POV-Ray : Newsgroups : povray.off-topic : Linux really costs a _lot_ more than $40 Server Time
5 Jul 2026 17:20:43 EDT (-0400)
  Linux really costs a _lot_ more than $40 (Message 181 to 189 of 189)
Subject: Re: Linux really costs a _lot_ more than $40
Date: 1 Dec 2008 14:15:21
Message: <493437c9$1@news.povray.org>
Darren New wrote:
> I find it really hard to believe GCC will compile a program, then read
> the output file to see if the result is the same, and if not, only then
> will unlink the old code and write the new code.
OTOH it could check mtime of the source and the binary and choose the
way to work. But somehow I even that hard to believe.
-Aero
Date: 1 Dec 2008 14:29:33
Message: <49343b1d$1@news.povray.org>
Except it would have to pretty much compile everything anyway, since
environment variables, command line options, and include files can all
affect the results too. And anyway, I changed the file between runs.
   The NFL should go international. I'd pay to
   see the Detroit Lions vs the Roman Catholics.
Date: 1 Dec 2008 18:36:22
Message: <493474f6@news.povray.org>
On Mon, 01 Dec 2008 10:55:03 -0800, Darren New wrote:
> Jim Henderson wrote:
>> That's not what I read in your post.  I duplicated with the code
>> staying the same, but not with it changing.
> I take advantage of X windows, ya see. :-)
It probably looks to see if the source file changed since the last
compilation (not sure how it tracks that).  All I know is that when I
didn't change the code, the inode stayed the same, and when I did, it
didn't.
> I'll give it a try next time I'm in Linux, tho.  I suspect it's more
> some options on the compiler or file system we have set differently or
> something.
Could be.
Jim
Date: 1 Dec 2008 21:57:13
Message: <4934a409$1@news.povray.org>
I find it hard to believe that GCC would be that broken.
Date: 1 Dec 2008 23:20:31
Message: <4934b78f$1@news.povray.org>
<shrug>  I'm just goin' by my observation.....if you've got a better
explanation, I'm all ears.
Or maybe that's "eyes". ;-)
Jim
Date: 2 Dec 2008 14:30:49
Message: <49358ce9@news.povray.org>
Dunno. Like I said, it may be the compiler version or something. Now, if
you're talking Java, I could understand this, because the Java equivalent of
#include looks at .class files to see if something needs to be recompiled.
I.e., "make" is sort of built in to Java compilers.
darren@dog:~/test> gcc -v
Using built-in specs.
Target: x86_64-suse-linux
Configured with: ../configure --prefix=/usr --with-local-prefix=/usr/local
--infodir=/usr/share/info --mandir=/usr/share/man --libdir=/usr/lib64
--libexecdir=/usr/lib64
--enable-languages=c,c++,objc,fortran,obj-c++,java,ada
--enable-checking=release --with-gxx-include-dir=/usr/include/c++/4.3
--enable-ssp --disable-libssp --with-bugurl=http://bugs.opensuse.org/
--with-pkgversion='SUSE Linux' --disable-libgcj --with-slibdir=/lib64
--with-system-zlib --enable-__cxa_atexit --enable-libstdcxx-allocator=new
--disable-libstdcxx-pch --program-suffix=-4.3
--enable-version-specific-runtime-libs --enable-linux-futex
--without-system-libunwind --with-cpu=generic --build=x86_64-suse-linux
Thread model: posix
gcc version 4.3.1 20080507 (prerelease) [gcc-4_3-branch revision 135036]
(SUSE Linux)
darren@dog:~/test> ls -l
total 28
-rw-r--r-- 1 darren users 67 2008-12-02 10:25 a.c
-rw-r--r-- 1 darren users 67 2008-12-02 10:26 b.c
-rw-r--r-- 1 darren users 22 2008-12-02 11:07 c.c
-rw-r--r-- 1 darren users 22 2008-12-02 10:25 d.c
darren@dog:~/test> cat a.c
#include "c.c"
int main() { write(1, "Hello " XYZ, 12); return 0;}
darren@dog:~/test> cat b.c
#include "c.c"
int main() { write(1, "Zing! " XYZ, 12); return 0;}
darren@dog:~/test> cat c.c
#define XYZ "World\n"
darren@dog:~/test> cat d.c
#define XYZ "xyzzy\n"
darren@dog:~/test> gcc a.c ; ls -li a.out ; ./a.out
1818787 -rwxr-xr-x 1 darren users 11120 2008-12-02 11:07 a.out
Hello World
darren@dog:~/test> gcc b.c ; ls -li a.out ; ./a.out
Zing! World
darren@dog:~/test> cat d.c >c.c
1818787 -rwxr-xr-x 1 darren users 11120 2008-12-02 11:08 a.out
Hello xyzzy
Zing! xyzzy
darren@dog:~/test> cat a.c >b.c
Hello xyzzy
darren@dog:~/test>
Nothing I did changed the inode number of a.out, in spite of getting
different output every time I ran it.
Date: 2 Dec 2008 15:03:07
Message: <4935947b$1@news.povray.org>
> equivalent of #include looks at .class files to see if something needs
> to be recompiled. I.e., "make" is sort of built in to Java compilers.
Might be.  What filesystem are you using?  Maybe it's a question of the
inode allocation system, number of free inodes and the like?
Jim
Date: 2 Dec 2008 15:17:52
Message: <493597f0$1@news.povray.org>
ext3. I don't think that's it. If I delete the a.out and run gcc again, I
get a different inode number.
Date: 2 Dec 2008 16:27:33
Message: <4935a845$1@news.povray.org>
> I get a different inode number.
Interesting; I also am running ext3 here....
Jim
