POV-Ray : Newsgroups : povray.off-topic : Colour consoles Server Time
19 Apr 2026 00:19:59 EDT (-0400)
  Colour consoles (Message 11 to 20 of 33)
Subject: Re: Colour consoles
Date: 20 Aug 2008 11:47:00
Message: <op.uf6zgld97bxctx@e6600>
On Wed, 20 Aug 2008 17:43:05 +0200, Darren New <dne### [at] sanrrcom> wrote:
> Fredrik Eriksson wrote:
>> NT-based console windows do not support colour escape codes. Only
>> 16-bit applications (running under NTVDM) can use colour escapes.
> So this doesn't work?
http://www.windowsnetworking.com/kbase/WindowsTips/Windows2000/UserTips/Miscellaneous/CommandInterpreterAnsiSupport.html
"the command.com shell interpreter"
"Any DOS applications you run in this command shell will now have ANSI
support."
FE
Date: 20 Aug 2008 11:50:46
Message: <48ac3d56$1@news.povray.org>
> support."
I've tried things like this several times before, and it's never worked
for me...
http://blog.orphi.me.uk/
Date: 20 Aug 2008 11:51:37
Message: <48ac3d89$1@news.povray.org>
> On Wed, 20 Aug 2008 17:20:17 +0200, Invisible <voi### [at] devnull> wrote:
>> The hard part, of course, is writing some Haskell bindings. ;-) In
>> particular, I cannot for the life of me figure out how to get at
>> symbolic constant names. :-(
> If you are looking for 'FOREGROUND_BLUE' and the like, they are defined
> in 'WinCon.h'. There you will also find the structure definitions
> relevant to the console subsystem.
Yes. I eventually tracked those down.
Also, apparently STD_OUTPUT_HANDLE is -10, not 10. >_<
Date: 20 Aug 2008 11:55:21
Message: <op.uf6zuilk7bxctx@e6600>
> for me...
As I said before, only 16-bit applications can use colour escapes under NT.
FE
Date: 20 Aug 2008 12:01:37
Message: <48ac3fe1@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:48ac3d56$1@news.povray.org...
>> support."
> for me...
I run ksh on my windows xp machine and I'm able to do all that with just a
few escape sequences in my .profile
Jim
Date: 20 Aug 2008 12:07:12
Message: <48ac4130@news.povray.org>
Technically, there's no such thing in C as such. The #define substitutes
the actual value for the name before the "compiler proper" ever sees it.
That's why the C standard requires something like
   f(3 + 2);
to not do any additions before invoking f(5). Otherwise, people would
hesitate to use something like
#define LAST (PREV+1)
Date: 20 Aug 2008 12:08:05
Message: <48ac4165@news.povray.org>
> support."
Oh. OK. So you can't invoke it from command.com and have it work?
Date: 20 Aug 2008 12:24:51
Message: <op.uf607owp7bxctx@e6600>
Only if it is a 16-bit application. The colour escape functionality is
provided by 'ansi.sys' which is a 16-bit driver.
FE
Date: 20 Aug 2008 13:42:18
Message: <48ac577a$1@news.povray.org>
Invisible wrote:
> I wonder... Is there some function call in the Win32 API that can
> actually change the colour of the text in a console window? Or is that
> impossible? Does anybody here know the Win32 API well enough to know the
> answer?
Yes, there is:
#include "stdio.h"
#include "windows.h"
void main()
     HANDLE hCon = GetStdHandle(STD_OUTPUT_HANDLE);
     SetConsoleTextAttribute(hCon, 0x0C);
     printf("Hello in red");
     SetConsoleTextAttribute(hCon, 0x09);
     printf(" and in blue\n");
     getchar();
Detailed here:
http://msdn.microsoft.com/en-us/library/ms686047.aspx
Date: 20 Aug 2008 15:22:28
Message: <48ac6ef4@news.povray.org>
> You *know* something's wrong when you find yourself envying people who
> use Unix because it can emulate an obsolete VT100... o_O
> Basically, I have a perfectly working console application, but I wish I
> could just make certain parts of its output come out in a different
> colour. On Unix, this would be a fairly trivial matter of writing some
> escape codes to stdout and you're done.
  AFAIK, the VT100 didn't support colors. That came with later versions
of VT.
