On Mon, 27 Jul 2009 22:29:04 +0200, andrel wrote:
> On 27-7-2009 21:57, Jim Henderson wrote:
>> +1
> seen this more often recently here. Yet another cross fertilization of
> the internet, I assume.
Yep, IIRC it comes from Slashdot's moderation system.
Jim
On Mon, 27 Jul 2009 17:24:20 -0400, Warp wrote:
> Jim Henderson <nos### [at] nospam com> wrote:
>> +1. BASIC was used as a good entry level way to teach programming
>> logic (just like LOGO and PILOT) back in my early days programming.
> I wonder if that's the reason why it feels like the majority of
> programmers
> is incompetent... ;)
Nah, I think it's more that they went from there to machine language (not
assembler) without working through some intermediaries. ;-)
Jim
On 07/27/09 11:56, Warp wrote:
> Even if we took goto as barely acceptable, its original implementation was
> very ascetic. AFAIK the original BASIC did not support named labels, but
> instead every line of code was numbered (by hand by the programmer), and
> gotos always jumped to a specified line number. AFAIK the numbering of each
> line was mandatory. Naturally this made it quite problematic to insert code
> between existing lines. While it was customary to number the lines in
> multiples of ten, this only gives the possibility of inserting 9 lines
> of code between any existing lines. If you run out of line numbers, you
> will have to start renumbering. And good luck trying not to break existing
> gotos if you start renumbering. (Some later BASIC text editors supported
> automatic renumbering, including all gotos, but naturally no such editors
> existed back then, when even having an interactive text editor in the first
> place was luxury.)
I wonder when such editors came around. Ever since I used BASIC, there
was the RENUM command. Of course, I _started_ using BASIC long, long
after its invention.
ASCII and ye shall receive.
On 07/27/09 11:07, clipka wrote:
>> QuickBasic was it's highest development.
> Just out of curiosity: Did they ever introduce such things as structs (records
> in Pascal)? That was the thing that bothered me most about BASIC ever since I
> first wanted to store a list of data tuples. Using a separate array for each
> "dimension" of the tuple just didn't feel right.
I've forgotten, actually.
>> I was able to display an image and VBnet seemed to promise good image
>> handling capabilities if one could only figure them out.
> If graphics (or any other non-textual user interaction, for that matter) is what
> you want to do, it comes as no surprise to me that you don't like modern
> computer languages. The major problem, however, is not an inherent feature of
I can sympathize with David. As a kid, graphics was one of the fun
things about BASIC/QuickBasic. For someone new to programming, there are
a lot of things you can do using language concepts with graphics, and
it's a lot more interesting than writing a silly calculator program.
I think that's what kept me and many away from "serious" languages like
C/C++ for a long time. No book I picked up covered what I thought should
be straightforward: How do I color a pixel on the screen. Doing graphics
seemed to be a lot more complicated.
I didn't have Internet access, nor did I know anyone who knew much
programming, so no one pointed me to better ways to do graphics in C,
nor was I aware of other languages where it may be easier.
>> +1
On 07/27/09 11:58, clipka wrote:
> I think it was not before DOS 5.0 that Microsoft started to bundle BASIC again
> with DOS, possibly in an attempt to revive the dwindling popularity of BASIC;
> still it was not as omnipresent as it had been in the home computer era, so it
> didn't manage to attract as many new enthusiasts.
Not 100% sure, but I think every version of DOS I had had either qbasic
or gwbasic or basica.
>>> +1
LOL
>> +1. BASIC was used as a good entry level way to teach programming logic
> I wonder if that's the reason why it feels like the majority of programmers
Have you met the majority of programmers?
>> BASIC again with DOS, possibly in an attempt to revive the dwindling
>> popularity of BASIC; still it was not as omnipresent as it had been in
>> the home computer era, so it didn't manage to attract as many new
>> enthusiasts.
qbasic
I vaguely remember there being a BASIC interpreter in MS-DOS 3.3...
Jim
"David H. Burns" <dhb### [at] cherokeetel net> wrote:
> I remember right the first "real program" I ever wrote was a program to
> calculate ozone
> concentration on a Commadore Pet. It was the first computer I ever dealt
> with
> and after a *very* short time playing with it I was able to write a
> program to replace
> the one we had been using on a TI55(?) calculator (the one with the card
> reader --remember
> that?)
Unfortunately not - I started my computing career no earlier than in the
mid-80s, after having seen (and toyed around with) a C64 somewhere; and I
wasn't older than 12 back then.
> If I remember right, the QuickBASIC and QuickC
> IDE's were models of what a good simple IDE should be. Microsoft was
> good in those days!
They're not bad these days either. It's just that the typical scale of
applications and desired UI paradigm has changed a lot.
> Yes access to Windows graphic functions seem unnecessarily complicated and
> poorly documented. I can't see any good reason for this.
As for being poorly documented, I'm not sure. Might be one of those cases of
documentation written for people already familiar with the concepts. As for
unnecessarily complicated, I'm quite sure this was originally due to
performance constraints in the advents of GUIs, and later due to compatibility
issues.
> I don't understand a lot of what you say, but it fascinates me, I may
> have to learn OOP
> and more about modern programming just for the fun of it.
Go ahead :)
> > Speaking of Borland, maybe they still come with the good old "graph" library and
> > the BGI graphics driver format, in which case I'd expect them to include a BGI
> > to interface to Windows, too.
> Maybe it does, if so I haven't be able to find it--or recognize it. The
> old "graphic.h" was for DOS and
> won't work on XP, anyway, and I think the routines are incompatible with
> modern graphic
> cards.
Turbo Pascal - and I think Turbo C/C++ as well - did not use hard-coded routines
to access graphics, but proprietary graphics card driver ("BGI" = "Borland
Graphocs Interface") modules, in order actually access the graphics hardware.
There were drivers at least for CGA, EGA, Hercules, 16-color VGA, and IBM
8514/A, and there was also some 3rd-party 256-color VGA driver available for
the famous "Mode 13h".
I wouldn't be too surprised if people found a way to provide a BGI driver that
could open a window of a particular size and use it as a canvas. Heck, I even
personally wrote a driver for the SuperVGA modes of my own Trident TVGA 8900
card (except for the blitting operations which I found I didn't need) =B)
> > C is really not a pretty language, by the way.
> No, but it's fascinating, and in my little experience addictive.
Don't get *too* addicted to it - it has some bad habits, and its own share of
being frowned upon :P
It's funny that even today graphics in C/C++ development (and in fact quite
many other languages) is a difficult issue.
What makes it ironic is that a large part of C/C++ programs out there are
heavily graphical (most prominently the computer games), and seems like
everybody just somehow manages to get the graphics done, but when you ask
for a simple way of getting graphics, they will usually shrug and say that
it's a bit complicated... (Because it *is* a bit complicated.)
Also, rather curiously, most programming languages which have integrated
graphics routines, are usually the most inefficient ones, and thus the least
adept for making eg. heavily-graphical games. There are a few exceptions
(such as ActionScript, although its capabilities for making games is quite
limited, as it's not the most efficient of languages around), but they often
tend to be a bit inaccessible (such as precisely ActionScript).
The reason why in older computers it was easier to draw graphics was that
the language was very integrated to the system in question and didn't need
to be portable to a wide range of different systems. You had one fixed OS
(no updates or anything), one fixed hardware (no different graphics chips,
CPUs, amounts of RAM, etc) and one fixed scripting language which was tied
to that precise system.
Immediately when you started having different users with different
hardware setups, the whole graphics programming stumbled on a huge problem.
I have seen quite a lot of programs. :P
A convenient excuse anyway. "Everybody needs someone to look down on. If you
ain't got nobody else, well help yo'self to me!" -Kris Kristofferson
(quoted from
memory) :)
David
Warp wrote:
> David H. Burns <dhb### [at] cherokeetel net> wrote:
>> it was *very* useful at work and at play! And by it, I learned that even
>> I can program,
> No offence, but I think that's one of the big problems: So many people
> *think* that they know how to program because they have written some simple
> scripts with BASIC or whatever, and then clueless employers hire them based
> solely on the fact that they *claim* they know how to program, after which
> you get horrible programs which are huge, full of kludges, full of bugs and
> basically unmaintainable.
> You just have to read TheDailyWTF to see actual examples.
Ah, maybe this little monkey should just snope away and play in his own
tree and
not bother the *real* men at work. ;)
> >> I can program,
> tree and
That kind of mocking attitude isn't really helpful.
> there was the RENUM command. Of course, I _started_ using BASIC long,
> long after its invention.
Me to some of these guys must be _old_!
> What's "plonk"? Or maybe I don't won't to know. ;)
WIYF - Wikipedia is your friend ;)
Plonk is a Usenet jargon term for adding a particular poster to one's kill file
such that the poster's future postings are completely ignored. It was first
used in 1989 and by 1994[1] was a commonly used term on Usenet regarding kill
file additions.
The word is an example of onomatopoeia, intended to humorously represent the
supposed sound[2] of the user hitting the kill file. It is also sometimes given
as an acronym standing for Please Log Off, Net Kook, though this is likely a
backronym. Other used expressions are "put lamer on killfile" [3] and Please
Leave Our Newsgroup: Killfile!
Not really polite unless the other party is really gone out of control (in which
case it's not polite either, just a good deal more adequate).
Fortunately perhaps. The Commodore PET was one of those desk tops with
a built in monitor. It had, I guess, a 16K ROM and 16K of RAM. (That's
K) and
programs we stored on a cassette tape.
>> good in those days!
In those days MS wasn't trying to hog the market (or lacked the
resources to try),
didn't have a monopoly, and didn't rely on advertising hype for sales.
And they hadn't
come up with idea of letting their users. Today I avoid everything
Microsoft that I
can. To my regret, I let price influence me to by another Windows
machine about a
year ago. I've kicked myself ever since!
> issues.
What you say maybe true. Also writing good documentation may be a difficult
poorly paid, and thankless task.
I have several graphics "packages" which use the "Mode 13h" but programs
compiled
with them, even pre-compiled examples don't work with XP (and I suspect
the graphics
card I have is also incompatible). The graphics routines in John Beales
wonderful
heightfield programs don't work, though the rest of the program does.
I didn't and there's no danger of it now, but I can see how it might be
easy.
:)David
I'm still kid and hope to remain one eternally. But in the work I did in
science
and engineering,graphical and image displays were almost essential!
No book I picked up covered what I thought should be straightforward:
How do I
Yes!! My experience exactly, except that I have never found out how to
plot a pixel colored
or not on XP. (It was easy enough in DOS). But it can be done, is done,
all the time. Pov-Ray
does, but so far I haven't been able to find anyone who can tell me how.
I haven't been able to find it on the internet either.
David
IIRC one of the main factors of BASIC's popularity - the all-time famous C-64 -
did *not* have a "RENUM" command.
The first computer *I* used, the Amstrad CPC, *did* - hehe :P
If it is (and I can't believe that it's all that complicated), why is it??
Maybe, but why are the graphics for Windows itself so complicated? It's a
single operating system running mainly on similar hardware. And again
Pov-Ray does
it for images at lease. How does it do it? So it's complicated, even
*hard*, surely
someone knows how it is done and can tell me, or tell me where to find
out. *That*
was my original question on the programming news group which led to my
original
post in this thread. Of course, the thread has been fun --and
informative. :)
I've run on past suppertime! ;)
David
David
Yeah, I know what you're talking about (although it was Turbo Pascal for me
later, which fortunately did have 2D pixel graphics, almost as easy as the
BASIC for my homecomputer).
When I was learning C, there was a project I really wanted to do that required
2D graphics output. But how to? I had access to both Windows and Unix machines,
but I had not the slightest clue where to start researching how to do graphics
output on either Windows or X.
Fortunately, I happened to know a bit about the PostScript printer language - so
guess what I did :P
(I later went to save some paper and toner though by going for GhostScript for
test runs ;))
Yup. DOS times were even worse than nowadays, as there was no accepted standard
interface to graphics cards at all (except for standard CGA/EGA/VGA modes,
which later graphics cards tried their best to remain hardware compatible
with); so essentially each program came with its own proprietary set of
graphics drivers, which fully supported only a selection of SuperVGA graphics
cards available - and new graphics cards in turn would come with disks
providing graphics drivers for only the most popular graphics-hungry
applications.
High-quality graphics games in the VGA/SuperVGA era would almost invariably run
in the famous VGA mode 13h (320x200 pixels at 256 colors) anyway, which worked
fine on virtually all SuperVGA graphics cards, but didn't really max them out
of course.
Nor is it particularly helpful to mock the abilities of someone you've
only just met.
This thread needs a whole lot of "lighten up, folks!". Seriously.
Jim
On Mon, 27 Jul 2009 17:56:03 -0500, David H. Burns wrote:
> The Commodore PET was one of those desk tops with a built in monitor. It
> had, I guess, a 16K ROM and 16K of RAM. (That's K) and
The earliest PET computers had 2K of RAM in them, not sure what the ROM
size was, but it wasn't big.
Those older models also had the "chicklet" keyboard - good for elementary
students (which I was at the time), not so good for people with "grown
up" hands.
Jim
> (quoted from
> memory) :)
"Jesus was a capricorn"
(Identified from memory... man, it's been ages since I've last heard that song.)
Bill Pragnell wrote:
> "clipka" <nomail@nomail> wrote:
> [snip basic info]
> For BASIC fans, the Rolls-Royce of traditional BASIC:
> http://en.wikipedia.org/wiki/BBC_BASIC
> This is the language in which I first learnt programming. Only available on
> 1980s-1990s Acorn computers in the UK (and parts of Europe), unfortunately, so
> not widely known. However, on those 8-bit and 32-bit platforms, it was a very
> complete inbuilt language, practically part of the OS. As well as named
> functions, procedures, debugging tools and a built-in assembler, it had very
> powerful graphics and sound abilities courtesy of its close alliance with the
> OS. There were even keywords for directly poking and peeking to memory
> (although that probably makes most people shudder these days!). It was often the
> easiest tool for writing multitasking desktop apps too... :)
Thanks it sound to me like it was the way programming should have gone,
I'll look it up.
A peek function would still be useful, but a poke function on a multi
tasking system where
the operating system is in RAM ... well at best, you might reboot a lot.
BTW the PET instruction manual warned if you poked into the wrong area
you might have to
reboot the computer. At that time, I had no idea what this meant and
stayed away from poking
around until I realized all rebooting invoved was pressing the reset button.
David
David
>> (quoted from
>> memory) :)
Me too. I have it somewhere on a reel to reel tape. I wonder how long it
would take
me to find it.:)
>> tree and
If you really take it as mocking, I'm sorry. Of course it was tongue in
cheek and
referenced earlier posts. :)
David
> only just met.
> Jim
I *thought* my monkey comment was light. Maybe we have just harped on
this same,
rather tangled, thread to long. :)
I ought to apologize for my typos and irregular lines. The keyboard on
this Timex Sinclair
is rather small and my tail keeps getting in the way.
David
Wow! I actually took those numbers from my TRS 80 Model III. They did a
lot with a little
memory in those days. The PET I had had a full-sized normal keyboard,
IIRC (If I
remember correctly).
> up" hands.
> Jim
David
> compiled
> the graphics
I guess the graphics card would be perfectly fine with it - even today's
graphics card still include backwards compatibility with VGA, if only for
booting and just in case someone decided to run some old DOS.
XP (for good reason) doesn't allow you to access the graphics card directly
(just guess what happened if every application you have running on your
computer - say, browser, calculator, Windows Explorer and your own home-brewn
program - would try to poke around at the graphics hardware, maybe even trying
to run in different modes... perfect chaos.
But a suitable driver might provide a frame buffer of, say, 640x480 pixels for
you to use freely, and do the interfacing to Windows (including event handling)
for you, instead of directly accessing real hardware.
> The graphics routines in John Beales wonderful
The name doesn't ring a bell.
They call that SunView / OpenWindows. That's what SunOS used before X was
around. Linux still allows this stuff, too, as in the Linux FrameBuffer.
"We'd like you to back-port all the changes in 2.0
back to version 1.0."
"We've done that already. We call it 2.0."
> lot with a little
> IIRC
Yeah, the later models of PET used a full-sized keyboard - the 8K model I
remember certainly did, as did some variants of the 4K model IIRC.
That really takes me back, though....
Jim
Jesus was Jewish! -- Avenue Q Soundtrack
Jim
>> only just met.
>> Jim
> this same,
Oh, there have been much longer threads in here.... :-)
> this Timex Sinclair
Ah, the ZX-81? Had to use a rubber band to hold the 16 K expansion pack
on mine. ;-)
Jim
I can appreciate that it might be wise to restrict access to the video
card. But it is possible to
display images somehow. Pov-Ray does it and in a whole host of
resolutions. Maybe displaying
graphics is very hard but it can't be impossible!!
You took me aback! I had to call up Pov-Ray links to make sure had had
the name right.
Have you every played with heightfields? I can't imagine anyone who has
not being familiar
with John Beale's "Gforge".
David
>> this Timex Sinclair
> on mine. ;-)
> Jim
You go farther back than me. I wasn't lucky enough to get one of those.
The Timex-Sinclair
is a latter version.
David
I don't think it's really even just graphics, altho graphics are the main
source of problems.
I think having libraries (or, more particularly, "components") is a
difficult thing to do efficiently. I've been looking at bunches of code for
high-efficiency programming lately, and I've started remembering what I hate
about C and C++ and the ilk.
The problem with all the low-level languages like C and C++ and such is that
they don't really come with the libraries you need to do modern stuff.
There's nothing built in for threading, graphics, sound, IPC, etc. That's
all left to libraries developed well after the language was standardized.
With C it isn't too bad, but C doesn't support things at a high-enough level
that I can take (say) an MPEG decoder library or a media streaming library
and just use it. Most of the time the author either invents a whole bunch of
routines to handle logging, strings, async I/O, header parsing, etc. Nobody
really writes a sophisticated library relying on a minimum of outside
non-standard libraries any more. *Most* systems have their own names for
integers, strings, whole complex hierarchies of header files, etc. There's
nothing even coming close to UNIX pipes or something where you plug things
together without having to fix a bunch of stuff inside. For example,
everyone has different logging libraries, instead of just writing to stderr
like the libraries were originally designed to handle. If you want to use an
XML parser, an HTTP client, a multimedia stream receiver, and a graphics
framebuffer library, you're going to wind up with four different logging
mechanisms probably more than one resource manager.
C++ is a lot better, in that at least people seem to avoid rewriting
malloc() and such, and Boost (if you use it) has a bunch of handy libraries
handling stuff everyone needs but everyone reinvents. Which is great if all
the projects use the same version, and all your code is in C++. But just try
to (say) use Qt from a language other than C++, and watch the pain-fest
begin. If you can do everything from scratch in C++, you're in good shape,
but if you're putting together a bunch of third-party stuff, you're pretty
well screwed unless you can cut it into separate processes.
High-level languages designed to solve this problem (like C#, say) have the
problem that they solve it by giving you huge libraries, so if not all your
code is .NET, you're basically screwed again. At least you can go out and
buy the components you want. The problem here seems to be that building such
a framework properly requires a whole bunch of design on a huge library and
runtime system, but people don't want to pay for that. Plus, if it doesn't
come from someone that's essentially already a monopoly, getting everyone to
use it is problematic. It doesn't matter how complete .NET's libraries are
if you can't find the piece of code you're looking for except in some
baroque conglomeration of twisty C++ classes. And it doesn't matter how
complete .NET's libraries are if you can't use them on the machine you
happen to be programming.
Sadly, I don't really see this getting better. Either your language is
sufficiently low-level that it works everywhere you need it, or it is
powerful enough that it has bunches of good code already developed for it
(either as standard libraries or built into the language) that you can just
plug in and use.
I don't think we're quite there yet, but I think the fact that languages
evolve much more slowly than hardware does might make this less of a problem
in the future.
> the name right.
> not being familiar
(Warning! Thread is becoming dangerously on-topic! :) ).
I'm aware of it, but I never used it. I prefer making my height fields
with POV-Ray instead :)
Chambers
>>> this Timex Sinclair
>> pack on mine. ;-)
>> Jim
> The Timex-Sinclair
*Now* I feel old. ;-)
The PET was the first computer I used, back in 1981 or so. Unless you
count the teletype terminal my dad would bring home from work
occasionally and hook up to the phone with an acoustic coupler.
Jim
Legacy.
While nowadays computers would most likely have the memory to provide a frame
buffer for each application to write to, and display that as necessary - with
plenty of support from the graphics card - that wasn't the case when Windows
was initially designed. (It even wasn't the case when Windows 3.1 came out.)
Back then, in order to be able to display multiple overlapping application
windows at once, the solution was that whenever the position of a window would
change, all windows previously hidden below it but now visible would have to be
(partially) re-drawn by their respective applications.
This made it impossible to apply the classic straightforward approach of drawing
the window contents when the application saw fit. Applications to still use this
approach would now have to allocate a buffer to draw in, and upon request of the
operating system blit the appropriate portions of the buffer to the screen.
Things were made even more complicated by the application no longer having
control over which video mode to choose: That would be fixed for all
applications. And it could be anything, from 2-color 720x348 over 16-color
640x480 to, say, 256-color 1024x768 (which was an awful lot back then).
Limited, by the way, to a standard palette.
How was such data to be handled when an application would use its own buffer and
just copy portions of it? Memory and computing power were still valuable, and
all those potential candidates for a standard format were rather arbitrary
anyway (with non-palette-based 15/16-bit High- and 24-bit TrueColor modes
nowhere to be seen yet), so from that point of view it seems logical to me to
go for what would be known as "device-dependent bitmaps".
Some of those modes a user might have chosen posed another problem, in that they
were highly anisotropic (e.g. that 720x348 Hercules format intended to be
displayed on a 4:3 monitor), so it was also logical to compute the dimensions
and positions of applications' dialog elements not based on pixels, but some
other - necessarily somewhat arbitrary - distance unit.
I'm not sure if I get all these details right, but stuff along these lines added
up to make the Windows graphics interface somewhat complicated to use, and the
bane of backward compatibility has kept these complications alive to this day.
Oh, if only it had always been that simple!
Yes, nowadays everyone is using 24-bit RGB graphics, and typically at 1:1 pixel
aspect ratio, but that's something PC-users could only dream of in the early
days of Windows.
> And again Pov-Ray does
> *hard*, surely
> out.
Let's see if we can shed *some* light on this, at least to the point where you
can start asking "stupid" questions about it; i'm not really familiar with
using the Windows API though, and typically relying on Microsoft frameworks
(MFC or the .NOT framework [duh, what a typo! I guess it deserves to be left in
here just for laughs :P]), but maybe... ah, we'll see.
I'm taking the POV-Ray 3.7 (beta 33) source for reference, because I have that
right at my fingertips; the file to look at there is "pvdisplay.cpp" in the
"windows" subdirectory, which defines a WinLegacyDisplay object (well, an
object class, to be precisely).
WinLegacyDisplay::WinLegacyDisplay(...)
WinLegacyDisplay::~WinLegacyDisplay()
These are a constructor and destructor, respectively, which don't do anything
exciting. Consider it some of the C++ overhead for object classes.
bool WinLegacyDisplay::TakeOver(...)
This is just there to handle a special case where a window can be re-used from
one render to the next, so I leave that to you for later study.
bool WinLegacyDisplay::CreateRenderWindow (void)
This is meat; I'll quote some of it:
rect.right = GetWidth() ;
rect.bottom = GetHeight() ;
flags = WS_OVERLAPPEDWINDOW ;
AdjustWindowRectEx (&rect, flags, false, 0) ;
This picks the desired "net" size (insert anything you like for GetWidth() and
GetHeight() respectively), chooses some window style (whether it has a title
bar, which title bar buttons can be seen, how thick the border is, etc.) and
has Windows calculate the "gross" size that would be required for such a
window.
What follows are computations to make sure the window is not larger than the
total desktop, and to decide where to place the window.
The m_Bitmap stuff sets up the rules for the drawing space to be used; you'll
want to pretend m_Depth8Bit=false. m_Bitmap.biBitCount = 24 will give you the
3x8 bits RGB you want. The m_Bitmap.m_BytesPerLine formula is designed to round
up the number of bytes required per line to a multiple of 4; I'm not sure
whether Windows actually needs that, so just keep it.
m_BitmapSurface is then set to point to newly allocated memory (in pure C, you'd
use malloc() here), and will serve as the actual drawing space, with bytes laid
out as RGBRGBRGB... per line; don't forget that the lines are padded to
multiples of 4.
Clear() just fills the drawing space with that grey-and-white pattern each
render starts with.
CreateWindowEx (...) is one of the uglier beasts. This actually requests Windows
to create a new window with the following properties:
- 0: matches parameter #4 in AdjustWindowRectEx
- PovLegacyRenderWinClass: a value allowing Windows to identify where to send
"events" pertaining to the window (e.g. user interaction, or requests to redraw
itself); we'll have to come back to this later.
- "POV-Ray"; the title text; choose anything you like.
- flags | renderwin_flags: matches parameter #2 in AdjustWindowRectEx, plus
whether the window is initially minimized, maximized or neither.
- renderwin_left, renderwin_top: position of the window
- width, height: "gross" size of the window
- RenderwinIsChild ? main_window : NULL: If you just want to pop up a window
from a command line tool, set this to NULL.
- NULL: this is for defining a menu bar; set this to NULL for simplicity.
- hInstance: You can leave this to NULL, at the cost of Win95/98/ME
compatibility.
- NULL: Looks like this last parameter is not needed either.
The result value will be NULL in case of failure, or a code uniquely identifying
"your" window.
SetWindowLongPtr (m_Handle, 0, LONG_PTR (this)); stores a reference to the
WinLegacyDisplay object; if you're not using C++, skip this one.
What follows looks like code to insert scroll bars if necessary, in some cases
give focus to the new window, and to request a non-standard cursor to be used
when over the window (the crosshairs); I guess you don't need these for
starters.
InvalidateRect (m_Handle, NULL, false) ; informs Windows that the whole window
needs to be redrawn (we haven't displayed the contents of our drawing area in
the window yet); Windows will subsequently request us to actually redraw the
window (or portions thereof) as soon as it gets visible.
void WinLegacyDisplay::Initialise()
This seems to be some POV-Ray internal thing, and I guess you don't need any of
this.
void WinLegacyDisplay::Close()
This rolls back all the stuff from WinLegacyDisplay::CreateRenderWindow.
SendMessage (main_window, WM_COMMAND, CM_RENDERDESTROY, (LPARAM) m_Handle); is
some POV-Ray internal stuff again, ultimately leading to a call to
"DestroyWindow ((HWND) lParam)"; you want to substitute "DestroyWindow
(m_Handle)" here, which will discard the window.
m_BitmapSurface memory is released (in pure C you'd use free() instead of
delete)
Not sure what the m_ErrorBitmap is about. I guess some "can't display this, it's
too large" fallback image.
Never mind the PVEnableMenuItem stuff.
void WinLegacyDisplay::Show()
void WinLegacyDisplay::Hide()
These demonstrate how to show or hide a window without really killing it. The
meat is in the "ShowWindow (m_Handle, ...) ;", never mind the rest.
inline void WinLegacyDisplay::SetPixel (...)
This is meat that demonstrates how to actually use the drawing area. Note
however that it doesn't actually draw to the window, it just draws to the
buffer. It seems that for performance reason Windows is not informed that part
of the image is now in need of being redrawn; that's done somewhere else.
void WinLegacyDisplay::DrawPixel(...)
void WinLegacyDisplay::DrawRectangleFrame(...)
void WinLegacyDisplay::DrawFilledRectangle(...)
void WinLegacyDisplay::DrawPixelBlock(...)
These are some helper functions; not any particular meat in there (there is some
in DrawPixelBlock(), but that's for some specialty here).
void WinLegacyDisplay::InvalidatePixelBlock(...)
This code is called whenever a significant portion of our drawing area has been
updated, and tells Windows via InvalidateRect (m_Handle, &rect, false) ; that
the particular region needs re-drawing; the code before that deals with
converting picture coordinates to the coordinate system Windows expects here -
which may be a bit complicated if the window is maximized (IsZoomed
(m_Handle)), but that's application choice; for starters you may want to always
display your drawings at 100% size.
void WinLegacyDisplay::Clear()
This just draws the already mentioned grey-white checkerboard pattern to our
drawing area.
void WinLegacyDisplay::SetRenderState(bool IsRendering)
This just picks a different cursor, depending on whether POV-Ray is currently
rendering or has finished.
LRESULT WinLegacyDisplay::WindowProc (...)
LRESULT CALLBACK WinLegacyDisplay::StaticWindowProc (...)
Pure Meat! This is called by Windows when something special happens. We've yet
to see how Windows knows that this is the thing to call.
You definitely want to implement some reactions for the cases WM_CLOSE (which is
passed to this function when the user requests to close the window) and WM_PAINT
(which is called when Windows requests to re-draw portions of the window; this
is where we actually make the drawing area visible. You should also hndle
WM_DESTROY, as it will tell you when for some reason the window is destroyed.
return (DefWindowProc (m_Handle, message, wParam, lParam)) ; should be called
for all other events, telling Windows that we don't consider it any of our
bloody business.
In a pure C environment, you can combine the two functions into a single one;
WinLegacyDisplay::StaticWindowProc() is just there to call the other one.
HPALETTE WinLegacyDisplay::CreatePalette (...)
This seems to be irrelevant for 24-bit RGB operation.
The pvdisplay.cpp leaves us with a few loose ends; if I'm not mistaken, the
following code from the register_classes function in pvengine.cpp should tie
them up:
WNDCLASSEX wc ;
wc.cbSize = sizeof (wc) ;
wc.hIconSm = NULL ;
wc.cbClsExtra = 0 ;
wc.cbWndExtra = 0 ;
wc.hInstance = hInstance ;
wc.lpszMenuName = NULL ;
wc.hbrBackground = NULL ;
wc.style = CS_BYTEALIGNCLIENT ;
wc.lpfnWndProc = WinLegacyDisplay::StaticWindowProc ;
wc.hIcon = renderIcon ;
wc.hCursor = LoadCursor (NULL, IDC_CROSS) ;
wc.lpszClassName = PovLegacyRenderWinClass ;
wc.cbWndExtra = 8 ;
if (RegisterClassEx (&wc) == false)
return (false) ;
This must be executed prior to the stuff in pvdisplay.cpp.
We haven't tackled renderIcon yet, but you can leave that to NULL for starters.
I'm not sure whether you can leave hInstance set to NULL as well, but I guess
not; we'll most likely need yet another function defined in pvengine.cpp, which
is actually the official entry point for a full-fledged Windows application
(instead of main()):
int PASCAL WinMain (...)
There's a lot in there though that we'll not need, and I guess I'll leave this
up to later to sift through this. Suffice it to say here that the only stuff I
expect to be of relevance is in the while (!exit_loop) very near the end - you
need to run this after you have set up everything as outlined above; it's
basically the code that "does everything", including an occasional check for
inbound events (the while (PeekMessage (&msg, NULL, 0, 0, PM_REMOVE)) loop).
For comparison, here's some sample code from the Windows documentation from
Visual Studio:
HINSTANCE hinst;
HWND hwndMain;
int PASCAL WinMain(HINSTANCE hInstance, HINSTANCE hPrevInstance,
LPSTR lpszCmdLine, int nCmdShow)
MSG msg;
BOOL bRet;
WNDCLASS wc;
UNREFERENCED_PARAMETER(lpszCmdLine);
// Register the window class for the main window.
if (!hPrevInstance)
wc.style = 0;
wc.lpfnWndProc = (WNDPROC) WndProc;
wc.cbClsExtra = 0;
wc.cbWndExtra = 0;
wc.hInstance = hInstance;
wc.hIcon = LoadIcon((HINSTANCE) NULL,
IDI_APPLICATION);
wc.hCursor = LoadCursor((HINSTANCE) NULL,
IDC_ARROW);
wc.hbrBackground = GetStockObject(WHITE_BRUSH);
wc.lpszMenuName = "MainMenu";
wc.lpszClassName = "MainWndClass";
if (!RegisterClass(&wc))
return FALSE;
hinst = hInstance; // save instance handle
// Create the main window.
hwndMain = CreateWindow("MainWndClass", "Sample",
WS_OVERLAPPEDWINDOW, CW_USEDEFAULT, CW_USEDEFAULT,
CW_USEDEFAULT, CW_USEDEFAULT, (HWND) NULL,
(HMENU) NULL, hinst, (LPVOID) NULL);
// If the main window cannot be created, terminate
// the application.
if (!hwndMain)
return FALSE;
// Show the window and paint its contents.
ShowWindow(hwndMain, nCmdShow);
UpdateWindow(hwndMain);
// Start the message loop.
while( (bRet = GetMessage( &msg, NULL, 0, 0 )) != 0)
if (bRet == -1)
// handle the error and possibly exit
else
TranslateMessage(&msg);
DispatchMessage(&msg);
// Return the exit code to the system.
return msg.wParam;
Would be very boring these days: At worst, poking around would get that
particular app jam itself, and you'd have to kill it via the task manager.
The operating system (with lots of hardware support from the CPU) does a good
job at not allowing any app to peek or poke around in memory allocated to other
programs or the OS. Applications even typically get to see different sections of
physical memory at any particular address.
BTW, in C you can actually peek & poke around as you like on virtually all
platforms, simply by assigning an arbitrary integer value to a pointer and then
accessing the memory location pointed to.
May result in the application getting terminated for an access violation though,
courtesy of Intel's "protected mode" and paging mechanisms, which can be used to
automatically trigger a hardware interrupt when certain memory address ranges
are accessed, so that the OS can take over and handle the access accordingly
(killing a misbehaving program, swapping virtual memory back in, or the like).
> would take
> me to find it.:)
I gotta ask my dad to copy that vinyl record to mp3... I didn't really like
"Jesus was a Capricorn", but I guess one or two other songs from the album were
ok, though the only other one I recall was "Jesse Younger" (which I quite
liked).
> this Timex Sinclair
Ook!
(Or was that some other thread? ;))
> the name right.
> not being familiar
Indeed I haven't done much heightfield stuff.
So... is religion good or bad? :)
<ducks>
Chambers
>> the name right.
>> has not being familiar
Gforge has a lot of tools for modifying the basic heightfield. It's fun
to play with
in itself. It has its own display routine (16 bit) but this fails on XP
and maybe on 98 and
2000 -- I can't remember.
David :)
Well, it *is* complicated. I'm still not convinced that, even with
legacy considered,
that it need be so. But since it is, that's what I'll have to work with.
The 3.6 code that I have doesn't have "pvdisplay.ccp"
but I take it that the code wherever it is (pvengine, I suspect) is
similar. It looks like
I am going to have to delve into the mysteries of WINAPI (which I have
already looked
into a little.) Your post should help. Unfortunately Microsoft
documentation is rather obscure
too me, and I don't read well for very long on a computer screen. It's
gonna be a long learning curve, the
question is, is it worth it? I'm beginning to think not. But, then, when
once mastered, I should be
able to write routines that could with relative ease be adapted to about
any language. I need
not fear that they won't work on future Windows versions, because unless
I go completely senile,
I will *never* purchase another Windows machine! Even now I'm wondering
if graphic programming
with a Mac is this complicated.
Thanks a lot. I will study this and will no doubt have "stupid"
questions. :)
David :) :)
I didn't know that, if I ever did, I had forgotten it. Thanks :)
I blamed those "access violations" that occasionally show up on Windows. So
their really due to a "safety" feature in Intel's hardware. Is that why
machines with
AMD processor's (reportedly) crash and hangup less frequently?
David :)
