POV-Ray : Newsgroups : povray.off-topic : Geek humour Server Time
1 Mar 2026 14:31:54 EST (-0500)
  Geek humour (Message 1 to 10 of 10)
Subject: Geek humour
Date: 26 Aug 2008 08:30:52
Message: <48b3f77c$1@news.povray.org>
When I was in the tea room eating my lunch, I noticed a piece of tissue
paper with crossword data scrawled across it. Being the mischifous soul
I am, I added the text "T = 2 pi sqrt(L/G)".
Apparently my handwriting is very unique. Either that or everybody knows
that only I would be stupid enough to write such a thing. Either way, a
guy just came other to thank me for my help with the crossword, and to
ask what the hell the formula is for.
3 points to the first person who can tell me what this formula describes.
http://blog.orphi.me.uk/
Subject: Re: Geek humour
Date: 26 Aug 2008 08:42:04
Message: <48b3fa1c$1@news.povray.org>
> describes.
Period for a ideal pendulum of length L in a homogeneous graviational
field of a acceleration G in the limit of small elongations (sin(x) appr.
x).
I don't mind the points, I'll dontate them to charity...
Date: 26 Aug 2008 08:44:21
Message: <48b3faa5$1@news.povray.org>
> x).
You can have a few more points if you explain the "in the limit of small
elongations" part...
Date: 26 Aug 2008 08:51:15
Message: <48b3fc43$1@news.povray.org>
That makes me suspicious, where do you get the points from, so you can
shell them out like no good? ;)
Try to set up the differential equations for the pendulum, and you'll run
into non-linear parts somewhere. So in order to keep the solution simple,
usually one assumes elongations small compared to the pendulum length (so
that you can approximate "sin(x)" by a much more linear "x").
Date: 26 Aug 2008 09:21:43
Message: <48b40367@news.povray.org>
  Or in other words, sin(x) is very close to x for the range -y <= x <= y,
where y is a small positive value.
Date: 26 Aug 2008 09:24:33
Message: <48b40411$1@news.povray.org>
You can write an exact differential equation for the motion of a pendulum,
but it will have a sin or cos in it because the string/rod is at an angle to
gravity.  Usually you replace sin(x) with just x to make it easy to solve
and get a simple solution.  x (in radians!) is actually a pretty good
approximation to sin(x) for angles up to 10 or 20 degrees - try it.
Obviously the bigger swings your pendulum makes, the more inaccurate the
"simple" equation will be.
Date: 26 Aug 2008 09:26:57
Message: <48b404a1@news.povray.org>
> pendulum, but it will have a sin or cos in it because the string/rod is
> at an angle to gravity.  Usually you replace sin(x) with just x to make
> it easy to solve and get a simple solution.  x (in radians!) is actually
> a pretty good approximation to sin(x) for angles up to 10 or 20 degrees
> - try it. Obviously the bigger swings your pendulum makes, the more
> inaccurate the "simple" equation will be.
Damn. And I thought it was an "exact" equation. Oh well...
Date: 26 Aug 2008 09:30:22
Message: <48b4056e$1@news.povray.org>
http://en.wikipedia.org/wiki/Image:Pendulum_period.svg
Date: 26 Aug 2008 09:40:18
Message: <48b407c2$1@news.povray.org>
"The graph as well as other important points are simply wrong: The time
at 90° amplitude is 18% larger than T0 and not 7.3% as shown in the
plot. Then, the author plots the integrand instead of the integral.
Furthermore, he calculates sin(th0)/2 instead of sin(th0/2). Means, this
page is seriously flawed!"
Date: 26 Aug 2008 09:45:06
Message: <48b408e2$1@news.povray.org>
Am Tue, 26 Aug 2008 14:40:18 +0100 schrieb Invisible:
"Author
Alessio Damato; thanks to John wayman, he let me notice a mistake in the
code."
If you look at the plot, you'll notice that at 90° it shows a deviation
of 18% indeed. So the file might actually be the corrected one.
