POV-Ray : Newsgroups : povray.off-topic : Linux really costs a _lot_ more than $40 Server Time
4 Jul 2026 17:32:13 EDT (-0400)
  Linux really costs a _lot_ more than $40 (Message 150 to 159 of 189)
Subject: Re: Linux really costs a _lot_ more than $40
Date: 23 Nov 2008 00:03:38
Message: <4928e42a$1@news.povray.org>
On Sat, 22 Nov 2008 09:46:38 -0800, Darren New wrote:
> Jim Henderson wrote:
>> why would you not be able to update it consistently?
> You write the .h file. While trying to write the .so file, you A) don't
> have permissions to do so,
The updater requires root rights to run, so it has permissions to do that.
> B) find that it's open by someone else as a shared text segment,
I don't believe that would matter, again, it's the inode that's open, and
when the file is overwritten a new inode is created and the old one is
destroyed.
> C) run out of disk space,
That would create other problems as well - as would running out of system
filehandles (which is interesting to watch on *nix systems - I wrote a
program to malloc() all the memory in a system once when in college - was
to get students off of workstations when they were playing the local MUD
if there were students who had actual work to do and there were no
machines available.  Once the malloc() program ran they couldn't even run
ps to find out what happened - just had to stop-A the system and reboot.
Interesting to watch on the Sun SLC Diskless workstations, because they'd
swap over the network to the server in the server room - which is
invariably where we ran it from, so we could see all the disk activity.
> D) have your process killed,
> E) have the power fail,
Yeah, those could happen and could introduce problems - so you just
reinstall the packages and that makes things consistent.  Come to think,
I've had to do that once or twice.
Jim
Date: 23 Nov 2008 00:42:10
Message: <4928ed32@news.povray.org>
Not always. See network-mounted file systems, file systems mounted
read-only, write-protect tabs, etc.
You're mistaken.
> destroyed.
Only if you unlink the old file then creat() a new one.  If you actually
open the current file for writing (and it's executing or sticky in swap,
and it has a shared text segment), you get an error, even as root.
Yes? So?  We know it's bad and you should avoid it, yes.
Note that nobody expects "I ran out of disk space" (or "I ran out of
file handles or swap space") to result in their root directory getting
truncated, for example. So it's not so bad that it should leave other
parts of your system in an inconsistent state.
I also left out "Linux out-of-memory killer randomly decided to nuke my
process because someone else grabbed a bunch of memory."
And until you do, things are broken. Which is kind of my point.
It's also not an orthogonal solution. Everyone has to reinvent the wheel
for themselves when trying to update multiple files consistently.
And if the package manager updates the database *before* it updates the
files, you might never know it.
Date: 23 Nov 2008 14:50:11
Message: <4929b3f3@news.povray.org>
>>> don't have permissions to do so,
>> that.
You'd have to configure things pretty weird to get part of the relevant
filesystems mounted in a way that was inconsistent with the requirements
- such as being able to update development header files but not shared
libraries.  You'd almost have to be trying to create a situation where
the updater doesn't work - and sure, you could do that, but what would be
the point other than to break things?
> You're mistaken.
Well, it's something I've never run into, and I've only been running
Linux for about 12 years...
>> again, it's the inode that's open, and when the file is overwritten a
>> new inode is created and the old one is destroyed.
Well, the installer does just that - it unlinks and creates new files,
near as I can tell.  But even in a case like that, the updater will error
and say that a file it needs to access can't be updated, and it will give
you the option of aborting or attempting to continue - same kind of error
message when it tries to auto-refresh after making a network change
(which I think is stupid, because it takes the network connection down
and ALWAYS errors once).
My point is that you would notice this probably before running out of
disk space.  Thinking about it, though, I have run into this before, and
the integrity didn't get messed up.
If you never know it, though, then things are working as expected - if
they're not, you can run a comparison of the database to the filesystem
using the RPM options to do so.
Jim
Date: 23 Nov 2008 15:07:36
Message: <4929b808@news.povray.org>
> destroyed.
Uh, it's not. Depends on your definition of "overwritten".
Open an existing file (inode), write into it. Did the inode change?
Date: 23 Nov 2008 15:19:26
Message: <4929bace$1@news.povray.org>
Sure.  However, you're looking at it from the narrow context of one
particular program under Linux.  Being able to deal with such problems
in a generic way is a benefit.
>> You're mistaken.
http://www.derkeiler.com/Mailing-Lists/FreeBSD-Security/2002-07/10992.html
It's not really common, unless you're trying to update executables while
they're running. It's not hard to make it happen. We've been over that
here, a few weeks ago.
> near as I can tell.
Most likely. Probably because (d'oh) you can't write to a file that's
being executed, yes? ;-)
> disk space.
Unless the update is what runs you out of space, or (just maybe) there's
more than one person using the computer, like? Or some background job
that's maybe doing something like receiving email?
And if "as expected" means "still has the security holes in it that the
update was supposed to patch", then yes, that's as expected. Not what
you want, but as expected. :-)
But yes, if you're only talking about package management per se (which
is indeed where we started) then there are obviously solutions in place.
It's just a shame they didn't generalize it so you can make it work for
other people too, or over the network, or in spite of failures, etc.
Date: 23 Nov 2008 16:10:16
Message: <4929c6b8@news.povray.org>
>> requirements
Well, sure, but dealing with every possible and conceivable exception
gets into areas where even in professional development it's decided not
to go.  It's good to deal with common exceptions, but more obscure and
unlikely possiblities aren't any more likely to be dealt with in OSS
development than in commercial software development.
About the only place I've ever seen 100% exception handling expected is
in ACM programming contests.
>>> You're mistaken.
FreeBSD != Linux, but you knew that already. ;-)
And in such a case IME the updater errors and tells you there was a
problem.
>> near as I can tell.
Well, yeah, that would fall under the category of "handling the
exception", no? ;-)
>> disk space.
Sure, and as I said, I've had that happen to me - didn't need to
reinstall the system, had to clean a few things up, but this sort of
thing can happen with any OS, not just Linux.  Ever try writing to the
Windows registry with C: full?  (I knew you were waiting for me to bring
Windows into the discussion - there you go. ;-) )
>>> the files, you might never know it.
So you need to run a validation - but again as I've said a few times, my
experience has been that an *error* condition like you describe stops the
upgrade process, it doesn't silently say "well, that's OK" and continue
without notifying the user.
"or over the network" - yeah, that works, but you have to follow special
procedures.  Anyone who sets a system up with remote /usr or /var
partitions knows that - or should know that.
"in spite of failures" - huh?  Update a system by writing files that
cannot be written because of a full disk (say) even though the disk is
full?  I'm not quite sure how you'd achieve the feat of writing to a full
disk without causing corruption.  But again, that's why the updater
displays an error message rather than silently failing. :-)
Jim
Date: 23 Nov 2008 16:11:09
Message: <4929c6ed$1@news.povray.org>
>> and when the file is overwritten a new inode is created and the old one
>> is destroyed.
That's not the situation we're talking about - we're talking about
replacing something like a shared library - I've *never* seen shared
libraries updated by opening them and writing a change into them, then
saving them out again.
Jim
Date: 24 Nov 2008 01:57:31
Message: <492a505b$1@news.povray.org>
> to go.
No, I  mean you can make it generic. Instead of looking at each of the
30+ possible causes of error, you can say "Any error rolls back the
changes."
You don't write a database transaction and say "What if the power fails?
What if the process is killed? What if I run out of space? What if ...?"
Instead, you just build a transaction, and if anything fails, you roll
back the transaction.
That's what I'm talking about. Then you don't have to build things like
"check the package database against the file system to make sure it's
consistent."
Except this error has been out there since UNIX v7 at least. But you
knew that already.
> exception", no? ;-)
Not really. It's correcting an error you detected. If the error
correction step also fails, you're pretty screwed.
For example, to make things work, you need to up date the executable and
three dynamic libraries. You update the executable, and one of the
libraries, and then your network connection to the machine hosting the
files fails. You can't handle that exception by rolling back your
changes manually.
Well, yes. That's why you have file system transactions in Windows.
That's kinda exactly my point. If you start a kernel transaction, copy
some files, update the registry, then bomb out, your changes get rolled
back automatically. Just like any other database system, and regardless
of why you bombed out or over which network the files are mounted.
Unless the error is "you pulled the plug" or "the RAID fell over" or
something like that.
> full?
No. Not having half-written files caused by the disk being full. Or
having only (say) two out of file files updated because the disk got
full while you were writing the third file.
Date: 24 Nov 2008 02:02:09
Message: <492a5171$1@news.povray.org>
> changes manually.
By which I mean, you can't handle that exception by writing code to
inspect errno and automatically undoing the changes you made. Of course
you can handle it "manually" as in a human intervening.
Date: 24 Nov 2008 02:15:00
Message: <492a5474$1@news.povray.org>
So, you haven't used gcc much, then? :-)
