POV-Ray : Newsgroups : povray.off-topic : This GPL stuff is getting ridiculous Server Time
22 Dec 2025 21:28:57 EST (-0500)
  This GPL stuff is getting ridiculous (Message 21 to 30 of 187)
Subject: Re: This GPL stuff is getting ridiculous
Date: 28 Jan 2009 13:22:29
Message: <4980a265$1@news.povray.org>
Jim Henderson wrote:
>>   This makes GPL incompatible with all other licenses. This is rather
>> restricting.
> But protective of the rights of the original author, which is the
> underlying goal.
Which original author? The one giving away the code with more restrictions,
or the one giving away the code with fewer restrictions?
   "Ouch ouch ouch!"
   "What's wrong? Noodles too hot?"
   "No, I have Chopstick Tunnel Syndrome."
Date: 28 Jan 2009 13:31:02
Message: <4980a466@news.povray.org>
Warp escreveu:
> nemesis <nam### [at] gmailcom> wrote:
>> Except freedoms are preserved rather than taken away.  You're still free to use
>> it in *any way* you want.  And if you want to modify it for yourself or your
>> organization.  You just have to comply to the GPL way if you later want to ship
>> that modified work, in which case the GPL is enforced so that you don't deny
>> others the same rights the GPL offered you.
>   There's a contradiction in there.
>   If you *have to* comply to something before you can distribute, that
> nullifies the claim that you are free to use it in *any way* you want.
True.  But I stated my claims in 3 ways:  first about usage (you can use
GPLed software in anyway you see fit), second about private
modifications (no need to release modified souce code under GPL) and
third about released modified GPLed work.  No contradiction when in context.
>   GPL is, in fact, rather restrictive. For example, if I make a project
> under, let's say, the MIT license, I have to make extra sure that I don't
> include *any* GPL'd code in it because that would be againt the GPL license.
True.
>   Just the fact that you can include MIT-licensed code in a GPL-licensed
> program but not the other way around tells a lot about which license is
> more "free".
The MIT/BSD license does nothing to protect such freedom.
If a MIT open-source project stales and dies out and all hosts of the
original code die out and only survivor of said original code is a
heavily modified closed software that led that project to die out by
providing proper marketing and more developers to make it a much better
product, then you are... well, screwed?
And if you were one of the contributors of code and patches to that
software and later realizes Microsoft or Adobe using it in their closed
products without any acknowledgement (let alone royalties) and pissing
and laughing on your grave, you are screwed too.
The GPL protects the code from gettting trapped into a closed product
and also the rights of the original developers to it.
It's more restrictive because it must make sure code remains free to use
and modify.  I take it over any permissive license anyday.
Date: 28 Jan 2009 13:33:19
Message: <4980a4ef@news.povray.org>
Warp escreveu:
> restricting.
http://www.gnu.org/philosophy/license-list.html#GPLCompatibleLicenses
Apache and Boost are among them.
Date: 28 Jan 2009 13:35:37
Message: <4980a579@news.povray.org>
Darren New escreveu:
> Except we're talking about plug-ins here, which by their very definition
> are an independent part of the program.
Yes, see my answer to Nicolas above.
Date: 28 Jan 2009 14:10:18
Message: <4980ad9a@news.povray.org>
> Your freedom to not be
> punched in the nose restricts my freedom to punch you in the nose.
I feel that freedom is in risk right now. ;)
> Then what freedom does it add to the author to force his plug-in to be
> open source and licensed under the GPL?
The freedom to use the gcc infrastructure for the benefit of his plugin.
> How does that benefit anyone
> who wants to use the plug-in without modification?
The GPL allows for unrestricted *use*, for any means.
Date: 28 Jan 2009 14:12:07
Message: <4980ae07$1@news.povray.org>
No. You're using the much better product. Or you have a copy of the source
of an unimproved program. Why would all copies of an MIT-licensed source be
more likely to disappear than all copies of a GPL-licensed source?
All you're saying is that the GPL prevents anyone from dedicating enough
resources to make it worth paying money for? ;-)
Unless that's what you want. Unless you're more interested in giving the
world good software than getting strokes from your peeps.
The MIT license doesn't prevent you from having an open project no matter
what someone else may do to it. Did FreeBSD disappear when MS used the TCP
stack from it?
> and modify.
So does the MIT license. The difference is the GPL makes sure someone
*else's* code remains free to use and modify.
If I put my own original code under the GPL, it's free to use and modify.
If I put my own original code under the MIT, it's free to use and modify.
If I put my own original code under the GPL, you can modify that, but you
can't hide *your* modifications.
If I put my own original code under the MIT, you can modify that, but you
can hide *your* modifications.
So the GPL does nothing to ensure that open code remains open. All it does
is ensure that if I feel like giving away my code, you can't make a profit
on your own work if it's related to mine.  It also ensures that someone who
needs to make a profit on their software to ensure they can provide the
necessary improvements will be unable to do so.
And the new stuff about forcing even plug-in authors to GPL-license their
code when it isn't a modification of the GPL'ed code is clearly not even
trying to keep you from "taking advantage" of my free code.
   "Ouch ouch ouch!"
Date: 28 Jan 2009 14:22:33
Message: <4980b079$1@news.povray.org>
>> definition are an independent part of the program.
If they need source code from the compiler, then they've copied bits of the
compiler, and they can be GPLed without technological barriers to keeping
them from running based on their license.
Device drivers link into the kernel in Windows, but they're not part of
Windows, either. As soon as you make a well-defined API for plug-ins, you've
specifically separated plug-ins from main line code. Programs that run on
Linux make use of Linux data structures too (see ioctl() for example). That
doesn't mean everything that calls ioctl is GPLed.
While firefox plug-ins might use less of firefox's internals than one might
think, firefox extensions are intimately related to firefox internals
through a well-defined API. I'm not sure why you would think a plug-in
naturally falls under the GPL for GCC and extensions for Firefox don't.
If I can create a plug-in without copying any code supplied by GCC, then the
plug-in doesn't fall under the GPL. If the only technological way to create
a plug-in is to use code that is supplied with GCC, then the plug-in doesn't
fall under the GPL. (For example, in the USA, if the only way to reset a
floppy disk controller is to poke a certain sequence of bytes to its I/O
port, you can't copyright that sequence of bytes.)  If the GPL is viral to
plug-ins, there's no need to add barriers to making non-GPLed plug-ins, is
there?  At least, no more than making technological barriers to modifying
GCC itself.
And where's my freedom to distribute a version of GCC that doesn't check for
a license string in the plug-in?
   "Ouch ouch ouch!"
Date: 28 Jan 2009 14:38:34
Message: <4980b43a$1@news.povray.org>
 > enough resources to make it worth paying money for? ;-)
That's a way of seeing it, yes.  Handing your problems over to a single
entity in exchange of money and freedom.
> source be more likely to disappear than all copies of a GPL-licensed
> source?
Good question!  Let me consult the horoscope...
>> closed products without any acknowledgement (let alone royalties) and
>> pissing and laughing on your grave, you are screwed too.
No one is that altruist, but I'm sure you didn't really mean it.  GPLed
software provides a good framework for *continued* sharing and bettering
of code and that is the main reason why people use it.  Sharing is
important because workload and bug fixing is divided by many interested
parties.  The GPL also ensures that no one will suddenly stop
contributing code for fear that the code is too damn good and could stop
in a commercial leecher product without further notice.
> matter what someone else may do to it. Did FreeBSD disappear when MS
> used the TCP stack from it?
Would open-source unGPLed Linux die if Microsoft and their 99% market
share would canibalize it as a basis for a better product?  You betcha!
>> use and modify.
Someone *else's* code wouldn't exist in the first place without the
original GPLed code.  That's what a modification means.
> does is ensure that if I feel like giving away my code, you can't make a
> profit on your own work if it's related to mine.
The GPL isn't about profits or money, it's about freedom.  AFAIK,
companies make money off of GPLed code and all they need to do is
provide the source for any modifications.
> their code when it isn't a modification of the GPL'ed code is clearly
> not even trying to keep you from "taking advantage" of my free code.
gcc plugins are not flash players.  gcc is doing the heavy work and they
are using it to provide extra useful functionality.  A gcc plugin would
not be a standalone app.
Date: 28 Jan 2009 14:45:34
Message: <4980b5de$1@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:4980a265$1@news.povray.org...
> >> restricting.
> > underlying goal.
restrictions,
Rights of the author who released his code under GPL of course. Only in the
bizzaro world might it make sense to assume GPL would offer protection to
authors who don't (!?) use it.
Date: 28 Jan 2009 14:46:44
Message: <4980b624@news.povray.org>
>>> restricting.
>> underlying goal.
> restrictions, or the one giving away the code with fewer restrictions?
The one who wrote the code that you are modifying and then distributing.
I use pan as my newsreader.  It's licensed under the GPL.
If I modify it for my own use, that's fine.  If I modify it and then
distribute my modifications, I *must* distribute my changes to the code
as well (I believe along with the original code - ie, the complete,
compilable modification chain).
This protects Charles' (the author of pan) rights because he did the core
development on the code that I've modified.  He has the right to decide
how his code is used and under what conditions modified versions of that
code are distributed.  He chose the GPL.
If I want to reuse his code, I have to respect his wishes (and his rights
as the original author) about how it be distributed.
Jim
