POV-Ray : Newsgroups : povray.off-topic : Interesting take on C++ vs others... Server Time
14 Oct 2024 15:12:17 EDT (-0400)
  Interesting take on C++ vs others... (Message 1 to 10 of 22)
Subject: Interesting take on C++ vs others...
Date: 2 Jun 2009 14:21:04
Message: <4a256d90$1@news.povray.org>
http://metamatix.org/~ocaml/price-of-abstraction.html
Very artificial benchmark to prove a point, methinks, but it's basically
supporting what Warp says. :-)
   There's no CD like OCD, there's no CD I knoooow!
Subject: Re: Interesting take on C++ vs others...
Date: 2 Jun 2009 15:19:55
Message: <4a257b5b@news.povray.org>
  C++ has indeed always been designed for number-crunching in mind, and
abstraction has always been added with the condition that it should not
have a significant hit to performance (or, at least, it should be possible
to create a compiler which can internally optimize away most of the overhead
caused by abstraction).
  That's precisely one of the reasons why I like C++'s design (even though
I'm also aware of its flaws in other respects). Given my line of work, it
makes me appreciate it even more. (I have to create quite often programs
which are quite number-crunching-heavy, and C++ allows me to easily do that
while still having a good level of abstraction. In other words, I don't have
to resort to such hardware-level coding as would be necessary with C.)
  Of course this doesn't mean that all possible C++ programs are always
automatically superfast. There are many situations where, if you don't know
what you are doing, you are going to end up with rather suboptimal solutions,
even if your algorithms are ok. (OTOH this is not really a problem exclusive
to C++, as C and many other "low-level" languages will have the exact same
problems.)
  (Btw, about the C++ program in that webpage: I think that if he had told
gcc to generate SSE code rather than FPU code, he would have got the desired
rounding without having to resort to inline asm...)
Date: 2 Jun 2009 15:29:43
Message: <4a257da7@news.povray.org>
Yah. Given that what I tend to do is complex interrelated data structures
with trivial amounts of math added, it doesn't seem as beneficial to me.
> problems.)
I think that's probably true of pretty much every language. I once spent an
hour removing the loops from the professor's APL code, and the run time went
from 15 minutes to about 30 seconds. And of course one major reason you have
a DBA is that SQL can give you crappy performance even if the algorithms are
decent.
Maybe he was trying to use the same FPU code that the other languages were
using. SSE uses a whole different execution model, yes?
Date: 2 Jun 2009 15:33:14
Message: <4a257e7a@news.povray.org>
  Why should that matter? The compiler should optimize as well as it can,
using any means it can.
  The SSE version would most probably have not been significantly faster,
but he would have got his 64-bit rounding without having to resort to
non-standard code.
Date: 2 Jun 2009 15:59:05
Message: <4a258489@news.povray.org>
> > problems.)
  I was more referring to some things which in theory one shouldn't have
to worry about, and which in many languages *are* things you don't have to
worry about, but in C++ they can bite you if you don't know about them.
  One concrete example which is a real shame with most C++ compilers is
memory allocation/deallocation speed. For some reason most compilers (and
very especially gcc) do a very poor job at this, even though they could
demonstrably do it much better.
  For example, consider this simple program:
#include <set>
int main()
    std::set<int> numbers;
    for(int i = 0; i < 10000000; ++i) numbers.insert(i);
  It does nothing else than add 10 million consecutive integers into a
balanced binary tree, and then destroys it and ends.
  Compiling this program with "g++ -O3 -march=native" in my system creates
a program which in my computer takes a bit over 15 seconds to run.
  Is this time spent into inserting elements and rebalancing the tree?
No. It's mostly spent in allocating memory!
  Let's change the 'number' definition a bit:
std::set<int, std::less<int>, FSBAllocator<int> > numbers;
  FSBAllocator is a memory allocator I have made. From a functional point
of view it doesn't change anything significant: The program still does the
exact same thing as before, and it even consumes about the same amount of
memory.
  However, when I run the modified program, it only takes 2.9 seconds.
Date: 2 Jun 2009 16:03:49
Message: <4a2585a5$1@news.povray.org>
OK. It was just a guess. :-)
Science depends on changing as few things as possible. If you're doing an
experiment comparing the speed cost of abstractions, running it on different
CPUs isn't a logical thing to do. :-)
Date: 2 Jun 2009 16:10:18
Message: <4a25872a$1@news.povray.org>
> to worry about,
Sure. And in theory, you shouldn't have to worry about what order you list
the tables to be joined in SQL. :-) More similar than you may think, I think.
Yep. That has always been a bane. Lots of people try to write
special-purpose allocators just for their programs which still don't do as
well as a good GC mechanism, too. (I posted a bunch of links to the actual
research a few months back.)
Allocation performance has always been a problem even long before C++ was
around. You'd certainly think people would have gotten it right by now. I
wonder why it's so hard, tho? Is it attempts to avoid fragmentation or
something?
I remember programs on machines with no MMU (like the Amiga) which had to
deallocate its memory on exit, when you'd exit the program and it would
spend long seconds cleaning up its memory. Even nowadays, you can sometimes
hear the disk thrash while exiting if you've started paging. :-)
It's cool to have a language where you can change that stuff without
screwing with the compiler, yes. :-)
Date: 2 Jun 2009 17:10:01
Message: <web.4a25948d6c437e29773c9a3e0@news.povray.org>
I'm not an OCaml expert, but I'd say that benchmark is flawed -- OCaml is
supposed to give performance very similar to C++ and its very unlikely Scala
running on top of JVM to beat it.  The author did use -O3 on GCC, what options
for ocamlopt?
Perhaps I should bring on Jon Harrop to the rescue. :)
Date: 2 Jun 2009 17:25:53
Message: <4a2598e0@news.povray.org>
  Show me one benchmark which isn't.
Date: 2 Jun 2009 17:45:00
Message: <web.4a259c526c437e29773c9a3e0@news.povray.org>
The algorithm here is a standard, not much to do about it.  Other than that, the
only thing one can do is use proper optimization flags for the compilers.  The
famous Language Benchmark Game gives proper optimization flags for the tools
that accept it and that makes it pretty fair.
