POV-Ray : Newsgroups : povray.off-topic : Random C craziness Server Time
9 Feb 2026 21:34:34 EST (-0500)
  Random C craziness (Message 21 to 30 of 34)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: Random C craziness
Date: 26 Jul 2008 15:39:36
Message: <488b7d78@news.povray.org>
Chris Cason wrote:
> In the real world, no programmer would ever do something
> that mean with a macro called TRUE. Right? :-)
There was an entry over at the Daily WTF in which someone posted code,
written by another person, containing this:
#define TRUE 0
#define FALSE 1
I swear that I am not making this up.
John
Date: 26 Jul 2008 15:45:22
Message: <488b7ed2@news.povray.org>
Vincent Le Chevalier wrote:
> John VanSickle a écrit :
>> Invisible wrote:
>>> Can somebody interpret this for me?
>>>   while (TRUE) { cont = (*cont)(); }
>>> What on earth...?
>> cont is a pointer to a function that is expected to return a pointer
>> to a function.  The code here causes a series of functions to be
>> called, each one specifying another function to be called afterwards
>> by returning the address of the function to be called.
> I was thinking the same, but I can't seem to find the right type
> definition to make it work without casting to and from void*... Which is
> apparently illegal
> (http://www.parashift.com/c++-faq-lite/pointers-to-members.html#faq-33.8)
Casting back and forth from void* is considered exceptionally unwise in
C++, but it's considered a great way of writing tighter code in C.
John
Date: 26 Jul 2008 15:47:39
Message: <488b7f5b$1@news.povray.org>
Warp wrote:
> Chris Cason <del### [at] deletethistoopovrayorg> wrote:
>> Of course, this being C, 'TRUE' could be a macro that expands to a function
>>  that returns a value and thus the loop need not be infinite.
>   Actually there are other ways for the loop to end. For instance, the
> function being called could execute an exit() call.
>   (Another less fancy way would be to return a null pointer from the
> function, in which case the program will end with a segmentation fault.)
Or return a pointer to the exit() function, which is the same as above.
John
Date: 26 Jul 2008 16:31:44
Message: <488b89af@news.povray.org>
  In fact, for example casting method pointers to void* and back is
undefined behavior and in no way guaranteed to work. (And, in fact,
in many compilers method pointers are as large as two regular pointers,
and thus casting to void* would drop information.)
Date: 26 Jul 2008 17:30:00
Message: <web.488b96f97f33a1c3de7267810@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> The idea here is that we jump to one label, then jump to another, then
> jump to another, never returning to the "caller".
> If we implement this using C functions that never return, an unbounded
> amount of stack gets eaten.
> Hence, they arranged for each function to *return* the function it would
> like to jump to next, rather than actually jumping to it, and the loop I
> posted is apparently the magic incantation that implements the jumping.
Yes, indeed.
http://en.wikipedia.org/wiki/Tail_recursion#Implementation_methods
I take it that you were looking at the C output of GHC, right?  Haskell relies
on tail-recursion as much as any other functional language, as Scheme.  The
method it is implemented underneath is as a trampoline.
Date: 28 Jul 2008 05:13:26
Message: <488d8db6$1@news.povray.org>
> #define TRUE 0
> #define FALSE 1
I remember it well...
http://blog.orphi.me.uk/
Date: 28 Jul 2008 16:21:44
Message: <488E2A94.3030104@hotmail.com>
> #define TRUE 0
> #define FALSE 1
Probably Unix convention?
http://en.wikipedia.org/wiki/True_(Unix)
http://en.wikipedia.org/wiki/False_(Unix)
Date: 28 Jul 2008 16:35:08
Message: <488e2d7c@news.povray.org>
>> #define TRUE 0
>> #define FALSE 1
Ah yes - return code 0 = OK, any other code = failure.
What have we learned here? That using integers to represent Booleans is
a Very Bad Thing. :-P
Date: 28 Jul 2008 16:56:21
Message: <488e3274@news.povray.org>
> >> #define TRUE 0
> >> #define FALSE 1
  C actually distinguishes between TRUE/FALSE and EXIT_SUCESS/EXIT_FAILURE.
They shouldn't be confused nor mixed.
Date: 29 Jul 2008 11:20:42
Message: <488f354a$1@news.povray.org>
Warp wrote:
>   Because "while(1)" is a common idiom, and avoids the ugly goto.
Either that or for(;;) { ... }
