For some reason, every few seconds the WiFi light flashes. Anybody have
any idea how I can completely disable WiFi? (If it were up to me, I
would have purchased a laptop that doesn't *have* WiFi, but for some
reason that appears to be impossible...)
Specifically, I'd like to make absolutely sure it can't connect to any
networks of any kind, and that it isn't wasting battery power trying.
http://blog.orphi.me.uk/
Orchid XP v8 wrote:
> Mmm, OK. It just seemed to take an absurdly long time to do whatever it
> was doing. (And nailing the HD while it was doing it.)
Since the test of the HD takes about 15 seconds here, I'm expecting your
laptop was doing other things during the test (like building search indexes)
or was swapping.
There's no CD like OCD, there's no CD I knoooow!
Disabling it in Network Connections doesn't do the trick?
On Sun, 05 Apr 2009 16:29:09 +0100, Orchid XP v8 <voi### [at] devnull> wrote:
You should find the answer in the manual.
You could disable it in the Device Manager
Regards
>> have any idea how I can completely disable WiFi?
Seems to work.
*manual*?! o_O
(Well, in fairness, there was a sheet of paper telling me how to insert
the battery and turn it on...)
>> it was doing. (And nailing the HD while it was doing it.)
> indexes) or was swapping.
I reran it and timed it. 4 minutes in total. (Interestingly, when you
rerun it, it actually *tells you* what it's doing! Mostly 3D tests...)
>*manual*?! o_O
Yes.
Regards
And if you change hardware, it runs it at the next reboot, in console mode.
I have to believe it drives the programmers of these things nuts to have so
many different environments to write this code in. :-)
There's also screensavers or some such that run the tests.
> mode.
O RLY?
> to have so many different environments to write this code in. :-)
Heh, yeah...
