POV-Ray : Newsgroups : povray.off-topic : Compiling stuff Server Time
15 Oct 2024 11:17:48 EDT (-0400)
  Compiling stuff (Message 1 to 10 of 283)
Subject: Compiling stuff
Date: 8 Dec 2008 08:31:23
Message: <493d21ab$1@news.povray.org>
http://xkcd.com/456/
Mmm... I did this.
Do you have *any idea* how long it takes to compile the Linux kernel? I
mean, damn, how *big* is it?? I thought the final binary was only a few
KB in size...
Oddly, X11 also takes forever.
(It's no surprise however that Firefox and OpenOffice are slow as hell.
Oh, and KDE... *very* slow!)
Damn, I really don't know why the hell I did that...
Subject: Re: Compiling stuff
Date: 8 Dec 2008 08:55:45
Message: <493d2761$1@news.povray.org>
That's funny.  Been there.
> KB in size...
The wait is even more fun the second time around, after you realize you
forgot to configure a necessary driver into your custom kernel. :D
Date: 8 Dec 2008 09:00:28
Message: <493d287c@news.povray.org>
"...I'm too late." ;-)
>> I mean, damn, how *big* is it?? I thought the final binary was only a
>> few KB in size...
I still don't entirely "get" why you would ever recompile the OS kernel.
I mean, all it does is memory allocation, interrupt scheduling, etc.
What's to change?
Also... Gentoo is the only Linux distro I've ever seen where compiling
the kernel was actually successful. Every other distro managed to either
spit cryptic error messages at me, or just leave me with a nonbootable
system.
Date: 8 Dec 2008 10:26:48
Message: <493d3cb8$1@news.povray.org>
> Mmm... I did this.
> KB in size...
Usually 8-10 minutes IME.
-Aero
Date: 8 Dec 2008 10:43:31
Message: <493d40a3@news.povray.org>
>> KB in size...
Exactly. "Normal" programs take less than 4 *seconds* to compile! o_O
Date: 8 Dec 2008 10:45:39
Message: <493d4123@news.povray.org>
Compiling all of KDE using GCC 3 == PAIN
Date: 8 Dec 2008 11:03:29
Message: <493d4551$1@news.povray.org>
>>> KB in size...
#define normal_program;
It depends very much of the scale of the program. OpenOffice takes
couple of hours IIRC.
For comparison:
grunka linux # time emerge povray
-clip-
real    2m0.416s
user    1m15.329s
sys     0m40.495s
POV-Ray, as you surely know, "only" calculates images after all (Unix
version doesn't even have a GUI nor editor). Linux kernel inholds
drivers for most of the hardware you're using (possibly even all of
them), does memory allocating, process handling, networking,
firewalling, RAID-handling, even cryptographic thingies.
-Aero
Date: 8 Dec 2008 11:13:56
Message: <493d47c4$1@news.povray.org>
Indeed yes.
Since even quite "large" programs take only a few seconds to compile,
the Linux kernel must be *huge*...
> OpenOffice takes couple of hours IIRC.
...and OpenOffice must be absolutely gigantic. But then, it's a pretty
complex bit of software, so you'd expect that. The Linux kernel's job
seems quite a bit simpler by comparison.
Ah yes, I'm forgetting: The Linux "kernel" isn't just the OS kernel. How
silly of me...
(It probably contains drivers for every piece of hardware known to
mankind, even if you don't need it. And I'll bet even if you disable
those parts, it still has to process that part of the source code to
decide whether or not to compile it...)
Date: 8 Dec 2008 12:13:46
Message: <493d55ca$1@news.povray.org>
> KB in size...
	8-10 minutes is not that long. I've been running Gentoo for over 5
years on the same machine, so I can tell you how long it took for any
package I've ever compiled via Portage.
GTK+ 2.x takes about 40 minutes
xulrunner (which is the bulk of the Firefox compile): 1 hour.
Thunderbird: 1.5 hours
gimp: 40 minutes
glibc: 1 hour
xorg-server: 25 minutes
	For me, other things take a longer forever.
	KDE need not be slow if you only compile what you want. I stopped using
DE's years ago, so now I only have a few KDE apps installed that I use.
If you think nobody cares, try missing a couple of payments.
                   /  \/  \ u e e n     /  \/  a w a z
                       >>>>>>mue### [at] nawazorg<<<<<<
                                   anl
Date: 8 Dec 2008 12:16:06
Message: <493d5656$1@news.povray.org>
> What's to change?
	When I initially compiled the kernel after installing Gentoo, I had no
DVD drive, and was also short a lot of other hardware. So I turned those
options off. Later on, when I got certain hardware, I needed to enable
those options.
	Lately I've had to connect to work using a PPTP VPN (evil stuff). I
hadn't compiled PPTP support in the kernel. So: Recompile. Another time
I needed to use DAV. Not enabled in kernel - so I compiled.
	I don't do it often - probably 1-3 times a year.
                                   anl
