POV-Ray : Newsgroups : povray.off-topic : COBOL Wow Server Time
15 May 2026 23:24:58 EDT (-0400)
  COBOL Wow (Message 11 to 20 of 32)
Subject: Re: COBOL Wow
Date: 12 Apr 2009 08:00:56
Message: <49e1d7f8@news.povray.org>
nemesis <nam### [at] gmailcom> wrote:
> 70-80%?  I thought COBOL was pretty much dead after SQL.
  Is SQL even Turing-complete?
Date: 12 Apr 2009 12:52:50
Message: <49e21c62$1@news.povray.org>
nemesis wrote:
> 70-80%?  I thought COBOL was pretty much dead after SQL.  Do COBOL programs use
> SQL databases?
COBOL predates SQL, but COBOL has of course been updated to support SQL.
Indeed, I believe COBOL was the first language to get embedded SQL. It
already had some fairly sophisticated file operation stuff built into the
language (like looking up values in flat files, etc.)
   There's no CD like OCD, there's no CD I knoooow!
Date: 12 Apr 2009 14:25:01
Message: <web.49e230e811354d36bbbb20030@news.povray.org>
No.  But my point is that COBOL was the language to write your business in when
there was:
1) no standard databases
2) no easier language
Even Perl+SQL database via DBI offer a far more robust and easier solution than
COBOL.  It's a language surviving on name.  Common Business... :P
That said, I think it's truly hard to believe COBOL is more used than SQL in
business today.  Every system these days accesses a SQL database in one way or
another, be it written in Java, C#, C++, Perl or, I believe, COBOL.
So, I believe that 70-80% figure sounds highly overrated unless it's counting
SQL out.
Date: 12 Apr 2009 14:41:57
Message: <49e235f5$1@news.povray.org>
> there was:
You got it backwards, actually. The CODASYL database standard is what led to
needing a business language to access databases, a la COBOL. SQL replaced
CODASYL only some 10-15 years later (depending on how you define "replaced").
No business-oriented language that was easier, yes. There was basically
assembler, fortran, cobol, LISP, maybe APL and/or BASIC. COBOL's definitely
the best of the bunch for business/database apps.
> COBOL.
Disagreed. Perl has no decimal money type, for example. Plus, it's up to the
programmer to ensure that files are laid out correctly between different
applications, for example. The lack of a file section in the data division
of Perl means you can screw things up in common files.  It might be "easier"
in some ways, but I don't think "more robust" is quite right, assuming you
mean "robust" the same way I do (namely, unlikely to screw up your data).
Plus, why in the world would you run an interpreted Perl program to do
things like (say) payroll, that you're going to compile once and run 100,000
times over the lifetime of the application?
Likely.
> SQL out.
I don't think SQL counts as a programming language you write programs in, at
least in the eyes of the author.
Date: 12 Apr 2009 15:05:39
Message: <49e23b83@news.povray.org>
> Every system these days accesses a SQL database in one way or another
  Btw, is it correct to say "SQL database"?
  AFAIK SQL is a computer language standard, not really a database standard.
SQL is simply the interface (or one of the possible interfaces) which is
used to access the database. Perhaps a good comparison would be like a
Unix kernel and the file system (which would correspond to the database) and
SH scripting (which would correspond to SQL). Just because you can access the
file system using SH doesn't make it an "SH operating system".
  Ok, maybe it wouldn't be too far-fetched to say that "SQL database" is
just short for "a database system which is mainly/exclusively interfaced
with using SQL".
  Btw, do database systems (such as Oracle) support any other interfaces
than SQL? Are there any database systems which would use something else than
SQL as the user interface? (Can MS Access be considered a database system?)
Date: 12 Apr 2009 15:32:44
Message: <49e241dc$1@news.povray.org>
> with using SQL".
Or perhaps "A database compatible with access via SQL"? SQL can't really
search anything that doesn't fairly closely follow the relational model, is
what I'm trying to say.
> than SQL?
Sure. There's QBE - Query By Example. There's all kinds of form inputs
(which eventually probably turn into SQL). There's what's called Relational
Algebra, where you write out selects, projects, and joins as such, altho I
don't know any databases that specifically expose that interface.
And of course there's a bunch of interfaces for things like making backups
or replicating data that access the database in a bulk-like way without
doing what you might call "queries".
Yes. CouchDB, Google's App Engine cloud database, Google's BigTable,
Amazon's SimpleDB, a bunch of stuff inside Amazon (like Dynamo), etc. All
pretty much targetted at spaces where speed or scale (or both) is more
important than consistency. (I.e., none of them are what you'd call ACID.)
I would certainly say so. Not a very sophisticated one, mind. And there were
tons of such database systems (foxbase, dbase, etc) back before desktop
machines got powerful enough to effectively support fully relational databases.
http://www.allthingsdistributed.com/2007/10/amazons_dynamo.html
http://labs.google.com/papers/bigtable.html
http://en.wikipedia.org/wiki/Query_by_Example
http://couchdb.apache.org/
http://code.google.com/appengine/docs/java/datastore/overview.html
Date: 12 Apr 2009 15:45:01
Message: <web.49e2444f11354d36bbbb20030@news.povray.org>
> > there was:
I vaguely remember about mentions to CODASYL.
I'd say Assembler and Fortran would be ruled out for business purposes right
away.  LISP was too imature at the time (60s) and was a hog meant for research
on AI and language design.  APL I don't really know, but BASIC is just that,
basic.  So, yeah, right language for the job, *back then*.
> > COBOL.
It was just an extreme example, perhaps not quite accurate, but the point is
that even a scripting language coupled to a RDBMS could do the job today, let
alone performant scripting languages leveraging from fast, robust VMs, like
Scala on JVM.
anyway, is it much of a hassle to use double to represent monetary values?
Perl is a glue language:  it's main purpose like should be all scripting is to
integrate different systems and route data between them.  Perl "slowness"
doesn't really get into account when it is expecting data from the RDBMS to
feed the PDF generator.
At workplace, at least, SQL responds pretty much for about 80% of the code, the
rest being forms and reports in Delphi to either enter or extract data to/from
the RDBMS.  Business rules validation on persistence is done by SQL stored
procedures.
> > SQL out.
SQL alone, no.  But stored procedures get you many new abilities.
Date: 12 Apr 2009 16:00:00
Message: <web.49e2478c11354d36bbbb20030@news.povray.org>
It may not be accurate, but the meaning is obvious, I guess: RDBMS employing SQL
as main interface.
> than SQL?
I heard Oracle supports Java.  PostgreSQL can have stored procedures written in
TCL, Python and Perl, all being used to *complement* SQL.  I don't think there's
that much more convenient a language to fetch relational data than SQL, even C#
with Linq resembles SQL very much.
If only it had some macro processing, it should be much more handy.  While views
can perform the same job, it's at cost of runtime performance.
I'm no fan of SQL.  I wish I was playing with pointers all day.
Date: 12 Apr 2009 16:13:56
Message: <49e24b84$1@news.povray.org>
Yes. It's not correct.  Add up a billion dollars in penny increments, and
tell me you can guarantee it's right.
> procedures.
Yeah, OK, if most of your actual code is in SQL, I'll grant you that. :-)
You still need something that supports the SQL data types, then.
Granted.
Date: 12 Apr 2009 16:15:28
Message: <49e24be0$1@news.povray.org>
They all eventually translate to SQL, tho, I think. Maybe some of the .NET
stuff is similar, but I don't know how the internals interface. Maybe
straight thru a COM-like interface without going thru SQL.
So learn CODASYL. :-)
