POV-Ray : Newsgroups : povray.off-topic : XP slipstreaming Server Time
16 May 2026 11:47:28 EDT (-0400)
  XP slipstreaming (Message 1 to 4 of 4)
Subject: XP slipstreaming
Date: 4 Sep 2008 10:21:27
Message: <48bfeee7@news.povray.org>
OK, as an IT guy in my small company I am really behind the times....
I needed to install XP on a machine with SATA RAID and no floppy drive.
I've ran across slipstreaming before, but dismissed it because of the
learning curve that I assumed I would have to go through.
Then I hit nliteos.com
While not perfect, I really was slick.
I was able to add SP3, IE7, and WMP11 to the install disk without having
to do a separate install later - along with all of the junk that comes
with it.
I added my SATA drivers along with some other goodies.
I removed things I don't use or care for - ie... Indexing service
It is no longer there at all - the files are gone.
Then burned about 6 CDR coasters that didn't work.
XP install kept complaining that it could find a file during install.
Then read to try a DVD - worked beautifully.
I need to use this at work.  This will save at least an hour on a build
because I don't have to wait for Windows updates to download and then
install junk.
Subject: Re: XP slipstreaming
Date: 4 Sep 2008 13:39:51
Message: <48c01d67@news.povray.org>
  Don't you mean "remove from" rather than "add to"?
Date: 4 Sep 2008 13:43:51
Message: <48c01e57$1@news.povray.org>
no I mean add to
While I am not the biggest fan of those 'features' I find that having
them around does make it easier to do some things.
And yes, you can remove most of those components that you never use....
outlook express anyone
Tom
Date: 12 Sep 2008 17:35:08
Message: <48cae08b@news.povray.org>
I still think outlook express is the best NNTP reader I've tried :/
