![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
scott wrote:
>> I have no idea what internal resistance is.
> A pretty accurate model of a battery is a perfect voltage source in
> series with an "internal" resistor. This then nicely explains how the
> more current you try to draw the lower the apparent voltage will be at
> the terminals of the battery.
As far as I'm aware, resistors affect only current, not potential. But
hey, I'm sure you know more about this than me...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Eero Ahonen <aer### [at] removethis zbxt net invalid> wrote:
> clipka wrote:
> > You need to invest extra power to get the higher frequency at the same AC
> > voltage and amps, right?
> Hmm, possibly.
> > So where does that extra power end up if you have the otherwise same AC running
> > through your body?
> At least part of it goes to heating the generator, which runs faster :).
> > EM field I'd guess - which may be just the extra "kick" you'd rather do without.
> That actually sounds reasonable. My head is atm too empty to remember
> how to calculate energies of EM fields, but it would make sense, while
> the field sure is frequency-dependent.
> -Aero
electrical impulses to the heart are interrupted and fibrillation occurs. IIRC
there are parts of the heart that receive the electrical impulses from the
brain then transmit secondary impulses to the muscle tissue to contract and
relax in an organised way. The electrical shock interrupts this process and you
get a disorganised high frequency oscillation in different parts of the heart. A
defibrillator is used to stop this effectively stopping the heart and the
natural sinus rhythm can be resumed. Before defibrillators became commonplace
the manual method was to strike the victims chest above the heart with a
controlled blow using the pinkie side of your fist. This was supposed to have
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Try putting 2 resistors in series, connect the power (you'll have eg.
+12V on R1+, R1- on R2+ and R2- on ground) and measure voltages between
R1+/R2-, R1+/R1-, R2+/R2-, you might be surprised
R1
R2
-Aero
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
No the heart is autonomous, will even beat outside the body for some
time (hours) if oxygenated. It's frequency can be modulated by stuff in
the blood and by nerve tissue that is close to the sinus node when they
release special molecules.
No, but what happens is much more complicated (i.e. you need a
complicated model to describe it and even then you see it happening
without getting much more understanding, but it works).
Standard procedure to induce VF in an open chest heart: hold a 9V
battery against it. And, no, I don't know how it actually works, but it
does.
> A defibrillator is used to stop this effectively stopping the heart and the
I does work sometimes. http://en.wikipedia.org/wiki/Precordial_thump Do
not apply to people that are not in VF:
http://en.wikipedia.org/wiki/Commotio_cordis
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Does anybody else find it slightly disturbing that andrel knows such things?
I mean, I know there's a good reason, but even so... kinda grusome.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I thought that you might respond :)
> does.
You are the expert I'm only a first aider
Unless you want to kill them ;)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> things?
As you may be aware, it is my job. It comes with being in a experimental
cardiology lab. BTW a beating heart is absolutely not gruesome, I would
rather say beautiful. I'd be happy to show you if you happen to be in
Amsterdam some time and an experiment is running. ;)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> things?
You don't watch enough TV.
Insanity is a small city on the western
border of the State of Mind.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> things?
> cardiology lab.
Indeed. But still... kinda freaky.
I once saw an operation on TV. They cut open a guy's chest, ripped his
ripcage apart, and inside was his heart. I swear, it honestly looked
like it was trying to CLIMB THE HELL OUT OF HIS BODY AND RUN AWAY!! O_O
*shivers*
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> things?
I always thought I watch far too much TV. :-P
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
