POV-Ray : Newsgroups : povray.off-topic : C++ questions Server Time
4 Jul 2026 18:18:37 EDT (-0400)
  C++ questions (Message 34 to 43 of 123)
Subject: Re: C++ questions
Date: 26 Sep 2008 09:39:10
Message: <48dce5fe@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> >> Copy...constructor...? x_x
> >   Usually you don't need copy constructors unless you have pointers as
> > member variables of your class and you explicitly allocate memory to
> > them with 'new'. But we don't do that, do we? ;)
> Heh. I get the impression that most of the stuff I'm reading about now
> is stuff that "you won't normally need". ;-)
  It's not like you don't need copy constructors (and copy assignment).
It's just that a beginner doesn't usually need them. When you start needing
copy constructors, your code will be a bit more advanced.
> (E.g., apparently you can overload the "->" operator... GAH! >_< OK, I
> am *so* not trying that out!)
  You can overload almost any operator, including 'new' (it's considered
an operator in C++) and the prefix-&.
  I think the only operator you can't overload is the dot operator.
> Anyway, the main reason I haven't written a Third C++ Program yet is
> that I'm trying to think of something I actually want to write that's
> implementable without automatic memory management...
  Hmm, is that sentence correct? Everything is implementable without
automatic memory management. Perhaps you meant something else?-)
Date: 26 Sep 2008 10:30:37
Message: <48dcf20d$1@news.povray.org>
Well, yeah. And *I* am unlikely to be writing anything "advanced" any
time soon! ;-)
And .* (apparently).
Also, unlike Haskell, you apparently can't make up new operators of your
own, just overload the ones that already exist.
Well, yeah, but it's a touch harder to implement heap-allocated data in
such a way that your program doesn't leak like a sieve. ;-)
[I'm actually surprised that using std::vector doesn't do this already...]
Date: 26 Sep 2008 10:37:22
Message: <48dcf3a2@news.povray.org>
  Aren't C++ compilers already stressed enough? Think about all the problems
they would have with user-defined operators, with their own precedence
rules, ambiguous situations, etc... :P
  You usually use the STL data containers for dynamically allocated
memory, and if what you need is to allocate a single object, you can
use a smart pointer (I posted in the other group an URL to one smart
pointer implementation I have made).
  Doesn't do what?
Date: 26 Sep 2008 10:44:46
Message: <48dcf55e$1@news.povray.org>
Heh, yeah... I can see that. ;-)
> use a smart pointer.
Fair enough.
>   Doesn't do what?
Leak like a sieve! ;-)
I've never actually seen a programming environment with manual memory
management *and* dynamically resizable collections. The two are usually
muturally exclusive.
Then again, I'm not really sure what the story is if you try to put
user-defined data types into a vector...
Date: 26 Sep 2008 11:05:54
Message: <48dcfa52$1@news.povray.org>
Useful for the "Smart Pointer" pattern. The autogen stuff for COM uses
these a lot.
~Mike
Date: 26 Sep 2008 11:18:53
Message: <48dcfd5c@news.povray.org>
> >   Doesn't do what?
  The class constructors, assignment and destructor help in automatizing
the internal memory management of the vector.
  You can write your own dynamic data container as a class in the exact
same way as std::vector and the other STL containers, which will be safe
and will automatically manage its memory.
  And not only memory. There are also other resources which can be
automatically managed with classes. Consider this:
void foo()
    std::ofstream os("outfile.txt");
    os << "Hello\n";
    bar();
    os << "there.\n";
  Note that nowhere is the file actually explicitly *closed*. However,
no open file handles are leaked because it gets closed automatically
because the std::ofstream class handles this resource.
  This is even so even if the function is exited abnormally. For example,
assume that the bar() call throws an exception. If that happens, the
function will be exited immediately (before the "there.\n" string is
written to the file). This is "unexpected" and we didn't take that
possibility into account. However, it doesn't matter: The file will
still be closed and thus no resource leak happens.
  Unless I'm completely mistaken, this is not something you can achieve
in Java. (In Java you have to close files explicitly and catch all
possible exceptions which might otherwise bypass that closing.)
  Well, it's not like *all* resources in C++ are managed manually.
More precisely, stack-allocated objects are managed automatically. Which
is exactly the reason why automatic management heap-allocated objects
becomes possible through these stack-allocated objects.
  If the user-defined type doesn't allocate memory in itself, or if it
does but manages it properly, there shouldn't be any problems.
Date: 26 Sep 2008 11:19:44
Message: <48dcfd90@news.povray.org>
> these a lot.
  Also used with iterators. (An iterator is an object which behaves
like a pointer.)
Date: 26 Sep 2008 11:31:44
Message: <48dd0060@news.povray.org>
But presumable you'd need to know what you're doing first. ;-)
Mmm, that's nice.
Actually, for reasons beyond my comprehension, if a Haskell program
halts abnormally, all files are closed, but not necessarily *flushed*.
Like, WTF? *Why?* Anyway, basically you have to write some code to catch
the exception and close the file before rethrowing it. It's an extra 3
lines of code, but you still have to remember to type them...
Indeed. I've not seen this in any other OO language.
Sounds good to me! ;-)
Date: 26 Sep 2008 12:31:06
Message: <48dd0e4a$1@news.povray.org>
Invisible wrote:
> Looks like it would only be useful for some pretty obscure situations...
Really? They're useful all the time in C#. Like, every time you have a
callback function you register with the GUI, or every time in Java where
you'd have to create an anonymous inner class or something. Pointers to
members are the OO mechanism corresponding to closures.
You have a window representing an object. You want to be notified
whenever the mouse moves over the window. How do you tell the window
manager that?
Date: 26 Sep 2008 12:35:35
Message: <48dd0f57$1@news.povray.org>
The destructor will close the file when the GC collects the object, but
that might be several seconds later. And it might not run if you exit
the program before the GC runs, but that's true of C++ also. So it's not
quite as nicely deterministic, but it still happens eventually.
