POV-Ray : Newsgroups : povray.off-topic : Very long post Server Time
2 Jul 2026 03:45:13 EDT (-0400)
  Very long post (Message 11 to 20 of 50)
Subject: Re: Very long post
Date: 24 Sep 2008 02:27:08
Message: <48d9ddbc@news.povray.org>
> 1. A "tokeniser" takes the input string and splits it into "tokens",
> possibly decorating them slightly. So now you have a flat stream of tokens
> instead of just characters.
Do you need to have some sort of grammar rules though before you can
tokenise?  I mean what if you have the string "-3*(4-3e-2)+5*-3", the
tokeniser (if I understand right) needs to correctly decide how to interpret
those minus signs, needing some rules about what is surrouding it etc.  What
would be the best way to convert an ASCII string like that into a list of
tokens?
Date: 24 Sep 2008 04:34:06
Message: <48d9fb7e$1@news.povray.org>
> tokenise?
Yes, definitely.
> interpret those minus signs, needing some rules about what is surrouding
> it etc.  What would be the best way to convert an ASCII string like that
> into a list of tokens?
Ah yes, the old "is it unary minus or binary minus?" question.
In this case, you'd probably let minus be a token by itself, and let the
parser decide whether it's unary or binary based on the context when it
builds the parse tree.
Date: 24 Sep 2008 06:28:50
Message: <op.uhzd2h1ic3xi7v@news.povray.org>
And lo on Tue, 23 Sep 2008 12:32:15 +0100, Invisible <voi### [at] devnull> did
spake, saying:
> # Preface #
> OK, so the muse has taken me. I want to write something.
[smack] Blog!
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 24 Sep 2008 06:36:18
Message: <48da1822$1@news.povray.org>
Phil Cook wrote:
> [smack] Blog!
Meh. Like anybody will read it! :-P
Date: 24 Sep 2008 08:42:26
Message: <48da35b2$1@news.povray.org>
>> tokenise?
> Yes, definitely.
To see this, consider that in many programming languages, "foo_bar" is a
single identifier. However, in TeX source code, "_" is [usually] a
command name and hence should be parsed as a seperate token.
So what constitutes a "token" completely depends on exactly what you're
trying to tokenise/parse.
Date: 24 Sep 2008 11:42:32
Message: <48da5fe8$1@news.povray.org>
Typically, it's done with regular expressions. And typically, "-37" is
two tokens in programming language compilers, at least.
Date: 25 Sep 2008 03:37:05
Message: <48db3fa1$1@news.povray.org>
> Typically, it's done with regular expressions. And typically, "-37" is two
OK, and then is there only one token for "minus", or are there two for unary
and binary minus?  ie does the parser decide or the tokeniser?
Date: 25 Sep 2008 04:26:39
Message: <48db4b3f@news.povray.org>
> unary and binary minus?  ie does the parser decide or the tokeniser?
Varies depending on the rules of whatever you're trying to process, but
typically it's the parser.
Date: 25 Sep 2008 06:09:17
Message: <48db634d@news.povray.org>
I'm just curious, because I made a parser like this in C++ once (it was very
hacky and basically just stepped along the string trying to identify what
each byte was).  Anyway, it worked ok for things like "-5*(4+2)" etc, but
crashed with "-(4+2)".  I guess the minus operator should be encoded as its
own token and then let the parser sort out what it should do.  Maybe I'll
try a rewrite one day.
Date: 25 Sep 2008 06:12:25
Message: <48db6409@news.povray.org>
> very hacky and basically just stepped along the string trying to
> identify what each byte was).  Anyway, it worked ok for things like
> "-5*(4+2)" etc, but crashed with "-(4+2)".  I guess the minus operator
> should be encoded as its own token and then let the parser sort out what
> it should do.  Maybe I'll try a rewrite one day.
Yeah, this is one of the tricky edge-cases of expression parsing.
Operator precidence and unary/binary operators can get pretty ugly.
(Gets even harder if you want to report meaningful error messages if
there's an actua syntax error...)
