POV-Ray : Newsgroups : povray.off-topic : Linux really costs a _lot_ more than $40 Server Time
5 Jul 2026 13:51:43 EDT (-0400)
  Linux really costs a _lot_ more than $40 (Message 161 to 170 of 189)
Subject: Re: Linux really costs a _lot_ more than $40
Date: 25 Nov 2008 13:46:09
Message: <492c47f1$1@news.povray.org>
On Sun, 23 Nov 2008 22:57:32 -0800, Darren New wrote:
> Jim Henderson wrote:
>> Well, sure, but dealing with every possible and conceivable exception
>> gets into areas where even in professional development it's decided not
>> to go.
> No, I  mean you can make it generic. Instead of looking at each of the
> 30+ possible causes of error, you can say "Any error rolls back the
> changes."
So like "an error occurs, let's ask the user what should happen"?  Which
is what it does. :-)
>> Well, yeah, that would fall under the category of "handling the
>> exception", no? ;-)
> Not really. It's correcting an error you detected. If the error
> correction step also fails, you're pretty screwed.
That would likely happen with a disk full error - if you can't commit one
transaction, it's going to be hard to verify and write out the old state
as well, no?
> For example, to make things work, you need to up date the executable and
> three dynamic libraries. You update the executable, and one of the
> libraries, and then your network connection to the machine hosting the
> files fails. You can't handle that exception by rolling back your
> changes manually.
You can by reinstalling the package, though.
>> Sure, and as I said, I've had that happen to me - didn't need to
>> reinstall the system, had to clean a few things up, but this sort of
>> thing can happen with any OS, not just Linux.  Ever try writing to the
>> Windows registry with C: full?  (I knew you were waiting for me to
>> bring Windows into the discussion - there you go. ;-) )
> Well, yes. That's why you have file system transactions in Windows.
> That's kinda exactly my point. If you start a kernel transaction, copy
> some files, update the registry, then bomb out, your changes get rolled
> back automatically. Just like any other database system, and regardless
> of why you bombed out or over which network the files are mounted.
And on Linux you have ext3, reiser, jfs, and other journaling filesystems.
>> So you need to run a validation - but again as I've said a few times,
>> my experience has been that an *error* condition like you describe
>> stops the upgrade process, it doesn't silently say "well, that's OK"
>> and continue without notifying the user.
> Unless the error is "you pulled the plug" or "the RAID fell over" or
> something like that.
If RAID falls over, I'd say you've got a more serious problem on your
hands....I've had that happen a few times, and it generally leads to a
system reinstall.
>> "in spite of failures" - huh?  Update a system by writing files that
>> cannot be written because of a full disk (say) even though the disk is
>> full?
> No. Not having half-written files caused by the disk being full. Or
> having only (say) two out of file files updated because the disk got
> full while you were writing the third file.
Sure, and that's what package validation is for - but again it becomes
moot because when the SUSE updater tries to update a file and can't
because the disk is full, you get a big really obvious dialogue box that
says "hey, we're out of disk space, what do you want to do?" - so you can
clear up some disk space and say "try again".
Jim
Date: 25 Nov 2008 15:33:25
Message: <492c6115$1@news.povray.org>
>> changes."
Uh, no. That's kind of my point. You can set things up such that it
works *JUST LIKE* a database transaction. Something fails in the middle,
and the system automatically puts things back to the way they were.
> as well, no?
No. Just like a real database system, things don't get updated
permanently until you're sure it'll work.
>> changes manually.
Only after you get your network connection back. Until then, everyone
using the machine locally is screwed.
Cool. What's the system call in Linux that lets me change three files
consistemtly?  I.e., I have files /tmp/One, /tmp/Two, and /tmp/Three,
and I want to rename them respectively to /tmp/1, /tmp/2, and /tmp/3,
and I never want any possibility of an "ls" operation on the /tmp/
directory to show my /tmp/One and /tmp/3 at the same time, or /tmp/1 and
/tmp/Three.  Is there some way to accomplish that?
> system reinstall.
And you've never lost power either, I take it?
Except that's a manual post-hoc fix that only works for package
installs. I'm talking about something that works without intervention on
a more generic kind of problem.
Date: 25 Nov 2008 15:33:55
Message: <492c6133$1@news.povray.org>
> I use it quite a bit.  A recompile of a library generates a new file, it
> doesn't modify an existing library
Did you try it?  It certainly reuses the same file for me.
Date: 25 Nov 2008 15:55:30
Message: <492c6642@news.povray.org>
>> it doesn't modify an existing library
Logically it doesn't make sense - since offsets change in a library and
so on when compiling code.....
And in my test, no, it didn't use the same inode for different
compilations of the same C file.
Jim
Date: 25 Nov 2008 15:59:57
Message: <492c674d$1@news.povray.org>
>>> changes."
>> Which is what it does. :-)
I prefer that the system let me know about an error condition so I can
correct the underlying issue, when it comes to things like filesystem
errors.
>> one transaction, it's going to be hard to verify and write out the old
>> state as well, no?
A silent failure wouldn't be useful - no indication of success or failure
would be even more confusing, IMO.
>>> and three dynamic libraries. You update the executable, and one of the
>>> changes manually.
A good case to be made for doing updates on the local machine rather than
the remote machine.  Like I said, management procedures in place for non-
standard deployments.
>>> rolled back automatically. Just like any other database system, and
>>> regardless of why you bombed out or over which network the files are
>>> mounted.
>> filesystems.
Again, if it's handled as part of the system update, the updater takes
care of that for you, not the system.
>> system reinstall.
Got a system here with a bad power supply, as a matter of fact - and yes,
it screwed a VMDK file that was open at the time.
You want to implement a filesystem as a database, knock yourself
out. ;-)  It's overkill for most applications.
Jim
Date: 25 Nov 2008 20:28:50
Message: <492ca652$1@news.povray.org>
> errors.
Of course you find out about the error. I'd just prefer the system to not
corrupt the file system when something fails.
What makes you think it would be silent??
I take it you've never used a database that has transactions. What happens
is you get back a message saying "your transaction failed because the disk
was full" (or whatever the reason), and you don't have to do anything to put
your changes back to how they were before you started. So if you say (for
example) "delete all the .doc files from this directory", and one of them
isn't deletable, none of them get deleted, and you're told which one can't
be deleted.
Right. That's what I'm saying.  Management procedures to work around the
lack of functionality.
That didn't answer the question.  How does the updater make sure that you
never see a half-renamed collection of files, even assuming we're only
talking about the updater here?
Not really. ext3 and reiser and all that are already implemented with
transactions. You just can't get to them.
Date: 25 Nov 2008 20:30:33
Message: <492ca6b9@news.povray.org>
I haven't the slightest idea why that would have anything to do with the
file-system level of whether you delete the file before you recreate it or not?
There's good reasons *not* to do that too, like not messing up permissions
and symlinks.
So you ran
   gcc xyz.c
   ls -i a.out
   gcc xyz.c
   ls -i a.out
and you got two different inodes for a.out?
Date: 26 Nov 2008 00:18:19
Message: <492cdc1b$1@news.povray.org>
> or not?
> permissions and symlinks.
> So you ran
>    gcc xyz.c
>    ls -i a.out
>    gcc xyz.c
>    ls -i a.out
Modified the code inbetween.  If the compiled code doesn't change, then
the point's moot - you'd be building the same library and there'd be no
difference, so who cares if it gets overwritten or not?
Jim
Date: 26 Nov 2008 01:16:20
Message: <492ce9b4$1@news.povray.org>
I'm not sure that answered the question, tho.  I get the same inode for both
a.outs.  Anyway, you care if the code gets overwritten because if it's
already running (and it has a shared text segment) you can't overwrite it,
and if it's not already running, you can't start it when it's being written.
Date: 26 Nov 2008 13:13:33
Message: <492d91cd$1@news.povray.org>
> both a.outs.  Anyway, you care if the code gets overwritten because if
> it's already running (and it has a shared text segment) you can't
> overwrite it, and if it's not already running, you can't start it when
> it's being written.
Your point is that updating a file while it's open and has a shared text
segment would cause a problem.  My point is that if you're *updating* the
file, the inode changes *unless* the file is being overwritten by an
unmodified version of that file (and that's probably not likely to happen
often), so if the file doesn't get updated with an identical copy of
itself, big deal.  The file is as it should be regardless of whether it
gets overwritten with an identical copy if its previous version or not.
The SUSE updater, though, applies patches, so only files that have
changed would get updated.......so again, not seeing what the problem is
here.
Jim
