POV-Ray : Newsgroups : povray.off-topic : code readability Server Time
1 Mar 2026 19:27:38 EST (-0500)
  code readability (Message 1 to 10 of 73)
Subject: code readability
Date: 26 Jun 2008 14:11:00
Message: <4863dbb4$1@news.povray.org>
I, for one, find it much easier to read C++ code which is braced like this:
if(somecondition == 0)
    // do some stuff
else
    // do something else
As opposed to
if(somecondition == 0) {
    // do some stuff
else {
Why doesn't the rest of the world understand that?
Subject: Re: code readability
Date: 26 Jun 2008 14:16:18
Message: <4863dcf2@news.povray.org>
  Because Brian Kernighan and Dennis Ritchie used the latter style in their
famous book, and because they are God, every C (and consequently C++) coder
must obey the same standard.
Date: 26 Jun 2008 14:29:26
Message: <4863e006$1@news.povray.org>
Different languages encourage different indentation schemes, based on
the details of syntax.  I use different indenting for C and Pascal, for
example.
I tend to prefer indenting where the things in one column are
sequentially executed. So if I have an if, an assignment, and a while
loop, I'll tend to want to indent things so there are only three lines
in that column, rather than including all the noise words. E.g.,
void codestuff() {
   int i;
   if (i == j) {
      do this thing;
      do that thing;
   j += 1;
   while (j < 23) {
      do another;
void morecode() {
Having things like switch (especially with fallthrus) and else sometimes
messes up the patterns, depending on just how you manage it. I figure
the fewer rules you need to learn to indent, the easier it is to learn it.
if (i == j) {
   stuff;
   morestuff;
} else if (yadda) {
   another stuff
   extra stuff;
} else {
   thing one
   thing two
That looks kind of ugly, but it also stands out as matching "my" rules
in many ways. Doing it as
if (i == j) {
   stuff
else if (j == 3) {
   stuff
else {
   thing
looks nicer, and also kind of works out with the "things in the same
column should be executed sequentially" rule. It also looks nicer when
you have "begin" and "end" instead of { and }  :-)
  Helpful housekeeping hints:
   Check your feather pillows for holes
    before putting them in the washing machine.
Date: 26 Jun 2008 14:40:07
Message: <4863e287@news.povray.org>
"Halbert" <hal### [at] gmailcom> wrote in message
news:4863dbb4$1@news.povray.org...
this:
>     // do some stuff
Whereas I find the first far too spread out to be able to read easily and
use the second as my standard code layout in C-like languages
Because the rest of the world doesn't necessarily agree with you?
Date: 26 Jun 2008 15:02:06
Message: <4863e7ae@news.povray.org>
  Compactness does not imply readability. On the contrary.
Date: 26 Jun 2008 15:14:12
Message: <4863ea84@news.povray.org>
news:4863e7ae@news.povray.org...
I never said it did.
I said that I find the first too spread out to read easily and that I prefer
the second as *I* personally find it easier to read.
If you prefer the former, more power to you. Just don't expect me to code
the same way.
Date: 26 Jun 2008 15:28:43
Message: <4863edeb$1@news.povray.org>
It's true that its only a preferance I personally have. The rest of the
world doesn't have to agree with me. I just like the way the braces all line
up and make visually clear the beginning and end of each code block. Its
easier for me to see than matching of the ending brace with the associated
expression at the top of the block.
I have been quietly living with that gripe in the back of my mind for the
last 18 or 19 years. Now that it's out in the open, I feel much better.
Date: 26 Jun 2008 15:39:00
Message: <4863f054@news.povray.org>
news:4863edeb$1@news.povray.org...
Everyone's entitled to their prefered way of doing things. Life would be
boring if we all agreed on everything
Good.
Date: 26 Jun 2008 15:41:01
Message: <4863f0cd@news.povray.org>
> Life would be boring if we all agreed on everything
  I disagree.
Date: 26 Jun 2008 15:47:59
Message: <4863f26f@news.povray.org>
>     // do some stuff
> else
I, for more than one, do not.
> As opposed to
>     // do some stuff
> else {
To me, the latter method is much more like POV-Ray than the first
method. I learned POV first, so I guess that's why I do it.
Since most of the code I write is never seen by another poor soul, you
won't find me bending backwards to tailor it for the "posh" crowd.
I kinda feel bad for the one guy who had to see my C++ code. At least it
was relatively short :)
Sam
