POV-Ray : Newsgroups : povray.off-topic : Quotable Server Time
2 Jul 2026 22:24:30 EDT (-0400)
  Quotable (Message 80 to 89 of 179)
Subject: Re: Quotable
Date: 2 Jun 2008 12:51:56
Message: <4844252c@news.povray.org>
Warp wrote:
> Darren New <dne### [at] sanrrcom> wrote:
>> For example, there's no known mathematical model to indicate where a
>> specific electron is, and indeed if I understand correctly, experiments
>> show there cannot be one.
>   That's a bit like being in the middle of the ocean and saying "there's
> no mathematical model which says where the water is", speaking as if the
> "water" was a point in space and you'd had to locate it at some specific
> coordinates.
>   Your statement is like that. You are starting from the assumption that
> an electron is an extremely small particle with well-defined boundaries,
> approximately equal to a mathematical point, and then you ask for a
> mathematical model to say where that point is in space. As with the
> water example, that's kind of silly.
I guess I was kind of sloppy. I was saying that there's no mathematical
model that tells you where you will find a specific electron when you
look for it in a set of places. E.g., if you shoot an electron at a
flourescent screen, there's no model (and *can* be no model) that tells
you where on the screen that electron will hit.
>   What the mathematical model *can* do is to give a distribution function
> which tells how the electron is distributed in space (a bit like a
> function which tells how the water is distributed, except that with
> the electron the "density" of the "water" is not constant).
No, actually, it tells you the likelihood of finding it at any
particular place, were you to look.
There's another distribution function that tells you the likelihood it's
in a particular place if you *don't* look.
When you put those two together, you get the two-slit experiment.
>   It's not like you could shoot an electron to some direction, and then
> the electron suddenly hits the other side of the Earth (or the solar
> system). It hits a quite accurately calculable place.
No, it doesn't. The probability of hitting anywhere in particular is an
infinite sum of complex (as in, real+imaginary) probabilities.
Yes, it can actually hit the other side of the Earth. It can also hit a
week before you shoot it. Very unlikely, but possible.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 2 Jun 2008 12:53:29
Message: <48442589@news.povray.org>
John VanSickle wrote:
> I wouldn't say that it is truly random, but merely that predicting the
> outcome of any interaction requires information that is presently not
> available.
You would be incorrect. Google on "Bell's Inequality".
> For instance, the decay of unstable particles appears to happen
> randomly, but at what appears to be a predictable rate for aggregate
> amounts of like particles.  What is likely is that the particles decay
> when they encounter certain conditions (such as a gradient in the
> electric or magnetic potential) that is high enough to overcome the weak
> internal cohesiveness of the particle, causing it to come apart.
That's the "hidden variable" theory. It has been disproven, multiple
times and with hundreds of different experiments. Boggling, isn't it?
Date: 2 Jun 2008 12:54:42
Message: <484425d2@news.povray.org>
> No, it only interferes with other electrons. The electrons it interferes
> with are electrons from other times. There's always a possibility that
> it lands at any particular place. Why is it any stranger that it
> interferes with electrons in the future than it is it interferes with
> itself?
  Because time travel doesn't exist?
Date: 2 Jun 2008 13:02:20
Message: <4844279c$1@news.povray.org>
Mueen Nawaz wrote:
>     There's the whole issue of "renormalization" to deal with infinities
> in physics. I won't go into any detail as I've never formally studied
> it. But it's another often cited example of "fishy mathematics".
I understand it enough to explain informally. When you're calculating
the probability of an event, you have to take into account every way
that event could occur, and add them up. So maybe the photon leaves the
candle and hits the film. Or it leaves the candle, splits into an
electron and positron, which then later recombine into a photon, which
hits the screen. Or it splits into an electron and positron, and the
positron goes off to the Sun back in time to combine with an electron
there, which makes it turn into a photon which happens to come back to
Earth which strikes the electron which pushes it into the wall which
emits a photon which hits the film. And so on.
So basically, you're adding up more and more events of lower and lower
probability. And it turns out that if you add them all up, you get
infinite probability everywhere.
But if you stop at, say, 10^-50 probability, and then renormalize
(something like divide by 10^-50), you get a number. And if you stop at
10^-60 and then renormalize (something like divide by 10^-60), you get
the same number. As long as you renormalize to where you stopped, you
get the same number. But nobody knows why you have to stop, and there's
so far no physical reasoning as to where you have to stop.
Speculation is that space is actually quantum, so the mathematics of
"real numbers" breaks down because they can get smaller than reality.
Which is where the Plank's constant seems to come in - speculation that
it's describing the quantum of size.
Date: 2 Jun 2008 13:03:13
Message: <484427d0@news.povray.org>
> Warp wrote:
> >   So when the electron hits the sensitive film *after* it has passed the
> > slits, it goes back to the past and changes it so that it goes through
> > only one of the slits after all?
> No. It either interferes with itself or not. You're assuming the only
> way it can interfere with itself is to go through both slits. There's no
> evidence that's the case, and much evidence that it isn't.
  So why does it interfere with itself when there are two slits but not
when there is only one? If it was just one regular physical macroscopical
particle it wouldn't matter how many slits there are: If it goes through
one of them, it just goes through one of them, that's it. It doesn't even
"know" that there are other slits.
  However, when there are two slits, the electron passes through and starts
interfering with itself, as if it has passed through both and changed
direction in different ways.
  How else can this be explained? How does the electron "know" that there's
another slit so that it "knows" to start interfering with itself, other than
actually going through the other slit as well?
  (I believe this has something to do with wave-particle duality: In the
double-slit experiment the wave nature of the electron shows up: The wave
goes through both slits and starts interfering with itself.)
> >   So you are saying that, even though the only possible explanation for
> > interference patterns is that the electron passed through both slits,
> > there's still no evidence of that?
> Yes. What makes you think that the only *possible* explanation is that
> the electron passed through both slits?
  What is the other explanation?
> >   If there's "no evidence", what do you call the interference pattern?
> > "Non-evidence"?
> Interference.
  The interference can be explained with the electron passing through both
slits at the same time. Ergo the interference is evidence of that happening.
(Note that "evidence" is not the same thing as "proof".)
Date: 2 Jun 2008 13:03:22
Message: <484427da@news.povray.org>
By the way, this is why it's called "quantum" physics. :-) Because it's
*not* a wave - there *is* a well-defined particle in a particular place.
Date: 2 Jun 2008 13:07:32
Message: <484428d4@news.povray.org>
>         There is a non-zero probability that this can happen.
  I bet the probability is so small that it hits the barrier of some
physical constant (Planck maybe?)
Date: 2 Jun 2008 13:12:54
Message: <48442a15@news.povray.org>
  Assuming the particle *is* at some specific location at any given time
instead of being distributed in space.
  I don't believe in the time travelling. As for the location, I assume
the probability of it hitting the other side of the Earth is so small that
some physical constant prevents it.
Date: 2 Jun 2008 13:17:59
Message: <48442b46@news.povray.org>
  Actually "quantum physics" means that everything is quantified. That is,
there's a minimum amount of everything (for example electric charge and
mass), and everything is an integer multiple of that amount. You just can't
have eg. half of the electric charge of an electron, for example.
  Waves are also quantified for the same reason: There's a minimum amount
of amplitude, for example, and all amplitudes are integer multiples of
that amount.
  These "quants" behave oddly. Sometimes they behave like particles,
sometimes they behave like waves, and sometimes they behave like both
at the same time. Different measurements of the exact same quant can
show wildly different behavior in this respect. (One experiment will
clearly show that light behaves like a wave and not like a stream of
particles, while another experiment will show the exact opposite.)
Date: 2 Jun 2008 13:57:09
Message: <a3d84416qgsj31tpo7sngm2rlvdhqn5rte@4ax.com>
On Mon, 02 Jun 2008 09:29:24 -0700, Darren New <dne### [at] sanrrcom>
wrote:
>Stephen wrote:
>> Indeed, a straight edge and compass. What more do you need?
>A ruler?
No, I don't think so. ;)
Regards
