POV-Ray : Newsgroups : povray.off-topic : GRUB uglies Server Time
16 May 2026 09:57:55 EDT (-0400)
  GRUB uglies (Message 11 to 13 of 13)
Subject: Re: GRUB uglies
Date: 9 Nov 2008 15:27:06
Message: <op.ukdcff1k7bxctx@e6600.bredbandsbolaget.se>
On Sun, 09 Nov 2008 19:00:24 +0100, Darren New <dne### [at] sanrrcom> wrote:
> My stumbling block here is that if I use chroot, I no longer have /dev
> for GRUB to write things to.
You must bind /dev in the new environment before chrooting.
Gentoo users know how to chroot properly, as it is a required step when
installing Gentoo:
http://www.gentoo.org/doc/en/handbook/handbook-amd64.xml?part=1&chap=6
FE
Date: 9 Nov 2008 16:02:34
Message: <49174fea$1@news.povray.org>
> installing Gentoo:
Thanks. I figured it was merely a stumbling block rather than a wall. ;-)
I'll put that into my instructions file under "in case of complete user
screw-up..."
I'm learning way more about system administration than I ever wanted to
know, you know? :-)
Date: 9 Nov 2008 21:52:22
Message: <4917a1e6@news.povray.org>
On Sun, 09 Nov 2008 10:00:24 -0800, Darren New wrote:
> Jim Henderson wrote:
>> Yeah, I would concur with that - have had that experience myself.
> for GRUB to write things to. If it comes to that much of a disaster,
> I'll reinstall stuff and rescue things on a per-file/per-directory
> basis. :-)
I also mount /dev/ in the chrooted environment.
Jim
