POV-Ray : Newsgroups : povray.off-topic : A silly little toy (~200 kb) Server Time
27 Jun 2026 18:13:48 EDT (-0400)
  A silly little toy (~200 kb) (Message 18 to 27 of 27)
Subject: Re: Build #86 (user-defined functions)
Date: 16 Oct 2008 18:49:46
Message: <48f7c50a@news.povray.org>
Invisible wrote:
> - Fixed a very evil bug where calling functions with certain variable
> names as arguments would cause bizare malfunctions. (Basically the
> variable names used inside the function clashing with the arguments
> passed in. This *should* be fixed now...)
And you wondered why Lisp has that funky "gensym" function.
Date: 17 Oct 2008 04:07:00
Message: <48f847a4$1@news.povray.org>
What is "gensym", and why does Lisp have it?
Date: 17 Oct 2008 12:09:40
Message: <48f8b8c4@news.povray.org>
It creates a guaranteed-unique variable name that you can use as a local
in a macro or a dynamically-scoped function.   What did you *think* it
might be for, given the bit I quoted and the name of the LISP function?
Date: 17 Oct 2008 13:14:44
Message: <48f8c804@news.povray.org>
Mmm, OK.
This isn't hard to do in Haskell - it's just that you have to remember
to do it! (And more subtly, do it at the correct moment.)
http://blog.orphi.me.uk/
Date: 17 Oct 2008 13:34:41
Message: <48f8ccb1$1@news.povray.org>
Yep. Of course, in LISP, you do this all the time. When you're good at
it, about 30% of your code winds up being code-generating macros. So
figuring out where gensym goes is like figuring out whether you need
global or stack-based variables in a block-structured language. You just
crash and burn if you don't learn it.
Date: 17 Oct 2008 13:47:08
Message: <48f8cf9c@news.povray.org>
Heh. Crazy language... I thought computer science experts concluded,
like, 30 years ago that self-modifying code is actually an Extremely Bad
Idea? (Originally of course everybody thought it was "cool"...)
Date: 17 Oct 2008 13:52:44
Message: <48f8d0ec@news.povray.org>
  Code generation is not the same thing as self-modifying code.
Date: 17 Oct 2008 14:12:58
Message: <48f8d5aa$1@news.povray.org>
It's only "self-modifying code" if you modify it after it has already
been run.
Computer scientists quite like code-generating macros. They have some
pretty sophisticated ones, called "compilers".
Date: 20 Oct 2008 04:06:22
Message: <48fc3bfe@news.povray.org>
> been run.
Well, technically that's true. But Lisp macros run at runtime, not
compile time, so technically you could run the same macro twice and have
it generate different code each time...
Yeah. And as I understand it, writing one is supposedly the hardest task
in all of Computer Science. :-P
Sounds like writing one as part of your application is an excellent idea...
Date: 20 Oct 2008 11:16:01
Message: <48fca0b1$1@news.povray.org>
>> been run.
But the macro still doesn't modify the code after that code is run, so
that's OK. Having the same macro generate different code at different
places is the point of a macro.
Certainly it used to be before the theories were worked out. Writing one
that generates anything close to optimal code is difficult given the
complexity of current chips.
Yep. ;-)
