POV-Ray : Newsgroups : povray.off-topic : Code division multiplexing Server Time
15 May 2026 23:05:26 EDT (-0400)
  Code division multiplexing (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: Code division multiplexing
Date: 22 Apr 2009 17:15:04
Message: <49ef88d8$1@news.povray.org>
Tim Attwood wrote:
> All it takes for a bit to be lost is for one analog "chip" to be
> a little outside of it's intended magnitude and then it misses
> the whole bit.
Actually, the whole point of the technology is that you *can't* jam it
without basically blanketing everything in the entire bandwidth (including
your own signals), and it's virtually impossible to detect because it all
sounds like noise unless the receiver has a key that matches the
transmitter.  It was originally developed for military radios, ya know.
   There's no CD like OCD, there's no CD I knoooow!
Date: 23 Apr 2009 03:52:54
Message: <49f01e56$1@news.povray.org>
Darren New wrote:
> Orchid XP v8 wrote:
>> Apparently this is how mobile phones manage to all transmit at the
>> same time yet not screw up each other's transmissions.
> More specifically, how CDMA phones manage it. GSM phones and many others
> use different techniques.
Really? That's interesting... I got to the CDMA article *from* the GSM
article. o_O
Date: 23 Apr 2009 05:15:27
Message: <49f031af$1@news.povray.org>
Darren New wrote:
> http://denbeste.nu/special/cdma_spreading.html
> Not magic, but certainly very difficult to understand intuitively.
Hey, neat.
So it's kind-of like this?
http://en.wikipedia.org/wiki/Visual_cryptography
I'm still trying to figure out exactly how it works, but it's quite neat.
And now I'm wondering... can you implement this stuff using only
analogue electronics? My first instinct is "how the hell do you compute
signal correlation without a computer?" but now I'm thinking maybe you
can do it with some op-amps. The only real problem would be getting
sender and receiver to generate the same psuedo-random reference signal,
and keep it synchronised.
Date: 23 Apr 2009 10:01:54
Message: <49f074d2@news.povray.org>
http://google.com/search?&q=(analog+OR+analogue)+computer
Tor Olav
http://subcube.com
Date: 23 Apr 2009 10:33:41
Message: <49f07c45$1@news.povray.org>
Tor Olav Kristensen wrote:
> Invisible wrote:
>> My first instinct is "how the hell do you compute signal correlation
>> without a computer?" but now I'm thinking maybe you can do it with
>> some op-amps.
Oh my God, check it out:
http://en.wikipedia.org/wiki/File:AKAT-1.JPG
Funkalishous, baby!
But yeah, I was thinking that splitting a signal into pieces and
computing a step-wise correlation would seem to require digital
electronics. But it doesn't really. You could probably wire up a system
that has a meter showing the instantaneous correlation between two
inputs without much difficulty. (And the spring in the meter will
probably smooth it out quite nicely.)
Date: 23 Apr 2009 11:49:42
Message: <49f08e16$1@news.povray.org>
> Hey, neat.
Not too different, except you do it with dozens of different masks. :-)
Once you figure it out, then realize you can talk at two different speeds at
the same time on the same frequencies (which is what the phone does for
voice vs signaling), you can talk to two different carriers on the same
frequency at the same time, and you have to account for round-trip speed of
light delays, including predicting how much that delay will change before
the next packet based on the fact that you're driving towards or away from
the tower...   And the tower has to modify the timing of the chips for each
phone based on the round-trip delays.
No idea. :-)
Date: 23 Apr 2009 11:51:40
Message: <49f08e8c$1@news.povray.org>
> article. o_O
Sure. The old analog phones used FDM (Frequency Division Multiplexing), and
GSM uses (I think) TDMA - time division multiple access.  There's also
phase-division multiple access, as well as various combinations thereof.
Date: 25 Apr 2009 04:26:05
Message: <49F2C91D.6000305@hotmail.com>
>>> some op-amps.
> Funkalishous, baby!
We had one that filled one wall of the room at our practical instruction
lab (beginning 1980's). With a patch panel of 4 by 2 meters or so. It
used to be a section of an even larger one used for ship behaviour
simulation. We got it as a gift when they converted to digital computers.
Date: 25 Jun 2009 04:27:37
Message: <4a4334f9$1@news.povray.org>
Darren New wrote:
>> article. o_O
> and GSM uses (I think) TDMA - time division multiple access.  There's
> also phase-division multiple access, as well as various combinations
> thereof.
Hmm, OK. Apparently,
"The modulation used in GSM is Gaussian minimum-shift keying (GMSK), a
kind of continuous-phase frequency shift keying. In GMSK, the signal to
be modulated onto the carrier is first smoothed with a Gaussian low-pass
filter prior to being fed to a frequency modulator, which greatly
reduces the interference to neighboring channels (adjacent channel
interference)."
So not CDMA at all. Weird...
Date: 29 Jul 2009 04:51:31
Message: <4a700d93$1@news.povray.org>
Le 25/06/2009 10:27, Invisible nous fit lire :
> Darren New wrote:
>>> GSM article. o_O
>> Multiplexing), and GSM uses (I think) TDMA - time division multiple
>> access.  There's also phase-division multiple access, as well as
> interference)."
Not at all... but 3G (successor of GSM, in term of end-user technology/availabilty) is
using CDMA.
European use of UMTS (3G) is based on W-CDMA (W- : wideband), but not only.
GSM is 2G (quite old), playing with sub-channels (124 of 200kHz each, with 8 time
slot) in
TX & RX separated bands. Payload per timeslot is about 24.7 kbit/s (and no link
aggregation).
Of the 124 sub-frequencies, for a given point in space, they must be split between, at
least and optimaly, 3 ground-antenna (think plane-coloring... with some antenna having
different forms of cover, and some covers being influenced by the actual topology and
buildings)
GSM transmission is coded in the phase of a constant amplitude signal, allowing to
elect
the best antenna rather easily for the receiver (pick the strongest received
amplitude);
Phase modulation being one of the best modulation for issue with moving apparatus and
echo
of signal on buildings.
But it does not allow to share timeslots.
Between GSM and UMTS, GPRS and EDGE are extending the GSM system.
GPRS allow link aggregation (upto 8 timeslots, if the ground antenna is idle enough to
allow that), and then EDGE use a higher-density coding in the phase modulation to
extend
the bandwidth of GPRS (with limitation to the range... there must be a trade-off).
It's all like the old modem technology, giving new legs to an old horse.
(9600/28k/56k...)
CDMA (UMTS/...) is to GSM what ADSL is to modem. A totally different beast. The end
user
still surf the internet (resp. make phone calls), the technology in the middle is just
not
the same. And yet, it's only an electrical (resp. a radio) signal on a telephonic wire
(resp. on the air).
