POV-Ray : Newsgroups : povray.off-topic : stupid out of memory errors Server Time
16 May 2026 01:27:14 EDT (-0400)
  stupid out of memory errors (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: stupid out of memory errors
Date: 8 Mar 2009 11:59:39
Message: <op.uqhddtu57bxctx@e6600>
On Sun, 08 Mar 2009 15:08:22 +0100, [GDS|Entropy]
<gds### [at] hotmailcom> wrote:
> "Eero Ahonen" <aer### [at] removethiszbxtnetinvalid> wrote in message
> news:49b3d036$1@news.povray.org...
>> [GDS|Entropy] wrote:
>>> I *really* hate those.
>>> Can't pov just use a freakin swap file?? Grrr....
>> Yes, it can. Tested with 12G consuming render and 1G of physical RAM :).
>> -Aero
> I don't understand why I'm getting those errors then... It will suck up
> 2gb of ram and then it dies, sometimes catastrophically. I have like 80gb
> free on disk too.
Because you are using a 32-bit OS. With a few tweaks you could push the
limit to 3 GB, but that is as much as you can get for a single 32-bit
application.
FE
Date: 8 Mar 2009 12:27:33
Message: <49b3f1f4@news.povray.org>
[GDS|Entropy] <gds### [at] hotmailcom> wrote:
> I don't understand why I'm getting those errors then... It will suck up 2gb
> of ram and then it dies, sometimes catastrophically. I have like 80gb free
> on disk too.
  You have a 32-bit computer and you are running the 32-bit povray
executable, yes? 32-bit programs cannot allocate more than 2 GB
(or in Windows, if you turn on some setting, 3GB) of memory. It's
a question of adressable space.
  It would be possible to address more data by using 64-bit addresses
(which is how eg. files of over 4GB are handled), but in a 32-bit
computer managing 64-bit addresses will impose a speed penalty, as
every operation requiring memory access or even just copying these
addresses around involves extra steps. This would also require some
heavy refactoring of the entire POV-Ray source code.
Date: 8 Mar 2009 14:45:39
Message: <49b41253@news.povray.org>
news:49b3f1f4@news.povray.org...
>> 2gb
>> free
>> on disk too.
I know that in 32bit OS progs are limited to 2gb max or so each, but why
can't pov use a swap file like photoshop?
Yeah...
Damn....I'm going to have to break down and install XP Pro 64 I think...
I'd like to upgrade to quadcore first though, since its only like $200 now
for the proc..
You don't happen to know what that "some setting" is that would let me use
3gb for progs until then do you? That would really be useful...
I freakin swear, my next computer is going to have at least 1333mhz mobo
bus, 16Gb+ DDR3 Ram, RAID5 10krpm SATA (SAS to much $$), 2x768mb nvidia
geforce sli, eSATA ports, USB3 ports, xp pro 64...hells...I might even go
for one of those nvidia Tesla systems...(wish I could snatch up one of the
Cray CX1s...$30k tho..)
And if windows 7 actually does make you pay monthly for features else they
get turned off, then screw it...I'm just going to drop windows altogether
and run Mono and Ubuntu.
ian
Date: 8 Mar 2009 15:11:18
Message: <49b41856@news.povray.org>
Look at the /3GB switch setting in boot.ini, as described here:
http://www.microsoft.com/whdc/system/platform/server/PAE/PAEmem.mspx
Date: 8 Mar 2009 15:21:34
Message: <49b41abe$1@news.povray.org>
The confusion is between the amount of semiconductor RAM available and the
amount of space in the address space.
Maybe an analogy would help: At the bank, they give you 4 squares on the
deposit slip to write the amount of your deposit. The most you can deposit
on one slip is $9999. Now, maybe their cash drawer only has room to fit
$1000 at a time, so the use the "swap space" in the vault to move different
drawers in and out of the vault to handle peoples deposits. You can have
lots of people depositing $100 and $200 at a time, and you can have one
person deposit $6000 (but that person will wait while tellers run back and
forth to the vault), but one person just can't put more than $9999 in their
account regardless of how big the bank vault is.
You're running up against there only being 32 squares on the deposit slip,
regardless of how much room is left in the vault. You'll find you can run
(slowly) another copy of POV at the same time that the first is running out
of memory.
POV could use a swap file and manually track it, but that's a *lot* of code
for relatively little gain. (Indeed, pretty much all the text editors and
word processors back in 9-bit days did the same sort of thing.)
It would have been more gain had 64-bit computers not come along and
eliminated the need to track that manually. Now, it's probably cheaper to
install Win64 than it is to pay someone to code up a swap file in POV. :-)
The power of mass market solutions trumps per-application solutions, in this
case.
GIYF. http://www.microsoft.com/whdc/system/platform/server/PAE/PAEmem.mspx
"The virtual address space of processes and applications is still limited to
2 GB unless the /3GB switch is used in the Boot.ini file."
> xp pro 64
I have noticed that on high-end machines, Vista seems to do a better job of
handling (for example) disk and windowing stuff at the same time. I can copy
from disk1 to disk2 and disk3 to disk4 and still not bring the system to its
knees, which wasn't true of my xp systems.
I think a huge number of people would agree. Have you heard anything along
those lines announced? I'd be surprised if anything other than "enterprise"
type stuff (like Exchange servers, say) needed an ongoing license fee.
   My fortune cookie said, "You will soon be
   unable to read this, even at arm's length."
Date: 8 Mar 2009 16:53:58
Message: <49b43066$1@news.povray.org>
2gb
free
> > on disk too.
When working with swap files, there is no speed penalty (nothing appreciable
anyway), whether it's 2GB, 2TB or 2EB.
Date: 8 Mar 2009 17:18:40
Message: <49b43630@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:49b41abe$1@news.povray.org...
this
> case.
Swapping to disk is immaterial of data bus width, it all depends on how much
physical memory you have installed. Physical memory is still relatively
expensive and not dense enough, there are physical and electronic
limitations, so even 64 bit systems shipping today may be limited to as
little as 6GB.
On top of that, for high efficiency, automatic memory management will not
beat application managed memory. It's the application that knows (or should
know, since moderns paradigms of today, carried out to the extreme, seem to
strive to make an application as ignorant as possible of the overall
picture) what data needs to be in memory and what data can be swapped out.
OS manages memory more or less blindly, ignorant of the application's
architecture or needs.
Not directly related, but one of my biggest beef is with applications that
don't know or care how big of data they are dealing with. Some archivers,
for instance, instead of uncompressing/compressing an archive to the
destination folder directly, uncompress it to a windows temporary folder,
and then copy it to the destination. It's assinine as it is, but for a 1MB
file, it's bearable. For a 1GB file, it's absolutely ridiculous. Similarly,
I've, on more than one occasion, cancelled a 2hr download by mistake and
went scrambling to the temporary internet files folder, because due to
thoughtless GUI design, the download window, with the *focus on cancel
button*, comes to the foreground once the download is complete and Windows
starts copying (again, assinine) the file from the temp folder to its
destination folder. That behaviour, as dumb as it is, may be acceptable for
a download that takes 2 seconds, and the shortsighted programmer surely did
not think of anything else, but not for a download that takes 2 hrs during
which time the user starts typing and working on other things on the
computer.
Similarly, a text/hex editor that uses the same method (of loading into
memory) for opening a 1KB file as a 1GB file is, to put it mildly, has got
to be written by monkeys. No application that deals with variable size data,
IMO, should be ignorant about the amount of data it may be dealing with, and
chose sensible strategies for different amounts of data.
Date: 8 Mar 2009 19:12:09
Message: <49b450c9@news.povray.org>
> this
>> case.
No. It also depends on how much address space you have available to work
with, if you're talking about OS-supported demand-paged memory.
If you're talking about what Photoshop does, basically building its own
demand-paged addressing system on top of the application, then no, that
makes less difference. Photoshop has that feature because it was originally
written in the days of 8-bit and 16-bit machines, where it was normal for
the data to exceed the address space even in usual uses. Most programs of
the time had the same kinds of features. It's very difficult to add
after-the-fact, especially to a program written in a language where it's
easy to make assumptions about how memory is organized.
> little as 6GB.
6GB of physical RAM. That's not your problem. Your problem is that you have
only 2GB of address space. You'd run into the same limitation regardless of
how much physical RAM or disk you have.
That's debatable. It's certainly sometimes true. Not always, tho.
Talk to RSM. I tried to use his emacs a long time ago, and the executable
wouldn't even link into the address space of an 8086. :-) Other editors of
the time (just as powerful) knew memory was limited and did things to handle
it.
Date: 8 Mar 2009 22:52:40
Message: <49b48478$1@news.povray.org>
news:49b450c9@news.povray.org...
much
I meant application managed swapping.
originally
Yes, "usual use" is the operative phrase. It's very hard to anticipate what
a "usual use" is, even down 6 months down the road. Adobe got lucky being
forced to make correct decisions at that time. You are also correct that's
it's very difficult to alter the architecture of an existing program, as you
note below. Thus, the safe method is to *not* assume your data will always
fit into physical memory, even if it will fit into the address space for the
foreseeable future. If the possibility is there that the data may not fit
into physical memory, you have to ask if you or the OS will be in a better
position to decide when, if, what and how to page. OS, to me, should be the
last resort. I see entirely too many programs today being written with most
inefficient use of memory since "OS will manage it". With 64 bit address
space, I am pretty sure that we will see applications that are memory hogs
and inefficient at levels we have never seen before.
> Most programs of
Date: 9 Mar 2009 13:22:27
Message: <49b55053@news.povray.org>
> foreseeable future.
I disagree. You balance the functionality you lose against the speed and/or
efficiency and/or programming convenience you gain.
Yep. And you have to balance it against the fact that the OS *will* make
that decision regardless of whether you want it to or not, and regardless of
whether you're coding your own paging or not. You also have to balance it
against the fact that the OS knows who else is using the memory, the
performance characteristics of the various devices in the machine (including
page tables, main memory, USB memory, and the disks it may have available to
swap to), paging behavior of previous executions of the program, and so on.
I'm not sure you'd gain much by reimplementing all that logic in each
application and *still* not having the global knowledge the OS has.
> OS, to me, should be the last resort.
I'm glad all your programs implement their own custom swap files. Me, I'd
rather have actual improvements in the outputted results, especially given
that we both already have machines that can handle plenty of memory.
If 64-bit chips and OSes weren't already available, I might agree with you
that it is important. But I'd rather see POV making full use of all the
cores than getting slowed down to support someone running a 32-bit OS on a
64-bit machine.
Then don't buy them. :-)
