POV-Ray : Newsgroups : povray.off-topic : Strange GPU Server Time
5 Apr 2026 06:22:40 EDT (-0400)
  Strange GPU (Message 11 to 20 of 34)
Subject: Re: Strange GPU
Date: 18 Aug 2008 09:54:18
Message: <48a97f0a$1@news.povray.org>
> Surely that's a rather rare failure mode on a graphics card?
About the same as getting some bad RAM bits in your normal PC RAM probably.
> That seems to me more like the kind of thing where you get a brand new
> card and it's DOA. This card has been installed and running without issue
> for years.
I had the RAM in my desktop machine at work partially fail after some time.
It started when dealing with big zip files, it would complain that the CRC
check didn't match up, even though I had just downloaded it.  Then it would
blue-screen randomly, and gradually got more frequent.  I did the memcheck86
or whatever it was and there was an area of RAM that was totally corrupt,
it's a wonder Windows even booted, let alone worked normally most of the
time.  Replaced the RAM and very reliable now.
I had the same with my nVidia Ti4200 graphics card, actually identical
symptoms to you, random triangles flickering across the screen.  Gradually
got worse over time, and also while playing a game until it crashed.  Tried
it in my sisters PC and the same symptoms.  I didn't bother trying to figure
out the cause, but just assumed it was bad RAM.
Date: 18 Aug 2008 10:00:36
Message: <48a98084$1@news.povray.org>
Well, you'd think. ;-)
I've bought brand new RAM sticks to find that they're defective, and
I've occasionally damaged one inserting or removing it, but never seen
one just fail during normal use. They seem to be quite reliable.
> time. It started when dealing with big zip files, it would complain that
> the CRC check didn't match up, even though I had just downloaded it.
> Then it would blue-screen randomly, and gradually got more frequent.  I
> did the memcheck86 or whatever it was and there was an area of RAM that
> was totally corrupt, it's a wonder Windows even booted, let alone worked
> normally most of the time.  Replaced the RAM and very reliable now.
Yeah, RAM failures cause weird crap to happen. Depending on where in RAM
the problem is, it often only causes problems when you try to do certain
things. (But what with virtual memory, it's quite hard to predict when
it will or won't show up a problem.) Diagnosing RAM faults without a
real RAM tester is just Not Fun...
> Gradually got worse over time, and also while playing a game until it
> crashed.  Tried it in my sisters PC and the same symptoms.  I didn't
> bother trying to figure out the cause, but just assumed it was bad RAM.
Well, since the RAM isn't replaceable on a graphics card, I guess it
really just boils down to "does this graphics card work properly or not?"
http://blog.orphi.me.uk/
Date: 18 Aug 2008 11:16:52
Message: <op.uf28qdkq7bxctx@e6600>
On Mon, 18 Aug 2008 15:43:22 +0200, Invisible <voi### [at] devnull> wrote:
>>  4. Hardware fault on the graphics card (eg bad RAM)
Not if it has been overheating.
Have you checked the temperature of the video RAM?
FE
Date: 18 Aug 2008 11:25:25
Message: <48a99465@news.povray.org>
True, but since the GPU generates far more heat than a block of RAM does...
I don't have a way to do that.
Date: 18 Aug 2008 11:36:51
Message: <op.uf29nnnl7bxctx@e6600>
> does...
The GPU also has far better cooling. Modern high-performance RAM can get
rather hot, particularly video RAM.
Try touching a VRAM chip (very briefly) while the game is running.
FE
Date: 18 Aug 2008 11:39:49
Message: <48a997c5$1@news.povray.org>
>> does...
Well, if they don't bother fitting cooling to a component, that
presumably means they don't think it's necessary. ;-)
Wouldn't simply having the case open radically alter the operating
temperature of the components inside? ;-)
Date: 18 Aug 2008 11:48:29
Message: <48a999cd@news.povray.org>
scott wrote:
> Actual chip core temperature of 55 degrees seems fine to me,
Compare it to your CPU temperature. I dunno about my GPU, but my CPU is
close to 55 just sitting idle.
Date: 18 Aug 2008 11:53:11
Message: <op.uf3aexz77bxctx@e6600>
>>> does...
>> get rather hot, particularly video RAM.
It can also mean that they chose not to include VRAM coolers because it is
cheaper that way. Whether they are necessary or not depends on many
factors outside the control of video card designers. Also, simply having a
cooler is not the same as having an effective cooler.
It can change the temperature, but not radically, unless you are talking
about the video card casing. In any event I doubt you could get an
accurate temperature reading using only your fingertip under any
circumstances. The point of the exercise is simply to get a feel for how
hot those things get.
FE
Date: 18 Aug 2008 11:53:34
Message: <48a99afe$1@news.povray.org>
Date: 18 Aug 2008 11:54:24
Message: <48a99b30$1@news.povray.org>
Ooo... Maybe I should use my IR thermometer? :-D
