POV-Ray : Newsgroups : povray.off-topic : Random stuff Server Time
16 May 2026 01:27:24 EDT (-0400)
  Random stuff (Message 8 to 17 of 37)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Random stuff
Date: 30 Apr 2009 10:48:37
Message: <49f9ba45@news.povray.org>
> But yes, I'm pretty sure this system possesses such a property.
It might depend on how much damping you give it.
Date: 30 Apr 2009 10:54:28
Message: <49f9bba4@news.povray.org>
Doubt it.
Consider a point exactly between two attractors. A particle at this
point experiences zero resultant force. Purturbing the point by any
finite amount to either side will make the resultant force non-zero.
This will cause a different path to be traced, regardless of how much
damping is applied.
In general, applying more damping makes the system *less* unstable, but
does not remove areas of chaotic behavious; it just makes them smaller.
Date: 30 Apr 2009 10:55:28
Message: <49f9bbe0@news.povray.org>
Invisible wrote:
>> Now, if you add more than one attractor.....
> ...it goes completely scatty! o_O
Twisted and tangled, baby! :-D
Download 'test_drawmany.jpg' (48 KB)
Preview of image 'test_drawmany.jpg'
Date: 30 Apr 2009 11:15:20
Message: <49f9c088$1@news.povray.org>
As an aside, I tried to implement this on my laptop at the weekend, but
it was hopelessly unstable. Today it seems very stable indeed. I can
only assume this is to do with replacing Euler with 4th-order
Runge-Kutta. I'm surprised it makes quite this much of a difference
though...
Date: 30 Apr 2009 14:29:00
Message: <49f9edec@news.povray.org>
> damping is applied.
I think you may have some misconceptions about what chaos is.  First
off, sensitivity to initial conditions is a necessary but *not
sufficient* condition for chaotic behavior.  Secondly your example of a
point between the two attractors only argues for this sensitivity at a
manifold of points, and many many non-chaotic systems have such a
feature (for example a simple pendulum).
Thirdly, although it's possible I'm wrong here, if you have *any*
dampening I don't think the system can be counted as chaotic because all
paths will eventually converge to a point.  If the system would be
chaotic without dampening it's sort of a minor point since it can still
look a lot like chaos, but technically I think it's incorrect to call it
chaotic.
Finally, I'm not sure that your system is chaotic.  For inverse-square
springs it's known as Euler's three-body problem and appears to have a
(rather complicated) analytic solution.
Date: 30 Apr 2009 14:32:18
Message: <49f9eeb2$1@news.povray.org>
This is for just two attractors of course with three or more I'd be
pretty surprised if it weren't chaotic (and I wouldn't be too surprised
to find out I'm wrong about the two attractor system).
Also, neat pictures!  You should color-plot the basins of attraction
when you have a dampening factor.
Date: 30 Apr 2009 15:12:24
Message: <49f9f818@news.povray.org>
This is my goal. Unfortunately, the GTK+ subsystem is giving me some
spurious error message about a missing DLL or some such stupidity... *sigh*
http://blog.orphi.me.uk/
Date: 30 Apr 2009 15:21:18
Message: <49F9FA2C.2030803@hotmail.com>
You could use something like POV to do that for you...
Date: 30 Apr 2009 15:26:48
Message: <49f9fb78$1@news.povray.org>
>> *sigh*
I could use PPM too. It's just irritating that GTK+ has decided to stop
working today. :-/
Date: 30 Apr 2009 15:43:27
Message: <49F9FF5D.7070208@hotmail.com>
>>> *sigh*
> working today. :-/
I am sure you didn't change anything
