POV-Ray : Newsgroups : povray.off-topic : Have I missed something? Server Time
3 Apr 2026 01:18:55 EDT (-0400)
  Have I missed something? (Message 20 to 29 of 39)
Subject: Re: Have I missed something?
Date: 11 Oct 2008 11:07:04
Message: <48f0c118$1@news.povray.org>
>> As I understand it, it's sorta-kinda like the Java virtual machine +
>> library assemblage, except explicitly designed to support multiple
>> source-level languages instead of just one.
> And do you know which source languages talk to it?
Off the top of my head... C#, F#, some Java derivative (J#?), and
there's a variant of VB for it.
>> (It wasn't easy to find this information, mind you...)
> "The Microsoft .NET Framework is a software technology that is available
> with several Microsoft Windows operating systems. It includes a large
> library of pre-coded solutions to common programming problems and a
> virtual machine that manages the execution of programs written
> specifically for the framework. The .NET Framework is a key Microsoft
> offering and is intended to be used by most new applications created for
> the Windows platform.
> The pre-coded solutions that form the framework's Base Class Library
> cover a large range of programming needs in a number of areas, including
> user interface, data access, database connectivity, cryptography, web
> application development, numeric algorithms, and network communications.
> The class library is used by programmers, who combine it with their own
> code to produce applications.
> Programs written for the .NET Framework execute in a software
> environment that manages the program's runtime requirements. Also part
> of the .NET Framework, this runtime environment is known as the Common
> Language Runtime (CLR). The CLR provides the appearance of an
> application virtual machine so that programmers need not consider the
> capabilities of the specific CPU that will execute the program. The CLR
> also provides other important services such as security, memory
> management, and exception handling. The class library and the CLR
> together compose the .NET Framework."
That seems slightly clearer than last time I looked. Last time I
researched this matter, I found endless pages telling me how awesome
.NET is and why I should immediately use it, but I couldn't find
anything (from Microsoft or Wikipedia) that explains precisely what it *is*.
http://blog.orphi.me.uk/
Date: 11 Oct 2008 11:08:48
Message: <48f0c180$1@news.povray.org>
Gail wrote:
> Ever seen anything written in C#?
Nope.
> VB.NET?
Not knowingly.
> Ever seen any website with .aspx pages?
Ah. *That* I have seen.
(I thought ASP was some kind of scripting language. I didn't realise it
had anything to do with .NET.)
>> Maybe .NET code is just less "visible" somehow?
> .Net isn't a language.
Well true, but even so, you don't often hear somebody say "hey, I'm
working on this thing written in C#..."
Date: 11 Oct 2008 11:20:13
Message: <48f0c42d@news.povray.org>
"Orchid XP v8" <voi### [at] devnull> wrote in message
news:48f0c180$1@news.povray.org...
> Nope.
The job market in the UK must be very different it both here and US.
Probably close to half of the programming jobs I see these days ask for C#.
Thing with .net is that if you're working on a machines that has the .net
framework installed (and I believe everything past XP does by default), you
won't know that you're running a .net app. It's not like Java where you can
see the VM running in task manager (or sometimes have a popup in the task
bar). That's how it's supposed to be. It's supposed to be seamless and to
not bother the end user with anything they don't need to know.
I know your machine has .net on because we've had conversations before on
free C# compilers and I recall you finding the framework folder.
It's a server-side dynamic page setup like php. It uses the .net framework
on the server. .aspx pages are asp.net, pages with just the .asp extension
are the older-style asp (active server pages)
ASP.NET pages are written in one of the .net languages, most commonly C# or
VB)
Most of the developers I know personally work in C#. I'd put it up with
Java, php, perl and C++ for popularity and usage, and that's not just
hobbyist.
It's far more used than VB or delphi. (and most VB these days is VB.NET
anyway)
Date: 11 Oct 2008 12:19:35
Message: <48f0d217@news.povray.org>
news:48f0bcf5$1@news.povray.org...
> (I've also seen people talk about Java and various other languages, but
> nobody seems to ever talk about .NET. That, however, might just be a
> result of the people I happen to listen to...)
I often get the impression that you are indeed mixing with the wrong crowd.
Date: 11 Oct 2008 12:27:53
Message: <48f0d409@news.povray.org>
I hang out here don't I? :-P
Only kidding guys! ;-)
...guys? Uh, no really, I was joking!... guys? o_O
Date: 11 Oct 2008 12:45:36
Message: <10m1f4d90p5fb5favqtdiq17or5fvqk6u0@4ax.com>
On Sat, 11 Oct 2008 17:25:31 +0200, "Gail" <gail (at) sql in the wild (dot) co
Probably not I just ran a search on jobserve for "programming c# england" and
got 117 hits for the last 7 days. "programming c++ England" gave 59 and
"programming +haskell England" gave none.
Heigh! Ho!
Regards
Date: 11 Oct 2008 14:15:00
Message: <web.48f0ec74ed0500cec097d90b0@news.povray.org>
Yes.  Join us... *voice from Evil Dead*
Date: 11 Oct 2008 14:15:01
Message: <web.48f0ec8eed0500cec097d90b0@news.povray.org>
> news:48efacfa$1@news.povray.org...
> > Today somebody posted a message anouncing an alpha release of a Haskell to
> > .NET bridge. Somebody reponded with "wow, great work! This could be a real
> > game changer."
> > I can't help but feel I've missed something important here...
> > Since when is .NET actually important? AFAIK, absolutely nobody on Earth
> > actually uses it for any purpose whatsoever. So... why would having a
> > bridge to it be of any signifigance? What am I not seeing here??
> Hasn't Simon Peyton Jones has been working for MS?
> http://www.dotnetrocks.com/default.aspx?showNum=310
Hasn't everyone been working for MS?
Date: 11 Oct 2008 15:06:23
Message: <48f0f92f@news.povray.org>
Most of the jobs I've seen can be roughly classified thus:
- We program toasters (so we want C).
- We write "serious" applications (so we want C or maybe C++).
- We write "custom business applications" (so we want VB / VBA or maybe
Java).
- We write web applications, so we want JavaScript / Perl / PHP.
> .net framework installed (and I believe everything past XP does by
> default), you won't know that you're running a .net app. It's not like
> Java where you can see the VM running in task manager (or sometimes have
> a popup in the task bar). That's how it's supposed to be. It's supposed
> to be seamless and to not bother the end user with anything they don't
> need to know.
"Everything past XP" meaning "only the latest bleeding edge OS that
nobody is using yet"?
Anyway, I know that the .NET framework is an absolutely *huge* download
and it takes hours to install. I know this because we have _one_ obscure
application at work which demands .NET 1.1 be installed. This takes many
times longer than installing the application itself. (Roughly 45 minutes
or so of HD thrashing.)
> on free C# compilers and I recall you finding the framework folder.
I don't recall that conversation, but anyway... my PC has never had it
until now. (It has it *now* because I just installed MS Visual Studio,
and the first thing it does is install this unwanted component.)
>> it had anything to do with .NET.)
> framework on the server. .aspx pages are asp.net, pages with just the
> .asp extension are the older-style asp (active server pages)
> or VB)
Well aren't you a mine of information? :-D
> hobbyist.
> anyway)
Isn't Delphi also long since dead? I haven't even heard its name
mentioned in years...
Date: 11 Oct 2008 15:20:00
Message: <web.48f0fbe4ed0500cec097d90b0@news.povray.org>
Orchid XP v8 <voi### [at] devnull> wrote:
> > anyway)
Delphi is alive because old apps written in it still need support.  But, yes,
ever since Microsoft grabbed *the* Delphi team to work on .NET, Borland the
company has been slowly dying a painful death, like most companies screwed by
Microsoft practices.
But hey, they are a great company with great products and consumers are just
happy, as long as all the dirt is underneath the carpet and out of view.
