![](/i/fill.gif) |
I have the same thing on one of my drives. Looks like it's some control
information about encrypted files. Why it's hanging encryption information
off my vacation photos I couldn't say, given they're not encrypted. Weird.
It went away after I deleted the files that used to be encrypted but no
longer are encrypted. Very odd.
Insanity is a small city on the western
border of the State of Mind.
![](/i/fill.gif) |
![](/i/fill.gif) |
I see. When you encrypt a file, it needs a place to store the symetric key
used to encrypt the file, along with the public keys used to encrypt it.
There has to be a way, for example, to add an escrow key. When you decrypt
the file, Windows apparently keeps around the keys that were used to encrypt
it, for some reason (that reason possibly being "a bug"). The problem with
defragging them is not that you can't move the file, but that the API works
by you passing a file handle to the file to be defragged, and for obvious
reasons you can't open the fork of the file that holds the encryption keys
for the encrypted file. I.e., security prevents you from opening the file in
a mode that would let you defrag it.
Copying the affected files to a new name and then deleting the old ones
cleans up the problem. "cipher /u" apparently doesn't, but will let you see
which files it thinks have keys associated, and if they aren't encrypted,
you know which files might be problematic.
So I don't think it was "mydefrag" that moved the files, but rather that
something cleaned off the encryption keys from files that used to be
encrypted but aren't any longer. I bet compressing the files (and then maybe
decompressing them if you need to) would achieve the same result, tho.
</ramble_babble>
![](/i/fill.gif) |
