POV-Ray : Newsgroups : povray.off-topic : Coin game Server Time
22 Jul 2026 09:15:43 EDT (-0400)
  Coin game (Message 10 to 19 of 29)
<<< Previous 9 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Coin game
Date: 8 Jan 2009 11:10:38
Message: <4966257e$1@news.povray.org>
"scott" <sco### [at] scottcom> wrote in message news:4965e43e@news.povray.org...
> Here's an interesting puzzle.
> A game is played by repeatedly tossing a coin until it lands heads.  If it
> lands heads on the first try, you win $1 and the game is over.  If it
lands
> heads on the 2nd try, you win $2 and the game is over.  On the 3rd try $4,
> and in general if you get the head on the nth try, you win $2^(n-1).
> I simulated this game in C++ and after 1e6 goes the average win-per-go
> settles down quite nicely to $8.09 and stays there up to 1e8 goes.  Is
that
> correct?
No. More properly, it's useless. You won't be able to solve this empirically
as such. Most influential outcomes on payoff are least likely, which you
will not ever come across in finite time.
> How much should you be willing to pay for each go?
Infinite. Sum(n,0,inf)( (1/2)^n * 2^(n-1) ) = sum(n,0,inf)(1/2) = inf.
Of course it only makes sense to play if both you and the casino have
infinite time and infinite money.
> Does it depend on how many goes you are going to have?
No, each round of game is independent, is it not?
Date: 8 Jan 2009 11:19:21
Message: <49662789$1@news.povray.org>
>  How did you implement it? What type of integers did you use to count the
> amount of money? (Note that a 32-bit integer will overflow after only 32
> tosses of the coin, which is perfectly within the realm of possibility.)
I used 32bit and then 64bit integers, but the result was the same.
Date: 8 Jan 2009 11:27:37
Message: <49662979$1@news.povray.org>
What if you don't have infinite time?
Yes, but somehow you have to calculate the "realistic" amount that you will
win in finite time, so you can decide how much you are willing to pay for
this game.
If I offered you a go for $2 would you take it? How about $5, $10, $100 ?
There is a stark contrast to these values and the theoretical infinite
average expected winnings.
Date: 8 Jan 2009 11:28:02
Message: <49662992@news.povray.org>
  Did you at least put an assert() to check that no more than 31 (or 63)
tosses were ever made?
Date: 8 Jan 2009 11:47:44
Message: <49662e30@news.povray.org>
news:49662979$1@news.povray.org...
Then we decide on a cutoff.
will
> this game.
Sure, if you tell me exactly what the finite time is.
It's an even game for 4 throws, favours me for higher. You must show me that
you have $8.
> How about $5,
It's an even game for 10 throws, favours me for higher. You must show me
that you have $512.
> $10,
It's an even game for 20 throws, favours me for higher. You must show me
that you have $524,288.
This is on par with typical lotteries. Odds of winning the biggest jackpot
is almost one in a million, with more probable smaller prizes.
> $100 ?
It's an even game for 200 throws, favours me for higher. You must show me
that you have over $8e59.
Even then, I don't think I'd play, as I don't know where I'd put that money
if I win.
The progression on maximum winnings possible might be a clue why.
Date: 8 Jan 2009 11:56:03
Message: <49663023$1@news.povray.org>
> it lands heads on the first try, you win $1 and the game is over.  If it
> lands heads on the 2nd try, you win $2 and the game is over.  On the 3rd
> try $4, and in general if you get the head on the nth try, you win
> $2^(n-1).
> that correct?  How much should you be willing to pay for each go?  Does
The expected payoff is infinite of course.  Personally, I'd pay about
$10 to play the game, which indicates that I'm not attempting to
maximize my expected payoff in making this decision.  The best I can
formalize my reasoning is that the `utility' to me of winning a sum of
money levels off asymptotically as that sum of money decreases.  For
example, as far as I'm concerned there's no difference between winning
$10^20 and $10^30, despite the fact that the latter is a vastly larger sum.
Furthermore, since I have only a very limited amount of money, losing $x
has a higher negative utility than gaining $x -- as indicated by the
fact that I wouldn't play a game with zero expected payoff (unless the
game itself was fun of course).
To properly estimate how much I should pay to play under this view I
should make a guess at my payoff vs. utility curve and then calculate an
expected utility, but that's a bit more effort than I's probably care to
spend were I presented with such a situation, so I'll take the
satisficing approach and just say $10.
Also, I assume that you're familiar with the name of this puzzle, but on
the off chance that you're not:
http://en.wikipedia.org/wiki/St._Petersburg_paradox
Date: 8 Jan 2009 12:10:30
Message: <49663386@news.povray.org>
I tried it myself with the program at the end of this post, and got a
bit different of a result. The program printed:
times tested: 100000000, sum: 1600092924, average: 16.0009
times tested: 200000000, sum: 2952473665, average: 14.7624
times tested: 300000000, sum: 4316535702, average: 14.3885
times tested: 400000000, sum: 6018669380, average: 15.0467
times tested: 500000000, sum: 7585216727, average: 15.1704
times tested: 600000000, sum: 8915924298, average: 14.8599
times tested: 700000000, sum: 10662688388, average: 15.2324
times tested: 800000000, sum: 12027713479, average: 15.0346
times tested: 900000000, sum: 13468996092, average: 14.9656
times tested: 1000000000, sum: 15300481793, average: 15.3005
  The program:
#include "IsaacRand.hh"
#include <iostream>
#include <cassert>
int main()
    typedef unsigned long long ULL;
    IsaacRand rng(0);
    ULL sum = 0;
    std::cout << "sizeof(sum) = " << sizeof(sum) << std::endl;
    ULL counter;
    for(counter = 0; counter < 1000000000ULL; ++counter)
        ULL rounds = 0;
        while(rng.getNext() % 2 == 0)
            ++rounds;
            assert(rounds < 64);
        if(rounds) sum += 1ULL << rounds;
        else ++sum;
        if(counter % 100000000 == 100000000-1)
            std::cout << "times tested: " << counter+1
                      << ", sum: " << sum << ", average: "
                      << double(sum)/double(counter) << std::endl;
Date: 8 Jan 2009 12:59:12
Message: <49663ef0$1@news.povray.org>
> if I win.
I can help with that!
   Why is there a chainsaw in DOOM?
   There aren't any trees on Mars.
Date: 8 Jan 2009 14:08:44
Message: <49664f3c$1@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:49663ef0$1@news.povray.org...
money
> > if I win.
Thanks, but I need help from a couple more people to stash away equivalent
of 40,000 universes' weight of money in 100 dollar bills.
Date: 8 Jan 2009 15:14:22
Message: <49665e9e@news.povray.org>
Btw, this might be of interest:
