POV-Ray : Newsgroups : povray.off-topic : REAL random numbers :D Server Time
1 Mar 2026 02:47:48 EST (-0500)
  REAL random numbers :D (Message 1 to 10 of 16)
Subject: REAL random numbers :D
Date: 5 Jan 2009 14:59:37
Message: <496266a9$1@news.povray.org>
http://www.fourmilab.ch/hotbits/
~Mike
Subject: Re: REAL random numbers :D
Date: 5 Jan 2009 16:02:56
Message: <49627580$1@news.povray.org>
I liked better the one that had a camera pointed at half a dozen lava lamps,
and took the sha-1 of the webcam's output to generate random streams. :-)
   Why is there a chainsaw in DOOM?
   There aren't any trees on Mars.
Date: 5 Jan 2009 16:13:58
Message: <49627816$1@news.povray.org>
> lamps, and took the sha-1 of the webcam's output to generate random
> streams. :-)
Depends on how unbreakable you believe SHA-1 to be. (Assuming you wanted
to use the random data for cryptographic purposes anyway. But then,
collectin random data from a public source is probably a dumb idea in
that case...)
http://blog.orphi.me.uk/
Date: 5 Jan 2009 17:09:06
Message: <49628502$1@news.povray.org>
>> streams. :-)
You could certainly take (say) one byte or one bit from the end of the hash.
And breaking SHA-1 still isn't going to give you any non-random results,
unless you find correlations within different parts of the outputs of SHA-1,
rather than the usual search which is correlations between inputs and outputs.
Date: 5 Jan 2009 22:00:30
Message: <4962c94e$1@news.povray.org>
> streams. :-)
	Yes, but at what *rate* can you produce random numbers with that method?
A day without fusion is like a day without sunshine.
                   /  \/  \ u e e n     /  \/  a w a z
                       >>>>>>mue### [at] nawazorg<<<<<<
                                   anl
Date: 5 Jan 2009 22:11:13
Message: <4962cbd1$1@news.povray.org>
>> streams. :-)
It is easily parallelizable. :-)
Date: 6 Jan 2009 08:09:34
Message: <4963580e$1@news.povray.org>
> streams. :-)
I think beta decay is probably a bit more random. After all, there is
that whole uncertainty thing .. :)
~Mike
Date: 6 Jan 2009 13:18:30
Message: <4963a076$1@news.povray.org>
>> streams. :-)
Hard to say.  It's certainly less amusing to watch, and certainly harder to
explain to a layman. :-)
 > After all, there is that whole uncertainty thing .. :)
What do you think drives the randomness of lava lamps? Pixies?
Date: 6 Jan 2009 13:29:07
Message: <4963a2f3$1@news.povray.org>
Fluid Dynamics? Heat?
Oh, hell, just take a shot of the back of the lens cap every so often
(at high ISO), You'll get plenty of quantum randomness there. Or,
amplify an idle input from the sound card to a great extent. More
randomness, there, or a radio tuner tuned to a non-station, and use the
universe as your source of randomness.  Plenty of sources. :)
~Mike
Date: 6 Jan 2009 13:54:42
Message: <4963a8f2$1@news.povray.org>
And ... those in turn are caused by ... ?
Granted, individual atom decay is less likely to exhibit statistical
groupings. And you rarely have your radioactive source get too cold to be
random. :-)
