POV-Ray : Newsgroups : povray.off-topic : Problem of the day Server Time
2 Jul 2026 02:21:18 EDT (-0400)
  Problem of the day (Message 25 to 34 of 34)
Subject: Re: Problem of the day
Date: 18 Dec 2008 06:58:16
Message: <heekk45r7l4tjksg7o6c6np5rq1jk9793d@4ax.com>
On Thu, 18 Dec 2008 08:38:40 +0100, "scott" <sco### [at] scottcom> wrote:
>> Strange, I've never wondered about it o_O
>Hehe, the exact problem I was applying it to was that I needed to save all
>the possible images generated by some website, I knew there was a certain
>number of possibilities and that it was random that each one appeared, so I
>just wondered how many times I would need to try before I got all of them.
>I didn't need to know exactly, eg if N=100, am I expecting 150 tries, 200
>tries, 500 tries?  But knowing the exact formula would be cool as it seemed
>an interesting problem without an obvious result.
OK, a real world problem. I don't think that I've come across the need to work
out probabilities in RL.
>Another situation I can think of is if you need to check every item in a
>physical population, but you can only select ones at random (eg tagging fish
>in a lake or something).
There are more things in Heaven and Earth than in my philosophy, Scott. :)
Regards
Date: 18 Dec 2008 07:02:18
Message: <494a3bca@news.povray.org>
*Clearly* you're not a betting man. ;-)
Date: 18 Dec 2008 07:16:45
Message: <uofkk498sd7k2jjut5r91h74rkhua6eb7r@4ax.com>
Not with anything as trivial as money. ;)
Regards
Date: 18 Dec 2008 07:25:36
Message: <494a4140$1@news.povray.org>
Oh I see... You wager with beer, eh?
Date: 18 Dec 2008 07:53:31
Message: <pshkk41c3dfrvgd62fbs461eipfdsn3fvp@4ax.com>
Generally with mars bars.
Regards
Date: 18 Dec 2008 07:55:00
Message: <494a4824$1@news.povray.org>
Eww... beer and mars bars?? o_O
Date: 18 Dec 2008 08:27:39
Message: <jtjkk41p8ftbib0qlad2pk8jbapqpaaiu7@4ax.com>
Dipso :)
Regards
Date: 18 Dec 2008 09:32:53
Message: <494a5f15$1@news.povray.org>
scott wrote:
> If you have a box with N balls numbered 1 to N, and you repeatedly pull
> one out at random (replacing it each time), on average how many times
> would you expect to pull out a ball until you have seen all the balls 1
> to N?
http://xkcd.com/356/
Date: 18 Dec 2008 16:30:56
Message: <494ac110$1@news.povray.org>
>> If we select one ball, the probability of it being ball #1 is 1/N.
>   You are thinking it in the wrong way.
>   The very first time you select one ball, the probability it's a ball you
> have never seen before is 1.
>   The second time you select a ball, the probability it's a ball you have
> never seen before is (N-1)/N.
>   With the third ball, the probability is (N-2)/N. And so on.
It is very likely that, for the third pick of a substantial N balls that
the probability is (N-2)/N. However, if the first two picks happened to
be the same, the probability would still be (N-1)/N.
Example: Lets say 100 balls, labeled 1 to 100. For the first 99 picks,
I've pulled out ball #1. That doesn't mean that, on the 100th draw, I
have (100-99)/100 chance of pulling out a ball I haven't seen. In
(N-K)/N, K needs to account for how many you've seen, not how many
previous picks have been performed. Which means to solve for K on any
draw at N=100, we have to solve this problem of how many picks it would
take for N=99. For N=99, we'd have to solve for N=98. And so on.
I remember this problem from combinatorics, I just don't remember where
my textbook is.
Date: 18 Dec 2008 19:14:24
Message: <494ae760@news.povray.org>
  As I said in my followup post, my suggestion gives the probability of
getting all the unique balls on the first try (iow. N!/(N^N).) It doesn't
tell how many balls you have to take out in average to see them all.
