POV-Ray : Newsgroups : povray.off-topic : GPU rendering Server Time
29 Mar 2026 11:06:54 EDT (-0400)
  GPU rendering (Message 31 to 34 of 34)
Subject: Re: GPU rendering [98K]
Date: 23 Jul 2008 06:59:51
Message: <48870f27@news.povray.org>
> OK, so for anybody who knows about such things... Would it be feasible to
> render an Iterated Function System image using a GPU? And would it be any
> faster than using the CPU?
See attached image. That spike in the right CPU chart was where I started
the program.
I'm using the standard fern algorithm that's on the wikipedia page about
IFS.
Speed: 23.2 million iterations per second (512x512 points in parallel per
frame at 88 fps)
This is on an nVidia FX1700, if I get time I'll try it on my FX7900 tonight,
should be significantly faster.
I don't know how this compares to how fast a CPU would be, if I get time
later I will try out the same on the CPU for comparison.
The hardest bit was actually getting a good random number generator inside
the pixel shader.  What I ended up doing was to generate a big texture full
of random numbers at the start of the code, then in the pixel shader it
generates an xy coord based on a number of things and looks up the value in
the random texture at that position.  Seems to work well, because believe
me, if your random number generator is just a little bit wonky, the fern
doesn't look very nice at all!
Download 'image1.jpg' (99 KB)
Preview of image 'image1.jpg'
Date: 23 Jul 2008 07:16:18
Message: <48871302$1@news.povray.org>
> started the program.
Sweet! That looks pretty awesome.
Next step: realtime animation. ;-)
http://blog.orphi.me.uk/
Date: 24 Jul 2008 03:38:07
Message: <4888315f$1@news.povray.org>
> frame at 88 fps)
> tonight,
OK so my FX7900 wasn't that much faster (37 million per second), despite the
specs indicating about 5x the pixel throughput.  The speed bottleneck is
obviously somewhere else in this code then, probably in the texture lookup
in the vertex shader, I guess that isn't very optimised yet.  If I had a
DX10 card I could use a geometry shader to cut the number of texture lookups
and vertex shader calls by a factor of 4, that would definitely speed things
up significantly.
Using a single core of an Intel E6400 I get 11 million iterations per second
(C++, but with no graphics).
Also it took me like 5 minutes to write the CPU code from scratch, but
several hours to get the GPU code working correctly!
Date: 24 Jul 2008 03:52:47
Message: <488834cf$1@news.povray.org>
>> frame at 88 fps)
>> tonight,
> the specs indicating about 5x the pixel throughput.  The speed
> bottleneck is obviously somewhere else in this code then, probably in
> the texture lookup in the vertex shader, I guess that isn't very
> optimised yet.  If I had a DX10 card I could use a geometry shader to
> cut the number of texture lookups and vertex shader calls by a factor of
> 4, that would definitely speed things up significantly.
Ooo... profiling GPU code... THAT SOUNDS FUN! o_O
> second (C++, but with no graphics).
Mmm, OK.
Heh. All hail the day when GHC has a GPU backend! ;-)
(Mind you, apparently Roman Cheplyaka is working on a physics engine
using Data Parallel Haskell as a Google SoC project. Apparently rigid
body collision is working already...)
