POV-Ray : Newsgroups : povray.off-topic : Still random Server Time
15 May 2026 23:05:26 EDT (-0400)
  Still random (Message 41 to 50 of 50)
Subject: Re: FIXED!
Date: 8 May 2009 14:15:15
Message: <4a0476b3$1@news.povray.org>
Darren New wrote:
> Orchid XP v8 wrote:
>> Well, if you wanted to go that far you could.
> Well, now you know why people do, when it's important to be correct. :-)
> Isn't it pretty trivial to do that in Haskell, tho?
Yeah, something along the lines of
   newtype Position = Position Vector2 deriving (Eq, Show, Vector, Num)
   newtype Velocity = Velocity Vector2 deriving (Eq, Show, Vector, Num)
Now just replace all occurrances of Vector2 with Position or Velocity as
appropriate.
The only problem is that *now* you can't say
   p1 = p0 * dt v0
without sprinkling it with typecasts.
Actually, what you'd *probably* do is define
   step :: TimeStep -> Velocity -> Position
   step dt (Velocity v) = Position (dt * v)
and then have
   p1 = p0 + step dt v0
Only problem now is that you'd have to define another such function for
acceleration - assuming you're going to have a seperate type for that.
There's probably some better way of encoding all this. (Possibly
assosiated types, or maybe just phantom types...)
http://blog.orphi.me.uk/
Subject: Re: Faster...
Date: 8 May 2009 14:16:20
Message: <4a0476f4$1@news.povray.org>
Nicolas Alvarez wrote:
> A clearer (for a human) way to see the speed is to show the inverse of that:
> seconds per frame.
Well, I can run the program and count the number of frames rendered per
minute (approximately). The number of seconds per frame isn't something
I can directly measure. (Of course, you can compute it yourself from my
numbers quite easily...)
Subject: Re: Still random
Date: 8 May 2009 15:29:26
Message: <4a048816@news.povray.org>
Darren New wrote:
> scott wrote:
>> I think the key point is that most things have a force that acts in
>> the opposite direction of the movement,
> I've always found this to be quite fascinating. Why should that be?
It seems like conservation of energy and the second law of
thermodynamics would essentially require this (barring situations where
there's some external source of energy).
If you had an effect that reinforced itself without using some external
source of energy then any measurable consequence of this effect would
have to increase as a system approached a high-entropy state.  Since
there's generally not much interesting to measure in a maximal entropy
state it shouldn't be a surprise that there's dampening forces everywhere.
Date: 10 May 2009 01:22:34
Message: <4a06649a@news.povray.org>
>> that: seconds per frame.
Imagine a 3D renderer. You put one sphere: 500fps. You add a second sphere:
250fps. What? It dropped a *lot* by just adding one more sphere! How is
this going to scale to a hundred objects?
Now, you put one sphere, it takes 2 milliseconds. You add another, 4
milliseconds. That sounds better.
Even though it's the *same numbers*.
Time per frame is clearer than frames per second because the brain can't get
around the inverse curve so easily.
Subject: Re: FIXED!
Date: 10 May 2009 05:30:05
Message: <4a069e9d@news.povray.org>
>   p1 = p0 * dt v0
> and then have
Couldn't you just define a * function that takes a velocity and a time and
returns a position?  You can do the same for one that takes an acceleration
and a time and returns velocity.  Then you wouldn't need to change the code,
and * looks better than "step".
In fact, maybe it's possible to do all this automatically if you keep track
of the units somehow?  Could you do this in Haskell?  Somehow tell it that
distance is units L, velocity is units L*T, etc, and then it would work it
all out automatically when you did multiplication and division.  Would be
pretty cool for phyical simulations.
Date: 10 May 2009 06:22:39
Message: <4a06aaef@news.povray.org>
> Of course, now I'm trying to comprehend how this *explicit* method
> differs from the more accurate *implicit* method I keep hearing about...
Useful link:
http://www.pixar.com/companyinfo/research/pbm2001/
Subject: Re: FIXED!
Date: 10 May 2009 11:43:10
Message: <4a06f60e$1@news.povray.org>
> track of the units somehow?
Yes.
That was kind of what I'd meant to ask. How easy is it? Is Haskell high
level enough to make a library for units that works like physical units?
   There's no CD like OCD, there's no CD I knoooow!
Subject: Re: FIXED!
Date: 10 May 2009 12:04:58
Message: <4a06fb2a$1@news.povray.org>
> and returns a position?
No.
I rephrase: Not if you want those to be different types.
The functions +, -, * and / are only defined to operate on values of the
exact same type (and return a result of the same type also).
You can, however, define new functions with the appropriate types. (Say,
have functions named |+|, |-|, etc. or something like that.)
Alternatively, you can provide new definitions for +, -, etc., but then
you have to manually remove access to the standard versions every time
you want to use them.
Subject: Re: FIXED!
Date: 10 May 2009 12:05:02
Message: <4a06fb2e$1@news.povray.org>
I know that several such libraries exist. I've never tried to use one,
so I couldn't say how they work.
Date: 10 May 2009 12:06:09
Message: <4a06fb71@news.povray.org>
> Useful link:
...those guys! o_O
