POV-Ray : Newsgroups : povray.off-topic : Problem of the day Server Time
2 Jul 2026 00:37:23 EDT (-0400)
  Problem of the day (Message 5 to 14 of 34)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Problem of the day
Date: 17 Dec 2008 09:29:22
Message: <49490cc2$1@news.povray.org>
>>> Now, if we perform K trails, the probability of seeing all the balls is
>>> (N! + (K-N)!) / N^N. (Assuming K >= N.)
>> Can you explain how you got that formula?
> Intuitively, assuming N trials the formula is just N! / N^N, so if we add
> (K-N) extra trails, you get the formula above.
> On reflection, I'm not sure that's actually correct...
What if K=5 and N=2? I think the answer should be a 30/32 chance of seeing
both balls, but your formula gives 8/4 !
Date: 17 Dec 2008 09:41:27
Message: <49490f97$1@news.povray.org>
Invisible wrote:
> N is trivially the lower bound.
> Each ball appears with probability 1/N, so the probability for all balls
> to appear (given that these events are clearly independent) in N trials
> would be (1/N)^N, which is 1/(N^N).
> Hmm, but wait! This does not count for ordering. There are N!
> permutations of N events, so taking *that* into account, we now actually
> have N! / N^N.
> Now, if we perform K trails...
Let's try that again...
If we select one ball, the probability of it being ball #1 is 1/N.
If we select K balls, the probability of ball #1 appearing becomes 1/N +
1/N + 1/N + 1/N + ... K times over, minus the probability of ball #1
appearing more than once.
In other words, we have K/N - E, and I can't figure out how to compute E.
(Presumably combinatorics provides a trivial way to solve this. Too bad
I don't know combinatorics, eh?)
Date: 17 Dec 2008 09:52:31
Message: <4949122f$1@news.povray.org>
You can think of it the other way round, ie the probability of ball #1
appearing after K tries is 1 minus the probability of ball #1 not occurring
after K tries.  That is 1-((N-1)/N)^K.
Date: 17 Dec 2008 10:18:38
Message: <4949184e@news.povray.org>
>> + 1/N + 1/N + 1/N + ... K times over, minus the probability of ball #1
> occurring after K tries.
Ah. So instead of a chain of non-exclusive OR events, you construct a
chain of independent AND events? Ingenius...
Date: 17 Dec 2008 10:48:18
Message: <49491f42$1@news.povray.org>
scott wrote:
> If you have a box with N balls numbered 1 to N, and you repeatedly pull
> one out at random (replacing it each time), on average how many times
> would you expect to pull out a ball until you have seen all the balls 1
> to N?
I'm sure the answer is in the back of a textbook somewhere ... :)
~Mike
Date: 17 Dec 2008 12:08:41
Message: <op.umbgj7wlmn4jds@phils.mshome.net>
And lo On Wed, 17 Dec 2008 13:49:38 -0000, scott <sco### [at] scottcom> did
spake thusly:
> to N?
Do a search for Coupon Collector's Problem. For equal random drawings it's
roughly nHn that is n * Sum k=1-n of 1/k multiplied by n
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 17 Dec 2008 12:11:43
Message: <op.umbgppb2mn4jds@phils.mshome.net>
And lo On Wed, 17 Dec 2008 17:08:21 -0000, Phil Cook v2
<phi### [at] nospamrocainfreeservecouk> did spake thusly:
> spake thusly:
>> to N?
> it's roughly nHn that is n * Sum k=1-n of 1/k multiplied by n
Brain death! - n * Sum k=1-n of 1/k
Phil Cook
Date: 17 Dec 2008 12:24:20
Message: <494935c4@news.povray.org>
I have often wondered this, occasionally looked for the answer, and never
really needed to know enough to work it out from first principles.
   The NFL should go international. I'd pay to
   see the Detroit Lions vs the Roman Catholics.
Date: 17 Dec 2008 12:54:07
Message: <j3fik4disa6pkcu0cg2hep649dqq342ecs@4ax.com>
Strange, I've never wondered about it o_O
Regards
Date: 17 Dec 2008 13:24:50
Message: <494943f2@news.povray.org>
  You are thinking it in the wrong way.
  The very first time you select one ball, the probability it's a ball you
have never seen before is 1.
  The second time you select a ball, the probability it's a ball you have
never seen before is (N-1)/N.
  With the third ball, the probability is (N-2)/N. And so on.
