POV-Ray : Newsgroups : povray.off-topic : stupid out of memory errors Server Time
16 May 2026 01:27:13 EDT (-0400)
  stupid out of memory errors (Message 11 to 13 of 13)
Subject: Re: stupid out of memory errors
Date: 8 Mar 2009 19:12:09
Message: <49b450c9@news.povray.org>
somebody wrote:
> "Darren New" <dne### [at] sanrrcom> wrote in message
> news:49b41abe$1@news.povray.org...
>> It would have been more gain had 64-bit computers not come along and
>> eliminated the need to track that manually. Now, it's probably cheaper to
>> install Win64 than it is to pay someone to code up a swap file in POV. :-)
>> The power of mass market solutions trumps per-application solutions, in
> this
>> case.
> Swapping to disk is immaterial of data bus width, it all depends on how much
> physical memory you have installed.
No. It also depends on how much address space you have available to work
with, if you're talking about OS-supported demand-paged memory.
If you're talking about what Photoshop does, basically building its own
demand-paged addressing system on top of the application, then no, that
makes less difference. Photoshop has that feature because it was originally
written in the days of 8-bit and 16-bit machines, where it was normal for
the data to exceed the address space even in usual uses. Most programs of
the time had the same kinds of features. It's very difficult to add
after-the-fact, especially to a program written in a language where it's
easy to make assumptions about how memory is organized.
> so even 64 bit systems shipping today may be limited to as
> little as 6GB.
6GB of physical RAM. That's not your problem. Your problem is that you have
only 2GB of address space. You'd run into the same limitation regardless of
how much physical RAM or disk you have.
> On top of that, for high efficiency, automatic memory management will not
> beat application managed memory.
That's debatable. It's certainly sometimes true. Not always, tho.
> Similarly, a text/hex editor that uses the same method (of loading into
> memory) for opening a 1KB file as a 1GB file is, to put it mildly, has got
> to be written by monkeys.
Talk to RSM. I tried to use his emacs a long time ago, and the executable
wouldn't even link into the address space of an 8086. :-) Other editors of
the time (just as powerful) knew memory was limited and did things to handle
it.
   My fortune cookie said, "You will soon be
   unable to read this, even at arm's length."
Date: 8 Mar 2009 22:52:40
Message: <49b48478$1@news.povray.org>
news:49b450c9@news.povray.org...
much
I meant application managed swapping.
originally
Yes, "usual use" is the operative phrase. It's very hard to anticipate what
a "usual use" is, even down 6 months down the road. Adobe got lucky being
forced to make correct decisions at that time. You are also correct that's
it's very difficult to alter the architecture of an existing program, as you
note below. Thus, the safe method is to *not* assume your data will always
fit into physical memory, even if it will fit into the address space for the
foreseeable future. If the possibility is there that the data may not fit
into physical memory, you have to ask if you or the OS will be in a better
position to decide when, if, what and how to page. OS, to me, should be the
last resort. I see entirely too many programs today being written with most
inefficient use of memory since "OS will manage it". With 64 bit address
space, I am pretty sure that we will see applications that are memory hogs
and inefficient at levels we have never seen before.
> Most programs of
Date: 9 Mar 2009 13:22:27
Message: <49b55053@news.povray.org>
> foreseeable future.
I disagree. You balance the functionality you lose against the speed and/or
efficiency and/or programming convenience you gain.
Yep. And you have to balance it against the fact that the OS *will* make
that decision regardless of whether you want it to or not, and regardless of
whether you're coding your own paging or not. You also have to balance it
against the fact that the OS knows who else is using the memory, the
performance characteristics of the various devices in the machine (including
page tables, main memory, USB memory, and the disks it may have available to
swap to), paging behavior of previous executions of the program, and so on.
I'm not sure you'd gain much by reimplementing all that logic in each
application and *still* not having the global knowledge the OS has.
> OS, to me, should be the last resort.
I'm glad all your programs implement their own custom swap files. Me, I'd
rather have actual improvements in the outputted results, especially given
that we both already have machines that can handle plenty of memory.
If 64-bit chips and OSes weren't already available, I might agree with you
that it is important. But I'd rather see POV making full use of all the
cores than getting slowed down to support someone running a 32-bit OS on a
64-bit machine.
Then don't buy them. :-)
