On Sun, 05 Apr 2009 16:29:09 +0100, Orchid XP v8 <voi### [at] devnull> wrote:
>For some reason, every few seconds the WiFi light flashes. Anybody have
>any idea how I can completely disable WiFi? (If it were up to me, I
>would have purchased a laptop that doesn't *have* WiFi, but for some
>reason that appears to be impossible...)
>Specifically, I'd like to make absolutely sure it can't connect to any
>networks of any kind, and that it isn't wasting battery power trying.
You should find the answer in the manual.
You could disable it in the Device Manager
Regards
>> have any idea how I can completely disable WiFi?
> Disabling it in Network Connections doesn't do the trick?
Seems to work.
*manual*?! o_O
(Well, in fairness, there was a sheet of paper telling me how to insert
the battery and turn it on...)
>> Mmm, OK. It just seemed to take an absurdly long time to do whatever
>> it was doing. (And nailing the HD while it was doing it.)
> Since the test of the HD takes about 15 seconds here, I'm expecting your
> laptop was doing other things during the test (like building search
> indexes) or was swapping.
I reran it and timed it. 4 minutes in total. (Interestingly, when you
rerun it, it actually *tells you* what it's doing! Mostly 3D tests...)
>*manual*?! o_O
Yes.
Regards
And if you change hardware, it runs it at the next reboot, in console mode.
I have to believe it drives the programmers of these things nuts to have so
many different environments to write this code in. :-)
There's also screensavers or some such that run the tests.
There's no CD like OCD, there's no CD I knoooow!
> mode.
O RLY?
> to have so many different environments to write this code in. :-)
Heh, yeah...
