POV-Ray : Newsgroups : povray.off-topic : NP-complete Server Time
28 Feb 2026 13:56:15 EST (-0500)
  NP-complete (Message 1 to 10 of 21)
Subject: NP-complete
Date: 9 Apr 2009 05:07:35
Message: <49ddbad7$1@news.povray.org>
Hmm, I wonder... If a problem is "NP-complete", does that actually mean
it's impossible to solve? Does it even mean it's necessarily difficult
to solve? I was under the impression that NP-complete merely means it
might take a long time to solve...
Subject: Re: NP-complete
Date: 9 Apr 2009 05:28:52
Message: <49ddbfd4@news.povray.org>
  What makes you think that? Have you even looked at the definition of "NP"?
It's a completely different category from the "non-solvable" category.
Date: 9 Apr 2009 05:50:32
Message: <49ddc4e8@news.povray.org>
Statements like "we use the following heuristic since actually solving
[problem X] is NP-complete". This kind of implies that NP-complete =
impossible to solve.
Yes. Several times. Needless to say, I didn't really understand it very
well.
Date: 9 Apr 2009 09:26:00
Message: <49ddf767@news.povray.org>
  It doesn't imply "impossible to solve". It implies "impossible to solve
in a rational amount of time". People do not have millenia of time to
wait for the program to given a solution.
> well.
  Basically the NP complexity class is composed of those problems for
which the solution cannot, as far as we currently know, be solved in
polynomial time using a deterministic computer (which means that solving
the problem requires at least exponential time), but if a solution is
given, the solution can be verified in polynomial time.
  A problem is "NP-complete" if it can be transformed in polynomial time
into any other NP problem. What this means in practice is that if you ever
find a polynomial-time solution to some specific NP-complete problem, that
exact same solution can be used to solve *all* NP problems in polynomial
time.
  (Note that a solution to an NP-complete problem might not be usable as
a solution to the so-called NP-hard problems, so it makes a difference
whether a problem is NP or NP-hard.)
Date: 9 Apr 2009 12:05:00
Message: <web.49de1baeb57439ee805d39df0@news.povray.org>
I would have thought this would really have driven the point home:
http://xkcd.com/287
 - Ricky
Date: 9 Apr 2009 13:23:50
Message: <49de2f26@news.povray.org>
triple_r <nomail@nomail> wrote:
> http://xkcd.com/287
  Except that the problem depicted there is not NP. It's O(1).
  (It would be NP as a generic problem with unlimited input. With a fixed
input and a fixed goal, it becomes O(1).)
Date: 9 Apr 2009 14:23:26
Message: <49de3d1e$1@news.povray.org>
It's a minor quibble, but I don't think this bit of reasoning holds.
Integer factorization, for instance, has no known polynomial time
algorithm but there are known sub-exponential algorithms.  Also (as I'm
sure you know, but Andrew may not) polynomial time algorithms are
considered part of the NP class, just as far as we know they're disjoint
from the NP-complete class.
I found this picture handy in describing this relationship:
http://upload.wikimedia.org/wikipedia/commons/a/a0/P_np_np-complete_np-hard.svg
One other point which I have messed up before and had Warp correct me
on.  The NP and NP-complete complexity classes are for *decision
problems* only.  That is algorithms which only return a boolean as their
result.  If you want to refer to complexity classes for algorithms which
  return more complicated results, the correct terms are FP (instead of
P) and FNP (instead of NP).
Date: 9 Apr 2009 16:59:07
Message: <49de619b@news.povray.org>
In practice, you should interpret a problem being NP-complete to mean
that any known algorithm will have an exponential worst-case running
time.  This does not necessarily mean that you can't efficiently solve
the problem instances you encounter in practice, or that it's impossible
to quickly solve for an approximate solution.  What sorts of efficiency
gains are possible over the worse-case behavior of an exact algorithm
will depend on the particulars of the problem and the domain to which
you're applying it.
Date: 11 Apr 2009 18:40:05
Message: <49e11c45@news.povray.org>
>> http://xkcd.com/287
Yes, but "General solutions get you a 50% tip", according to the comic
tooltip :D
Date: 14 Apr 2009 04:47:08
Message: <49e44d8c@news.povray.org>
Really? I was under the impression that just recently - ah, wait. No,
they found a polynomial-time primality test, but factorisation. Oh well.
> problems* only.
Yeah, I thought that was the case...
