POV-Ray : Newsgroups : povray.off-topic : Questionable reasoning Server Time
2 Jul 2026 13:48:00 EDT (-0400)
  Questionable reasoning (Message 21 to 30 of 30)
Subject: Re: Questionable reasoning
Date: 19 Jan 2009 14:37:46
Message: <4974d68a$1@news.povray.org>
Orchid XP v8 wrote:
> I still miss the old days when you could take a filesystem offline to
> defrag it properly... :-(
You mean, back in DOS days, when you couldn't run anything but the defrag
tool while the machine's running? :-)  What's "improper" about the
defragging it does now?
   Why is there a chainsaw in DOOM?
   There aren't any trees on Mars.
Date: 19 Jan 2009 15:05:07
Message: <4974dcf3@news.povray.org>
> defrag tool while the machine's running? :-)  What's "improper" about
> the defragging it does now?
You can't stop users from doing work and look as important anymore? :P
-Aero
Date: 19 Jan 2009 15:46:33
Message: <4974e6a9@news.povray.org>
People can be refragmenting the files as you're trying to defrag them?
(Also this is presumably why every defrag tool known to man fails to
defrag certain parts of the filesystem.)
http://blog.orphi.me.uk/
Date: 19 Jan 2009 16:00:24
Message: <4974e9e8$1@news.povray.org>
Most defragmenters either lock the file while it's being defragged or they
stop defragging if you open the file for writing while they're defragging it.
That's more because bits of the kernel keep physical locations of files in
memory (like swap, or root directory, or whatever).  Also, if you have the
file open for writing (like the registry, say), then it's rough to defrag
while it's being written.  Which is why (for example) the "page file
defragmenter" runs during boot rather than live.
Date: 19 Jan 2009 16:02:19
Message: <4974ea5b$1@news.povray.org>
> in memory (like swap, or root directory, or whatever).  Also, if you
> have the file open for writing (like the registry, say), then it's rough
> to defrag while it's being written.  Which is why (for example) the
> "page file defragmenter" runs during boot rather than live.
Indeed. If you could run a defragger with the filesystem unmounted, you
could move around anything you like.
Still, Windows doesn't seem to support the concept of mounting and
unmounting filesystems at will...
Date: 19 Jan 2009 16:05:13
Message: <4974eb09$1@news.povray.org>
With suffient information about what is where, everything but hardcoded
blocks could be moved around, yes.
Of course it does.  There are just some file systems you can't unmount
because the kernel is using files there.
Date: 19 Jan 2009 16:07:25
Message: <4974eb8d$1@news.povray.org>
Well you can't unmount the second partition on your harddrive, defrag
it, and then remount it (for example).
Of course, under Linux you can mount and unmount things at will - you
just can't defrag anything at all! :-}
Date: 19 Jan 2009 16:15:42
Message: <4974ed7e$1@news.povray.org>
Sure you can. You have to write your own defrag tool, but you can certainly
unmount the second partition, do raw I/O to it, and then remount it[1]. If
you had a defrag tool that would work on an unmounted partition, you could
do this. The one that is built into Windows assumes you want your system
live while doing this, so it deals with it, handling the fact that you're
moving the file transparently to the users.
No you can't. You can't unmount a file system with open files on it under
Linux either.  You can defrag it (or fsck it) while it's mounted, but
that'll just corrupt it, most likely.
[1] For example, try "chkdsk d: /x" from an administrator command line.
Date: 24 Jan 2009 09:32:34
Message: <497b2682$1@news.povray.org>
>> Yeah, I was talking about *algebraic* data type when I said "all
>> Haskell types are ADTs". ;-)
> Sorry. I get them mixed up, since the definitions changed since I
> studied them.
>> I think we're still talking about two different meanings of ADT. ;-)
> Possibly.
So, now do you agree that "all Haskell types are algebraic data types"? ;-)
Date: 24 Jan 2009 12:02:10
Message: <497b4992$1@news.povray.org>
I don't know. I'm thinking not, but perhaps so. I don't know the details of
Haskell well enough, but it's possible, yes.
   "Ouch ouch ouch!"
   "What's wrong? Noodles too hot?"
   "No, I have Chopstick Tunnel Syndrome."
