POV-Ray : Newsgroups : povray.off-topic : Random C craziness Server Time
14 May 2026 02:06:58 EDT (-0400)
  Random C craziness (Message 5 to 14 of 34)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Random C craziness
Date: 24 Jul 2008 08:27:06
Message: <4888751a@news.povray.org>
>> cont is a pointer to a function that is expected to return a pointer
>> to a function.  The code here causes a series of functions to be
>> called, each one specifying another function to be called afterwards
>> by returning the address of the function to be called.
> I was thinking the same, but I can't seem to find the right type
> definition to make it work without casting to and from void*... Which is
> apparently illegal
This is example code, so it might not be literally runnable... (It might
be simplified somewhat.)
> I'm not too comfortable with function pointers though, so it's likely
> that I'm missing something here... Any hints?
Don't look at me! ;-)
http://blog.orphi.me.uk/
Date: 24 Jul 2008 09:07:24
Message: <48887e8c$1@news.povray.org>
>> is apparently illegal
Does it still provide the declaration of cont, by any chance?
Vincent
Date: 24 Jul 2008 13:19:46
Message: <op.ues3q8fh7bxctx@e6600>
On Thu, 24 Jul 2008 14:24:51 +0200, Vincent Le Chevalier
> apparently illegal
> (http://www.parashift.com/c++-faq-lite/pointers-to-members.html#faq-33.8)
It is illegal because a 'void *' is a data pointer, not a function pointer.
On a related note, we do not know if the original code was supposed to be
standards-compliant or not, nor if it was supposed to be C or C++.
> Here's what I ended up with:
[...snipped...]
The "right" way to do it, assuming C++:
http://www.gotw.ca/gotw/057.htm
FE
Date: 24 Jul 2008 13:39:06
Message: <4888be3a$1@news.povray.org>
> be standards-compliant or not, nor if it was supposed to be C or C++.
Ment to be ANSI C (not C++).
Date: 25 Jul 2008 04:48:00
Message: <48899340$1@news.povray.org>
Invisible wrote:
> So cont points to a zero-argument function that returns a zero-argument
> function? And this loop just calls it repeatedly?
Assuming TRUE is a value that always returns non-zero, yes. The code itself
appears to implement a state machine.
Of course, this being C, 'TRUE' could be a macro that expands to a function
 that returns a value and thus the loop need not be infinite. It could even
expand to a variable with a decrement or increment operator. Or really
anything - if the code were presented to someone as part of an computer
science exam, for example, they would probably be expected to pick that
possibility up. In the real world, no programmer would ever do something
that mean with a macro called TRUE. Right? :-)
-- Chris
Date: 25 Jul 2008 04:53:42
Message: <48899496$1@news.povray.org>
More exactly: It's a workaround for C's lack of lack of GOTO.
[This fragment appears in the output of a compiler that's using C as
"portable assembly".]
Hey, I found this cool site, it's called The Daily WTF... ;-)
Date: 25 Jul 2008 05:18:38
Message: <48899a6e@news.povray.org>
> [...snipped...]
Thanks for that!
Vincent
Date: 25 Jul 2008 08:56:37
Message: <4889cd85@news.povray.org>
  Except that C does have goto.
Date: 25 Jul 2008 08:59:08
Message: <4889ce1c@news.povray.org>
  Actually there are other ways for the loop to end. For instance, the
function being called could execute an exit() call.
  (Another less fancy way would be to return a null pointer from the
function, in which case the program will end with a segmentation fault.)
Date: 25 Jul 2008 09:00:04
Message: <4889ce54@news.povray.org>
Ooo, really?
In that case, I have *no clue* why they did it this way...
Oh, wait, maybe I do... Can you use GOTO to jump to a *pointer*? Or only
a literal label?
