POV-Ray : Newsgroups : povray.off-topic : Hypothesis: OO does nothing for reusability Server Time
3 May 2026 13:13:39 EDT (-0400)
  Hypothesis: OO does nothing for reusability (Message 3 to 12 of 22)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Hypothesis: OO does nothing for reusability
Date: 20 Aug 2008 16:07:05
Message: <48ac7969@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> (I count
> "reuse" as the ability to take code already written and use it in ways
> not anticipated when it was written.)
  Maybe your definition of "reusability" is different than what it's really
meant.
  IMO a reusable component is one which you can take out of the original
program it was developed for, and use it (usually for the same purpose)
in a different program.
  Of course a generic library is reusable by definition (because it has
not been developed for a specific program, but to be reusable in all kinds
of programs). However, what OOP advertises is that, when you are developing
a program, if you design your objects properly, there's a high chance that
those objects will not be completely tied to that specific program, but can
be reused in other programs as well.
  What does OOP in particular bring to the whole reusability concept?
It brings the concepts of encapsulation, abstraction and (minimal)
interfaces. When properly implemented, these concepts aid in making a
module reusable (ie. not tied to a specific program).
  That doesn't mean other programming paradigms wouldn't support those
same concepts. It's just that OOP has been designed with those concepts
as the main starting points.
  (Whether the OOP paradigm has completely succeeded in this goal is open
to debate, but IMO it has succeeded pretty well, even if not perfectly.)
Date: 20 Aug 2008 16:12:30
Message: <48ac7aae@news.povray.org>
somebody <x### [at] ycom> wrote:
> I tend to agree with you. A procedural library with proper standards and
> documentation is much easier to use *and* extend. Problem with OO is just
> what you mention, "anticipation". If the authord of an OO library did not
> anticipate a usage pattern that you wish to employ, it's
> unusable/unextendable at worst, and inefficient at best.
  Uh. Basically you are saying "a well-designed procedural library is much
better than a badly-designed OO library". Well, duh.
  Obviously we should compare well-designed procedural libraries with
well-designed OO libraries.
> OOP is only an improvement over using global variables in procedural
> programming. It's *not* an improvement over procedural programming. If one
> can wrap everything in procedures, that's the ideal, if you ask me.
  Exactly how would you implement, for example, a linked list or a binary
tree without using any objects?
Date: 20 Aug 2008 17:31:55
Message: <48ac8d4b$1@news.povray.org>
Well, what *I* was saying is that a well-designed OO library isn't
generally better (in the reusability sense) than a well-designed
procedural library. Especially when you don't have object-type data
you're manipulating in the first place. Sure, an OO GUI library is
likely to be better than a procedural GUI library. But if the thing
you're making a library of doesn't inherently have a heirarchical
inheritance kind of structure, it's been my experience it doesn't help
to make it OO. (E.g., it doesn't help to make a logging library OO, or a
text processing library OO, or etc.)
For example, I haven't found any OO language where I could (for example)
rip out the email/MIME handling code and use it to implement an NNTP
client, unless the email/MIME handling code was specifically designed to
be used in a second project anyway. It takes as much discipline to make
reusable OO code as it does to make reusable procedural code, but more
discipline than it takes to make reusable
concurrency-oriented-programming code or stand-alone whole-program code.
Because, you know, nobody ever implemented a linked list or a binary
tree in FORTRAN, or C, or ... :-)
Yep. That's what I mean.
but can
I've found that not to be the case. That's kind of what I meant. It
takes a lot of design-fu to be able to do that naturally without
intentionally sitting down to make that happen.
I believe it has failed. I don't see OO classes that aren't designed as
stand-alone from the start as being any less decoupled from their
environment than procedural languages similarly designed. The idea that
OO automatically leads to self-contained classes that can be (a) reused
elsewhere and/or (b) extended via inheritance in unanticipated ways is
just wrong.
Because I've done stuff like that. I've tried to (for example) take a
credit-card-clearing class from one PHP program and use it as the backup
when the credit-card-clearing class from the other PHP program fails,
and it just doesn't work. Things rely on particular logging mechanisms,
particular configuration system, particular error handling strategies.
There's too much expectation on the environment, unless you diligently
avoid it from the start. (Of course, the same is usually true of
procedural code, but my contention isn't that OO is *worse*.)
That has been my experience, at least.
Well, yeah, that's kind of what I was debating. ;-)  In any case, I
think it's more that the memory management of OO languages has helped
the reusability more than the actual "OO-ness", or class information
hiding stuff.  I don't think it's the "if you want to change something,
inherit and override" that does it as much as it is the "you don't have
to dick with half a dozen memory allocators to make stuff work."
And I think there are a lot of programming techniques that lead to
*more* reusability than OO does. OO classes are too small and the
borders between them too wide and (in general) poorly specified to
achieve the aims people claimed for them.
Has anyone here actually pulled classes out of some program that wasn't
intended to be pulled apart, and used them without major reworking?
Date: 20 Aug 2008 18:51:05
Message: <48ac9fd8@news.povray.org>
  You have got it backwards. It's not like OOP would somehow magically
make any code you write more reusable. The actual point is that if you
want to make reusable code, OOP makes it *easier* than many other, simpler
paradigms. This is because OOP offers strong tools for this exact purpose
(such as abstraction and encapsulation).
  Let me propose an allegory for this: Just because you own a set of
kitchen utensil doesn't make you a better cook. However, if you are a
good cook, the kitchen utensil set will make it much easier for you to
prepare a meal. A set of carpenter tools, however, would be a rather poor
choice for preparing a meal, even though carpenter tools are good for
other, completely different tasks.
> The idea that
> just wrong.
  True. And this shows that you have misunderstood what OOP is. It's a
set of tools, not magic.
  A certain programming paradigm will not make you a better programmer.
You can write crappy programs in any language.
  I really can't see how memory management has anything to do with
reusability. Just because something has automatic memory management
doesn't make the code any more (or less) reusable. A crappy program
is still a crappy program even if it doesn't leak memory.
  The one thing which OOP has contributed greatly to reusable programming
is the concept of modules. (Not really an "invention" of the OOP paradigm,
but it's the paradigm which made it available to the masses.)
  Even the most OO paradigm hating coder cannot deny the usefulness of
modules, which are the basic building blocks of OOP languages. (And
for those who don't know what a module is, many OOP languages call it
"class".)
  You have still got it backwards.
Date: 20 Aug 2008 19:12:42
Message: <48aca4ea$1@news.povray.org>
> paradigms.
Hmmmm. Again, I'm not sure I agree.
But there are many other paradigms that do this far *far* better.
Message-passing concurrency. UNIX-like filters. Etc.
I don't think OO goes far enough.
>> The idea that
>> just wrong.
Um, yes, I know, thanks.  But in the early days, it was claimed that
making something OO would make it easier to reuse in new projects. I've
just never found that to be the case. (See the whole "software ICs" stuff.)
Memory management makes things easier because you can treat objects as
entities. If the object comes with its own mechanism for deallocating
the memory when it's no longer needed, then your library doesn't have to
implement that and your callers don't have to enforce it.
If it's automated, all the better.
Or are you telling me it's not easier to write libraries in C++ than in
C because of the destructors?  Would C++ be that much easier than C if
you didn't have destructors?
Having memory management built in to some degree isolates you from
having to know what's inside the object to that degree. You don't have
to say "when you're done with this, call DisposeMyThing(mything) to free
all the memory allocated."  If you actually have something like GC, you
can say "and don't worry if I've formerly returned a pointer to
something inside, or if you passed me a pointer to something outside."
The idea of modules was around long before OOP. :-) They were called
"libraries".
> "class".)
Except the problem I think is that most OOP modules are much larger than
  a class. And you probably still have trouble retargetting them to a
*slightly* different purpose.
Perhaps. I think you're trying to say that writing reusable OOP is
easier than writing reusable procedural. I'll grant that might be the case.
I'll argue that other paradigms are even easier to write reusable in.
I'll also argue that non-reusable OOP isn't any easier to make reusable
than non-reusable procedural code, which I think is also what many early
advocates of OOP were suggesting.  "Just subclass someone else's class,
and change the routines you need changed, and viola!"
I'm probably talking about more rabid advocates of OO-reuse than you
are. :-)
Date: 20 Aug 2008 19:31:28
Message: <48aca950@news.povray.org>
  Obviously we should assume the word "properly" in there.
  One could say that if you write a class which is *not* reusable, then
your OO design is bad.
  Still can't see what this has to do with reusability. Reusability is
a question of design, not a question of memory management.
  Still can't see the connection to reusability.
  Perhaps you are confusing "reusable" with "easy to use"? Different things.
  Still related to ease of use rather than reusability.
  Didn't you read what I wrote in parentheses?
> They were called "libraries".
  When I say "module" I'm referring to a much more concrete entity than
a generic "library". I'm talking about modules as per the modular programming
paradigm.
  Some people call C header+source file pairs "modules", but that's not
the kind of module I'm talking about. That has little to do with the modular
programming paradigm.
  I'll believe it when I see it.
Date: 20 Aug 2008 20:08:16
Message: <48acb1f0$1@news.povray.org>
But you could say that about a library/collection of general functions
in a procedural language, too. If your higher-level OO class depends on
a lot of lower level classes having the proper semantics and calls,
you're not going to be able to reuse it.  If your MIME parser depends on
certain memory allocation mechanisms, regular expression libraries, and
so on, it's going to be difficult to reuse without bringing in the
entire stack.
You don't have to design the memory management. :-)  And, more
importantly, the memory management doesn't conflict with someone else's
memory management.
Nope.
You have to spend less time tracking what's inside the class if the
memory management (well, really, resource management) is done
"properly". You don't have to worry if (for example) object A you passed
to object B to initialize B is still being referenced after you've
finished with B. E.g., if you pass a bitmap to a window for drawing,
when can you throw away the bitmap? Does the window object copy the
bitmap or just hold a reference to it? If you actually have to say, then
you've exposed implementation details of your class, and of the bitmap
class (which now might need a "clone me" operator). This gets even more
obvious when you start having things like a open-file-handle used by a
certificate used by an encryption-in-progress used by an SSL-link used
by a socket used by an HTTPS connection used by a network-rpc used by
.... When is it safe to close the file handle if you're the one that
opened it?
If the memory management is more automated (and here I count C++ as
"more automated"), then your window class can work with bitmaps that
don't have the "clone me" method implemented (because, perhaps, they're
too big to fit in RAM all at once anyway). When the caller closes the
bitmap *and* the window, the memory and/or file handle goes away.
This is kind of exactly the sort of thing you complain about with
finalizers versus destructors all the time. I'm kind of surprised you're
now disagreeing with me.
Of course. But if it's modules that make something reusable and not
objects, then that's just supporting my point.
> paradigm.
I know.  In practice, a "library" is also a "module" in many ways,
especially if designed to be reusable.  By which I mean a library
designed to do one specific thing, such as parse XML or so. Yes?
Hmmmm... I suspect you'd have to describe to me what you think "modular
programing paradigm" means before we could talk meaningfully about that.
How many people reuse the work that went into Apache in their own
programs? Half the web sites on the internet?  :-) How many CLI source
code control systems on UNIX use a linked-in editor rather than invoking
$EDITOR as a separate program?  How many link in database engines rather
than having them running as a separate executable?
Obviously packaging up your code as a separate executable file makes it
easier to use from other programs in some ways than does packaging it as
an object-oriented class library.  Harder to reuse in *my* sense of the
word, perhaps.
Date: 21 Aug 2008 04:05:25
Message: <48ad21c5$1@news.povray.org>
Darren New wrote:
> (I count
Isn't that "extensibility", not "reusability"? You want to *extend*
existing software to do something it wasn't designed to do.
> But particular OO libraries are IME limited to doing exactly what they
> were designed to do, without really being any more extensible than a
> procedural language with carefully crafted callbacks.
You're still talking about "extensible", not "reusable".
In a classic procedural language like, say, Pascal, it is basically
impossible to write a reusable sorting algorithm. That's because Pascal
is a monomorphic language, so it forces you to write SortIntArray(),
SortRealArray(), SortStringArray(), SortIntList(), SortRealList(),
SortStringList(), SortIntDList(), SortRealDList()... are you getting
bored yet?
With any half-decent OO language, this problem immediately goes away.
You can now write a sorting algorithm once for each container type (or
even once overall if you desire, but that's probably less efficient) and
you're done. This one sorting algorithm can then be reused anywhere you
need to sort data.
These days OOP isn't the only paradigm that actually offers this
benefit, but the benefit is real none the less.
http://blog.orphi.me.uk/
Date: 21 Aug 2008 11:11:26
Message: <48ad859d@news.povray.org>
> opened it?
  I still see only thing related to ease of use rather than reusability.
  I'm only disagreeing with your definition of "reusability", which still
sounds to me like "easy to use".
  In fact, OOP brings modules on steroids, and offers tools which a pure
modular language doesn't. These tools can also be used for reusability.
> > paradigm.
  An XML parser is actually a good example of a library which benefits
(from a reusability point of view) from the OOP paradigm. That doesn't
mean a good and reusable XML parser couldn't be implemented with other
paradigms, it means that the OOP paradigm is very well suitable for it
(often even better than many other paradigms).
  I can think of two different ways of implementing an XML parser library:
1) The parser library is initialized and told to parse some XML file.
   After that, the calling code traverses through the elements in the XML
   file by asking these elements from the library one at a time.
   Where does OOP kick in? Well, one very natural way of implementing this
   "XML element" which the library returns is for it to be an object.
   After all, "XML element" is a concept, something very suitable to be
   described as a class.
2) The calling code implements a virtual callback class/interface defined
   by the library, gives itself to the library, and then tells it to
   parse the XML file. The library then passes all the parsed elements
   to the calling code by using this callback interface.
   The callback class/interface is pure OOP, so there's no need to argument
   that any further.
  Especially in the second case the OOP aspect helps reimplementing the
code which receives the XML elements on a per-program basis. This is
reusability at its best.
  Should suffice to say that modules should be instantiable.
  (With that I don't mean that *all* modules *must* be instantiable.
What I mean is that the module should support instantiation unless it
has been specifically forbidden.)
Date: 21 Aug 2008 11:40:41
Message: <48ad8c79$1@news.povray.org>
Ease of reusability, then. ;-)
I think what I'm stressing is that you can not only use it in different
programs, but with different types of data that you might not have
anticipated when you wrote the program in the first place. That's where
the ability to let objects manage their own lifetime (i.e.,
encapsulation of the resource management) comes into it.
That's called the DOM. (Document Object Model.)  Or, rather, the
standard object interface for it is called DOM. Note that while you do
indeed "reuse" the library when working with it, the tendency is to not
actually ever write subclasses for the DOM objects, so generally it's
neither more nor less "reusable" than a procedural library. It's perhaps
a bit easier to use from a language with distinguished-caller syntax,
but otherwise, if your language isn't OO, it's trivial to provide the
same stuff as procedures taking objects, since there's neither
inheritance nor subclassing going on.  I.e., if you wanted to expose the
XML library as data structures rather than object with getters, it's
trivial to do so, and languages that don't support OO do this without
any problem.
That's called SAX, meaning "Simple API for XML".  Stupid name, but there
you have it. It's also not XML. Generally speaking, a SAX parser isn't
implemented in an OO kind of way. (Obviously, in languages like Java
where there are no functions, yeah, it's implemented in an OO way. But
in languages that support something other than or in addition to OO
(like PHP), it's almost never implemented in an OO way.)  It's
implemented instead as "here's the callbacks for handling various
events" instead of "here's an instance of a class with a particular
interface."   (True, it would probably be *better* as a class, but not
significantly moreso, especially if it crashes to have two concurrent
instances anyway.)
Would be funky if true.  Sadly, even the Java implementation doesn't
actually work right, and crashes if you use it in two threads at once,
which would lead one to believe it's not actually storing everything it
needs in the instance variables of the parser.
Fair enough.  Sort of OO without inheritance. :-)
