POV-Ray : Newsgroups : povray.off-topic : Random C craziness Server Time
9 Nov 2026 20:51:24 EST (-0500)
  Random C craziness (Message 11 to 34 of 34)
<<< Previous 10 Messages Goto Initial 34 Messages
Subject: Re: Random C craziness
Date: 25 Jul 2008 05:18:38
Message: <48899a6e@news.povray.org>
Fredrik Eriksson a écrit :
> On Thu, 24 Jul 2008 14:24:51 +0200, Vincent Le Chevalier
> <gal### [at] libertyallsurfspamfr> wrote:
>> Here's what I ended up with:
> [...snipped...]
> The "right" way to do it, assuming C++:
> http://www.gotw.ca/gotw/057.htm
Thanks for that!
Vincent
Date: 25 Jul 2008 08:56:37
Message: <4889cd85@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> More exactly: It's a workaround for C's lack of lack of GOTO.
  Except that C does have goto.
Date: 25 Jul 2008 08:59:08
Message: <4889ce1c@news.povray.org>
Chris Cason <del### [at] deletethistoopovrayorg> wrote:
> Of course, this being C, 'TRUE' could be a macro that expands to a function
>  that returns a value and thus the loop need not be infinite.
  Actually there are other ways for the loop to end. For instance, the
function being called could execute an exit() call.
  (Another less fancy way would be to return a null pointer from the
function, in which case the program will end with a segmentation fault.)
Date: 25 Jul 2008 09:00:04
Message: <4889ce54@news.povray.org>
Ooo, really?
In that case, I have *no clue* why they did it this way...
Oh, wait, maybe I do... Can you use GOTO to jump to a *pointer*? Or only
a literal label?
http://blog.orphi.me.uk/
Date: 25 Jul 2008 09:01:29
Message: <4889cea9$1@news.povray.org>
I believe that is in fact what's meant to happen, yes.
...or have count() perform any other illegal program-halting action.
Date: 25 Jul 2008 09:05:47
Message: <4889cfab@news.povray.org>
> Ooo, really?
  Because "while(1)" is a common idiom, and avoids the ugly goto.
> a literal label?
  Jumping to a pointer is normally called "function call".
  Goto works only with labels.
Date: 25 Jul 2008 09:21:50
Message: <4889d36e$1@news.povray.org>
>> Ooo, really?
>> a literal label?
Yes, but jumping to a function pushes a return address onto the stack.
And they specifically don't want to do that. (Because it would use an
unbounded amount of stack.)
Date: 25 Jul 2008 09:31:58
Message: <4889d5ce@news.povray.org>
  Functions in C don't need to return anything.
Date: 25 Jul 2008 09:37:59
Message: <4889d737@news.povray.org>
	I thought that's what "lack of lack of GOTO" meant.<G>
I almost had a psychic girlfriend, but she left me before I met her.
                    /  \/  \ u e e n     /  \/  a w a z
                        >>>>>>mue### [at] nawazorg<<<<<<
                                    anl
Date: 25 Jul 2008 10:04:59
Message: <4889dd8b$1@news.povray.org>
The idea here is that we jump to one label, then jump to another, then
jump to another, never returning to the "caller".
If we implement this using C functions that never return, an unbounded
amount of stack gets eaten.
Hence, they arranged for each function to *return* the function it would
like to jump to next, rather than actually jumping to it, and the loop I
posted is apparently the magic incantation that implements the jumping.
Date: 26 Jul 2008 15:39:36
Message: <488b7d78@news.povray.org>
Chris Cason wrote:
> In the real world, no programmer would ever do something
> that mean with a macro called TRUE. Right? :-)
There was an entry over at the Daily WTF in which someone posted code,
written by another person, containing this:
#define TRUE 0
#define FALSE 1
I swear that I am not making this up.
John
Date: 26 Jul 2008 15:45:22
Message: <488b7ed2@news.povray.org>
Vincent Le Chevalier wrote:
> John VanSickle a écrit :
>> Invisible wrote:
>>> Can somebody interpret this for me?
>>>   while (TRUE) { cont = (*cont)(); }
>>> What on earth...?
>> cont is a pointer to a function that is expected to return a pointer
>> to a function.  The code here causes a series of functions to be
>> called, each one specifying another function to be called afterwards
>> by returning the address of the function to be called.
> I was thinking the same, but I can't seem to find the right type
> definition to make it work without casting to and from void*... Which is
> apparently illegal
> (http://www.parashift.com/c++-faq-lite/pointers-to-members.html#faq-33.8)
Casting back and forth from void* is considered exceptionally unwise in
C++, but it's considered a great way of writing tighter code in C.
John
Date: 26 Jul 2008 15:47:39
Message: <488b7f5b$1@news.povray.org>
Or return a pointer to the exit() function, which is the same as above.
John
Date: 26 Jul 2008 16:31:44
Message: <488b89af@news.povray.org>
  In fact, for example casting method pointers to void* and back is
undefined behavior and in no way guaranteed to work. (And, in fact,
in many compilers method pointers are as large as two regular pointers,
and thus casting to void* would drop information.)
Date: 26 Jul 2008 17:30:00
Message: <web.488b96f97f33a1c3de7267810@news.povray.org>
Yes, indeed.
http://en.wikipedia.org/wiki/Tail_recursion#Implementation_methods
I take it that you were looking at the C output of GHC, right?  Haskell relies
on tail-recursion as much as any other functional language, as Scheme.  The
method it is implemented underneath is as a trampoline.
Date: 28 Jul 2008 05:13:26
Message: <488d8db6$1@news.povray.org>
> #define TRUE 0
> #define FALSE 1
I remember it well...
Date: 28 Jul 2008 16:21:44
Message: <488E2A94.3030104@hotmail.com>
> #define TRUE 0
> #define FALSE 1
Probably Unix convention?
http://en.wikipedia.org/wiki/True_(Unix)
http://en.wikipedia.org/wiki/False_(Unix)
Date: 28 Jul 2008 16:35:08
Message: <488e2d7c@news.povray.org>
>> #define TRUE 0
>> #define FALSE 1
Ah yes - return code 0 = OK, any other code = failure.
What have we learned here? That using integers to represent Booleans is
a Very Bad Thing. :-P
Date: 28 Jul 2008 16:56:21
Message: <488e3274@news.povray.org>
> >> #define TRUE 0
> >> #define FALSE 1
  C actually distinguishes between TRUE/FALSE and EXIT_SUCESS/EXIT_FAILURE.
They shouldn't be confused nor mixed.
Date: 29 Jul 2008 11:20:42
Message: <488f354a$1@news.povray.org>
Either that or for(;;) { ... }
Date: 29 Jul 2008 11:27:01
Message: <488f36c5@news.povray.org>
...and to think people complain when a Haskell programmer writes
   fix ((1:) . scanl (+) 1)
or something... :-P
Date: 29 Jul 2008 15:39:00
Message: <488f71d4$1@news.povray.org>
Well, maybe if you're lucky. :-) Otherwise, it just goes off happily
executing whatever is at memory address zero (or whatever NULL maps to).
  Helpful housekeeping hints:
   Check your feather pillows for holes
    before putting them in the washing machine.
Date: 29 Jul 2008 17:05:51
Message: <488f862f@news.povray.org>
  I'm pretty sure POSIX or some other type of standard states that jumping
to the null pointer will always cause a segmentation fault.
Date: 29 Jul 2008 17:21:04
Message: <488f89c0$1@news.povray.org>
But not the C standard. Try it on MS-DOS, Win 3.1, AmigaDOS, a credit
card terminal, a cell phone, etc. :-)  Basically, you're saying you
can't have a POSIX-compliant system without memory mapping, methinks.
But C is used in particular because of its primitiveness and lack of
reliance on a particular complex bit of hardware.
"The operating system is there to provide the facilities the language
designer left out."
