POV-Ray : Newsgroups : povray.off-topic : C++ questions Server Time
24 Jun 2026 15:33:54 EDT (-0400)
  C++ questions (Message 81 to 90 of 123)
Subject: Re: C++ questions
Date: 27 Sep 2008 05:00:12
Message: <48ddf61c@news.povray.org>
Orchid XP v8 <voi### [at] devnull> wrote:
> Now, however, all the programs I can think of that I'd like to write all
> involve constructing dynamic data structures
  What kind of data structures? Are they something which you can't do with
the STL data containers? If you have any questions about using those
containers, just ask.
Date: 27 Sep 2008 05:12:13
Message: <48ddf8ed$1@news.povray.org>
I was thinking maybe I'd try implementing a Huffman coder. I need a
binary tree for that. Does STL happen to have one already? (That would
obviously be the simplest thing...)
http://blog.orphi.me.uk/
Date: 27 Sep 2008 05:16:52
Message: <48ddfa03@news.povray.org>
  That sounds like a bit advanced... :)
> I need a
  std::set (as well as std::map) is internally implemented as a balanced
binary tree, but if I'm not mistaken, a Huffman coder requires an
unbalanced one, so it may be unusable for that purpose.
  But yeah, if you need to create your own dynamic data containers, it
inevitably means you will have to deal with pointers, 'new' and explicit
memory management. (Although using smart pointers may by possible in
this situation.)
Date: 27 Sep 2008 05:23:18
Message: <48ddfb86$1@news.povray.org>
All my programs are! ;-)
>> I need a
> this situation.)
Actually, thinking about it... I don't "really" need the tree, all I
need is the tree addresses. I could represent each "tree" as just a
vector of symbol/codeword pairs, and "join trees" by frobbing the
codewords and joining the vectors.
Oh, er... can you have a vector of vectors? Or would it have to be a
vector of vector pointers?
Date: 27 Sep 2008 06:20:17
Message: <48de08e1@news.povray.org>
  It's perfectly possible.
std::vector< std::vector<int> > vecvec;
vecvec.resize(10);
vecvec.at(5).push_back(42);
  When you start having nested data containers, it may be useful to abstract
a bit, so that the syntax becomes easier, like this:
typedef std::vector<int> IntCont;
// Now 'IntCont' is a vector of ints
std::vector<IntCont> vecvec;
// 'vecvec' is a vector of vectors of ints
vecvec.push_back(IntCont()); // Put a new IntCont into the vector
vecvec.back().push_back(42);
  Of course there's no limit on how many containers you can nest. You
could just go on:
typedef std::vector<IntCont> IntVecCont;
std::vector<IntVecCont> vecvecvec;
// Now 'vecvecvec' is a vector of vectors of vectors of ints.
  Managing all this in your head might become a bit complicated, though. :)
  In practice when you start needing such deeply nested containers, a good
idea is to start abstracting even more. The inner containers will usually
have a specific role, so you should make a class out of them, rather than
using the directly, and use some simple public interface with that class.
  For example, if you want a vector of huffman trees, it would be a bad
idea to try to manage them directly. Instead, it's a much better idea to
abstract the whole huffman tree concept, and then use that as the element
of the outermost vector. In other words, something like:
class HuffmanTree
 public:
    // A nice and easy-to-use interface here
 private:
    std::vector<IntCont> theTree; // Or whatever
    // Other possible private members
  Now you can do this:
std::vector<HuffmanTree> trees; // A vector of huffman trees
  So here you have three levels of nesting of vectors, but they are so
well abstracted that it's easily manageable. In the outermost layer you
only see the HuffmanTree class and its simple public interface.
Date: 27 Sep 2008 06:37:06
Message: <48de0cd2$1@news.povray.org>
OK. I just wasn't sure if it's permissible for the element type to be of
variable size, that's all.
> a bit.
Agreed.
Hence the abstraction. ;-)
Presumably I'm going to do something like define a struct that holds all
the data I need about each symbol (what the symbol is, its probability,
its current codeword, etc), and then define a typedef for a vector of
symbol info structs. Then it'll be quite clear that vector<tree> is a
vector of Huffman trees.
> class HuffmanTree
>  public:
>  private:
...or I could do that, yes. That would provide an obvious place to put
the "tree merge" functionallity, as well as symbol lookup, etc.
Date: 27 Sep 2008 06:41:03
Message: <op.uh4ymphl7bxctx@e6600>
On Sat, 27 Sep 2008 12:37:13 +0200, Orchid XP v8 <voi### [at] devnull> wrote:
It is not. In fact, there is no such thing as a variably sized type in C++.
FE
Date: 27 Sep 2008 06:58:13
Message: <48de11c5@news.povray.org>
  As Fredrik pointed out, a type in C++ always has the same size.
"std::vector<int>" is an example of a type, and each instance of it
will have the same size.
  In fact, there's a keyword in C++ (and C) which can be used to get
the size (in bytes) of a type, at compile time: sizeof(YourType)
  The std::vector class itself consists of a pointer and maybe a few
data members. Its contents do not change. What the vector does is that
it allocates memory dynamically. That allocated memory does not affect
the size of the std::vector object.
  Anyways, these are technical details you don't have to worry about.
Date: 27 Sep 2008 14:46:45
Message: <48de7f95@news.povray.org>
OK, that's pretty neat.
That's what's so neat about it. ;-)
Date: 27 Sep 2008 15:16:15
Message: <48de867f$1@news.povray.org>
What would be the correct way to iterate over a vector of integers and
find + remove the lowest element?
