POV-Ray : Newsgroups : povray.off-topic : Coolest thing EVER! Server Time
16 May 2026 14:00:18 EDT (-0400)
  Coolest thing EVER! (Message 11 to 20 of 112)
Subject: Re: Coolest thing EVER!
Date: 31 Aug 2008 12:59:42
Message: <48bacdfe$1@news.povray.org>
>> My PC at work is barely powerful enough to run *one* OS, let alone
>> two. It _would_ be quite useful for test purposes though.
> That's one of the main reasons I went for a quad core with lots of
> memory when I upgraded.
I can see how that would be the case. ;-)
>> However, the idea of being able to just plug in a USB stick and click
>> an icon and instantly have a complete Linux environment set up exactly
>> the way I want it is... pretty neat, actually.
> You might have problems with IO speed if you do that. USB is a lot
> slower than SATA.
Depends what you want to do. Running Damn Small Linux from a USB drive
is probably *faster* than running it from a CD-ROM due to the vastly
superior seek time. (CD-ROM drives typically have a horrible seek time!)
Also, DSL is based on KNOPPIX and uses a cloop compressed filesystem
image, so there's less data to shift (but more CPU load).
If I get bored enough maybe I'll benchmark it. But either way, it's a
trivial matter to copy a folder off the USB drive and onto a spare
folder on the local HD, run it for a while, and then just delete it when
you're done. That's about the easiest install/uninstall procedure
imaginable! ;-)
http://blog.orphi.me.uk/
Date: 31 Aug 2008 13:01:05
Message: <48bace51$1@news.povray.org>
Gail wrote:
> Virtual machines are soooo useful. I've been using them for some time to
> test out beta software that I don't want breaking my machine, or to try
> out things that I know are going to break stuff (hence the name of the
> VPC in the picture)
I use them at work, while one real server can easily hold up the work of
3 smaller servers, and having only one hardware makes less heat, uses
less power, costs less money and takes up less space.
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 31 Aug 2008 13:07:12
Message: <ucjlb4l1ddf87j4lves2ms6p2hgf8i7cra@4ax.com>
On Sun, 31 Aug 2008 18:54:53 +0200, "Gail" <gail (at) sql in the wild (dot) co
[dot] za> wrote:
>"Stephen" <mcavoysAT@aolDOTcom> wrote in message
>news:pmhlb49pho3518hld68ob2f0h600na7nk4@4ax.com...
>> On Sun, 31 Aug 2008 18:16:57 +0200, "Gail" <gail (at) sql in the wild
>> (dot) co
>> [dot] za> wrote:
>> A new email address, Gail!
>> Have you started your new job yet?
>That's actually the email address related to my blog
>(http://sqlinthewild.co.za) not a work address.
You have a blog dedicated to SQL? Is that so you don't use this forum for Haskel
Oops! Sorry Andrew :)
>I have started the job. Going slowly at the moment. Should be picking up in
>a week or two. Lots of clients are currently 'considering what they want'
Yes, I understand. My new job (with Dwr Cymru (Welsh Water)) started off slow
then accelerated so that I've little time for Pov-ing.
I hope yours goes well.
Regards
Date: 31 Aug 2008 15:48:33
Message: <48baf591$1@news.povray.org>
Orchid XP v8 wrote:
> OK, so I realise I'm probably about 20 years behind everybody else, but
> seriously... this is THE coolest thing I've seen this year!
I've been thinking of playing with some virtual machine technology, but
I wasn't aware there was one under Windows that would run Linux. Which
virtual machine are you running here? (I.e., what's the Windows software?)
Date: 31 Aug 2008 16:13:26
Message: <48bafb66@news.povray.org>
1. Go to http://www1.interq.or.jp/t-takeda/top.html
2. Download the zip file at the top of that page.
3. Unzip it somewhere.
4. Find an ISO image for a Linux LiveCD.
5. Do the following:
   qemu.exe -cdrom My_LiveCD.iso
6. Watch it boot up.
It's that easy.
(Actually no, it isn't. The path to the ISO image must contain only
FORWARD SLASHES, not backslashes. Also, if the current directory isn't
the QEMU folder, you must add the -L switch with the correct path so the
emulator can find things like the BIOS image, keymaps, etc.)
The *home page* for QEMU is here:
   http://bellard.org/qemu/
But you have to hunt around a bit for the Windoze port. So I have you
the direct URL...
If all of that is too much effort, go to
   http://www.damnsmalllinux.org/
and download the "embedded" Zip file. This contains a .bat file that you
can just double-click to start up Linux.
PS. If you want to "install" Linux rather than run off a read-only
LiveCD, you can create a harddisk image using the qemu-img.exe tool.
Something like this:
   C:\> qemu-img create Disk1.img 500MB
   C:\> qemu -cdrom My_Install_Disk.iso -hda Disk1.img
Now install Linux onto /dev/hda. Once you've done that, you can run
   C:\> qemu -hda Disk1.img
and you have a read/write Linux system. (Obviously similar steps work
for *any* OS. Build an empty harddisk image, run the emulator with the
install CD ISO image and the harddisk, install, you're done.)
My God... I sound like I know what I'm talking about! This morning when
I woke up, I knew none of this. ;-)
Date: 31 Aug 2008 16:17:12
Message: <48bafc48$1@news.povray.org>
Very nifty. Thanks very much!  I was going to try out the VM from
Microsoft, but this sounds a lot easier to get working. :-)
Date: 31 Aug 2008 16:23:16
Message: <48bafdb4$1@news.povray.org>
Yeah. Zero install. Unzip a file and you're ready to execute stuff.
As I say, DSL uses it to run off a USB flash drive. Stick the flash
drive in, double-click, you have Linux running. Don't even have to
reboot. Live CDs EAT YOUR HEART OUT! (OTOH, emulation is obviously just
a tad slower...!)
Actually, I *think* you can even tell it to use your real CD-ROM drive
as the emulated CD-ROM, if you don't have an ISO image but have a real
CD... You can also do the same with your HD, but... uh... don't!
Date: 31 Aug 2008 17:54:32
Message: <48bb1318$1@news.povray.org>
I'll have to see if I can make it run the Linux on the other partition,
just to see. It could be pretty cool if I could get into my work
machine's configuration for a bit without having to stop what I'm doing
in Windows every time they want some free advice. :-)
Date: 31 Aug 2008 19:54:28
Message: <48bb2f34@news.povray.org>
Orchid XP v8 wrote:
> Also - virtual machines are SOOOO SLOOOOOW... :-/
They aren't that slow. Thing is, you're using QEMU, which isn't a virtual
machine, it's an emulator. Software like VMware or VirtualBox use your real
CPU instead of basically executing x86 code on an interpreter.
Date: 31 Aug 2008 19:56:33
Message: <48bb2fb1@news.povray.org>
Huh? I have yet to see virtual machine software that *can't* run Linux on a
Windows host...
