![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
scott wrote:
> Can this actually happen though, or does the CPU just shut down before
> it knows it is going to melt?
I once came home to a powered-down Windows machine that had been doing a
render. When I turned it on, I got a pop-up from Windows saying it had been
shut down due to temperature problems. (Poorly-ventilated machine inside a
cabinet.)
I suspect both the OS and MB monitor the heat.
Why is there a chainsaw in DOOM?
There aren't any trees on Mars.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Fri, 09 Jan 2009 11:58:06 +0100, Invisible <voi### [at] dev null> wrote:
> http://vadim.oversigma.com/MAS862/Project.html
> Suggests that the entire body consumes about 100W, and the brain itself
> uses 20 - 40 W. (So... a pretty significant fraction, considering that
> the human body is *not* a data processing device, primarily.) That's how
> much energy it *uses*, I wonder how much of that ends up as heat?
http://www.dilbert.com/fast/2009-01-05/
FE
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible wrote:
> Yes, I *will* buy the same CPU brand as the melted one. You know why?
> The rival brand uses a different socket. :-P
You'd buy that CPU from Acer?
> OTOH, it would probably be both *cheaper* and more beneficial to just
> buy an entire new laptop! ;-)
That's what I ment, they can sell you a new laptop. And if eg. Acer was
fine in other ways but it, hmm, kind of.. melted, you're granted to buy
new Acer. Right?
I just might think about another laptop-brand. I might check Dell or
Lenovo, if my HP melted oslt.
-Aero
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Arttu Voutilainen wrote:
> Ever heard of sauna? ;P
I guess he hasn't. But damn, not only you beat me asking that, but you
also made me think if I should heat one up. Get some nice 70-80C to air
and vaporaze some liters of water to it...
Hmm, naah. It's too warm outside to get best out of it :(.
> -- Arttu Voutilainen
-Aero
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
And they should. The OS can do pretty sophisticated things in such
manner, while estimating the overheat - it can shut down or freeze
processes nicely, it can hibernate or power down nicely etc. The MB...
Well, via ACPI it can tell the OS to do (at least most of) these things
also, but it (also) should be able to cruely cut the power, in case of
OS crashing hard (you know, kernel panic, BSOD etc) and not being able
to do anything nicely.
-Aero
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I am constantly baffled at people who think that buying things from Dell
is a valid thing to do... ;-)
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
We do run them at work, you know. For which brand do you have such an
experience? ;-)
-Aero
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> As an aside, it turns out that on CDMA at least, the list of cell phone
> numbers that should start ringing during this 1.25 time fits in one or two
> packets, and is sorted by phone number, so while you're listening, if you
> hear a higher phone number in the list, you can power down. It turns out
> you have to adjust the sleep timer depending on how many phone numbers you
> listened to, because running the receiver heats up the quartz crystal
> differently depending on how long it runs, so the timer runs at a
> different speed, and you'll miss your wake-up window if you don't. Pretty
> intensely complicated inside there.
Yeh I imagine on a lot of systems that are operating right on the limit of
what's possible there are cool things like this that have to be done.
On a side note, isn't that a pretty bad security design, in that your
handset could (in theory) be able to display a list of all phone numbers
called in your cell? I mean your phone could just store the last few
seconds worth of called-numbers in your cell, and then when you hear your
target's phone ring, trial and error through the short-list for to get their
number.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'll ask.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes. :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
