POV-Ray : Newsgroups : povray.off-topic : Being tactful Server Time
16 May 2026 15:16:48 EDT (-0400)
  Being tactful (Message 11 to 20 of 33)
Subject: Re: Being tactful
Date: 31 Jul 2008 09:38:25
Message: <4891c051$1@news.povray.org>
> Track Changes is already turned on. What I need to do is somehow
> comprehend the rat's nest of comments and alterations that are already
> there, and figure out how to add my own comments. (And, frankly, given
> that most of my comments aren't like "this sentence is should be
> rephrased" but more "this entire document is fundamentally wrong", it's
> not obvious where to put such comments...)
Draw a text box over the top and put it in Arial size 64 bold red.  That
should do it.
Date: 31 Jul 2008 09:57:16
Message: <4891c4bc$1@news.povray.org>
>> it's not obvious where to put such comments...)
> should do it.
Sir, I like your thinking. ;-)
Not sure whether this could be considered in any way "tactful" though...
http://blog.orphi.me.uk/
Date: 31 Jul 2008 10:13:25
Message: <4891c885$1@news.povray.org>
Invisible wrote:
> For anyone who's interested...
> 1. They want to keep backup tapes (even differentials) forever. (No
> regulations require this.)
Ask why they want to do this.  You were not in the meeting where they
decided to do this.  They should be happy to tell you.
> 2. They want to allow the vagaries of the Gregorian calendar and its
> lack of synchronisation with the 7-day week affect when our backups do
> and don't happen.
Ask why?
> 3. They want to keep the weeks' tapes in the server room until the end
> of the week.
Provide your observations about the potential risks to this choice, and
the benefits of alternatives.
> 4. They want to verify that tape restoration works by restoring a
> standardised, unchanging 0.09 KB file and performing a visual inspection
> to check that it "looks the same". (In fairness, if the backup software
> says it's restored, you can be 99% sure it's fine. Usually if there's a
> problem the software will complain that it "can't" restore the file,
> rather than restore gibberish. But even so...)
Be nice, and give constructive feedback.
> 5. The order in which tapes are run is not clearly described. In fact,
> the relevant section is utterly incomprehensible. Surely *they* know
> what they meant - but *I* haven't got a clue!
Ask for clarification.
> 6. Similarly, there's a new form to fill out - but I don't understand
> why, what does on it, or when it's meant to be done.
Ask and you shall receive.
> 7. The procedure talks about "software backups". As most of you won't
> know, the regulations make a distinction between "backups" and "archive
> copies", and this document is confablating the two. The result is a most
> inappropriate procedure, which is outside the scope of the document anyway.
Point out the confusion and ask for clarification.
> 8. Did I mention yet that THIS PLAN IS CRAZY?!
Yes but you fail to explain why it is crazy.
Date: 31 Jul 2008 11:08:50
Message: <4891d582$1@news.povray.org>
Include an estimate for the cost of tapes for one year of backups, as
well. Don't forget the cost of storing them securely off-site.
>> and don't happen.
> Ask why?
That honestly doesn't seem too problematic to me, unless you want to
utterly automate the backups. Given you have to be there to change
tapes, have a script that does the first-of-month backup and another
that does the friday-backup, for example.
I can even understand why they might want such a thing, if it makes it
easier to find files from a particular day in a long collection of backups.
>> of the week.
Also point out the cost of buying a secured fireproof media safe big
enough to hold a week's worth of backup tapes. (Hint: they aren't
cheap.) Note that a fireproof safe that will keep tapes safe isn't the
same as a fireproof tape that will keep paper safe.
>> inspection to check that it "looks the same". (In fairness, if the
>> backup software says it's restored, you can be 99% sure it's fine.
>> Usually if there's a problem the software will complain that it
>> "can't" restore the file, rather than restore gibberish. But even so...)
Again, shouldn't be hard. Ask if you can back up the file then use an
automated comparison rather than a visual comparison to make sure it
worked.
Exactly, yes. Then, create a chart for a couple months of backups, and
include it and say "please check that I have correctly paraphrased your
instructions."  Then follow the chart if they say it's OK.
Yeah, these don't seem like WTF problems as much as "we didn't write
down everything we talked about".
Date: 31 Jul 2008 11:19:47
Message: <4891d813@news.povray.org>
hundred pounds per year.
Interestingly, I worked out that based on the dimensions of an LTO tape
[not sure if this is with or without case] you can store enough takes in
1 m^2 for 360 years of backups. :^}
Neither of these arguments look particularly compelling. It's more the
fact that there is ABSOLUTELY NO REASON TO DO THIS that annoys me...
>>> do and don't happen.
>> Ask why?
> That honestly doesn't seem too problematic to me.
I just dislike having the backup frequency vary at random, that's all.
The idea of keeping hold of these backups is so that we can go back. I'd
really hate to say "gee, I can't restore that file because that
particular month was a day longer than the others".
> worked.
I suggested MD5 hashes or something would be a good idea. I even
suggested a procedure for using 'em...
>>> fact, the relevant section is utterly incomprehensible. Surely *they*
>>> know what they meant - but *I* haven't got a clue!
That's the amusing part - there *is* a chart in the document! It just
doesn't make any *sense*. :-/
Highly likely. But hey, that's why we review these things...
Date: 31 Jul 2008 11:54:08
Message: <4891e020$1@news.povray.org>
It sounds to me like they lack an understanding of "archival" vs.
"backup".
>> and don't happen.
> Ask why?
I'm trying to remember if this is how the old Palindrome system worked -
it used a Grandfather-Father-Son backup scheme that is common in the
mainframe world, and while Palindrome used our calendar for its schedule,
it may be a variation of this that doesn't is what they're using.
>> of the week.
ISTR this is typically done this so you could do restores of individual
files; if you needed to restore the entire system, you'd have to pull the
last full backup from offsite storage.  It depends on the value of the
data if its lost.
>> Usually if there's a problem the software will complain that it "can't"
Agreed.  That said, doing a restore is much better than depending on the
tape drive's report during the backup of problems.  I've been burned by
that - it said data was being written, but it was unreadable due to tape
errors (that was old DAT technology years ago, so the newer stuff is
probably better, but I'd still trust at least a read with error checking
of the tape over any reporting that comes back during the backup).
Just Invis' description sounds like GFS style backups.  It's a style that
some people find difficult to describe.
Jim
Date: 31 Jul 2008 12:05:33
Message: <4891e2cd$1@news.povray.org>
You're going to store an entire set of backups on 5 or 10 tapes?  Aren't
you backing things up every week, or every day?
Only if you fill the tapes. And a cubic meter of media safe storage is
pretty expensive.
No, but you should (a) ask why they want to do this (as in, "please
describe for me when you might want to access backups this old, that I
might work out a way of labeling the tapes to make it easy to find what
you're looking for") and (b) point out that they do indeed need to
budget a thousand pounds to buy tapes and storage.
See above: "when might you want to go back to these old tapes?" when
they answer "how should we handle the situation when the month is a day
longer, and we didn't make a back up that day?"
If you phrase everything as a reasonable question, it's more difficult
to get upset at the person asking. (Not impossible, mind; see the "shoot
the messenger" syndrome.)
>> worked.
What's wrong with "comp"?  Or just a little program to read two files
and compare the contents, if that's what they're really worried about?
Well, ask them to express the chart as a calendar, since you don't
understand what it means. Or otherwise ask them what you're confused
about. If there's contradictory information in the chart, come up with
an example that matches both contradictory elements and ask what the
answer is, after pointing out that one element in the chart says yes and
the other says no.
Date: 31 Jul 2008 12:50:14
Message: <4891ed46$1@news.povray.org>
http://en.wikipedia.org/wiki/Backup_rotation_scheme
I didn't know GFS did backups, other than to other machines. Unless
you're talking about a different GFS. :)
Date: 31 Jul 2008 13:39:48
Message: <4891f8e4$1@news.povray.org>
>> - it used a Grandfather-Father-Son backup scheme that is common in the
>> schedule, it may be a variation of this that doesn't is what they're
>> using.
That's the one.
>> that some people find difficult to describe.
Yeah, Grandfather-Father-Son. ;-)
Jim
Date: 31 Jul 2008 13:41:19
Message: <4891f93f$1@news.povray.org>
Oh. Duh. Right.
