POV-Ray : Newsgroups : povray.off-topic : Quotable Server Time
2 Jul 2026 12:14:22 EDT (-0400)
  Quotable (Message 41 to 50 of 179)
Subject: Re: Quotable
Date: 1 Jun 2008 16:25:40
Message: <484305F2.7010805@hotmail.com>
Chambers wrote:
> andrel wrote:
>> A couple of remarks:
>> - According to that most reliable source of wikipedia, it was Truman
>> that fired MacArthur for disagreeing with him. So I would be surprised
>> if he did not try to portrait him as an idiot. That is irrespective of
>> whether he was right or wrong. Simply the case that a president fires
>> a famous general dictates that the president should convince the
>> public that he was much better equipped than the general.
> Basically, it all came down to the fact that MacArthur wanted to go out,
> fight, and win WWIII.
> Truman did everything in his power to avoid an actual war - he thought
> two World Wars were more than enough, and would rather see the conflict
> played out on a smaller scale.
Indeed, just what Truman would say ;)
> The Korean War (and, eventually, the
> Vietnam War) were direct results of his policies in that respect, as was
> the Cold War in general.
> People blame our leadership for those confrontations, but fail to
> realize that the alternative was all out war on a scale similar to, if
> not larger than, WWII.
> ...Chambers
Date: 1 Jun 2008 16:27:58
Message: <4843064e$1@news.povray.org>
>  Ever heard of the Banach-Tarski paradox? A solid ball in 3-dimensional
> space can be split into several non-overlapping pieces, which can then be
> put back together in a different way to yield two identical copies of
> the original ball.
I hadn't heard of that one, but it makes perfect sense in a topology
context.
In that context "split" really means a 1:2 mapping of spaces.
Cut the ball in half, then in the two hemispheres the new equator plane
is a curve from the lip that follows a 0.5*y scaled sphere, from there
just map the curved planes back to flat to get two spheres.
Since we're talking about a mapping, not a real object, there's no
conservation of volume, a sphere is a sphere, no matter what the size.
The paradox is that the more mathematicians learn,
the less they are able to explain clearly.
Date: 1 Jun 2008 16:29:14
Message: <mk1644d2dnjndmq5f83h4ijntdtbe6cne6@4ax.com>
On Sun, 1 Jun 2008 13:34:22 -0600, "somebody" <x### [at] ycom> wrote:
>"Darren New" <dne### [at] sanrrcom> wrote
>> Warp wrote:
>> >   I would say that mathematics can always be used to represent reality
>> > when put in the proper context.
>> The fascinating thing to wonder about is ... why is this so?
>Easy. Mathematics can represent *anything*, since you get to make up your
>own axioms.
Oh! You let the secret our :)
Regards
Date: 1 Jun 2008 16:34:45
Message: <48430814.6060609@hotmail.com>
Darren New wrote:
> Warp wrote:
>>   I'm sure if you asked a physicist specialized in quantum mechanics he
>> would say that life would probably not be possible without the wild
>> uncertainties of quantum phenomena (such as particles physically being
>> at multiple locations at the same time).
> I imagine that life based on DNA and chemistry and such wouldn't work
> the same way.
It wouldn't work at all. Let's put it this way: if the Universe was as
complicated as the most inventive physicist can image, it would still
not be complex enough for life to develop. Hmm, there might be a good
sig in that for this physicist.
Physics is incompatible with life.
Date: 1 Jun 2008 17:18:25
Message: <48431221$1@news.povray.org>
> own axioms.
Now try inventing a *consistent* set of axioms. ;-)
http://blog.orphi.me.uk/
Date: 1 Jun 2008 17:53:41
Message: <48431a65@news.povray.org>
> context.
  That doesn't work. The volume of the sphere cannot be modified by a
simple change in topology. You cannot simply change the topology and
then calculate the volume as if you hadn't. You have to calculate the
volume using the *new* topology, not the old one.
  Besides, if what you say was true, the same trick would work with a
2-dimensional circle, but it has been proven that it doesn't.
  And besides, the original setup happens in regular cartesian coordinates,
without any change in topology.
  You clearly haven't understood the theorem.
Date: 1 Jun 2008 18:53:48
Message: <4843287c$1@news.povray.org>
There's another cool one, I don't remember what it's called, that proves
you can chop up a filled-in circle (I.e., a 2D slice thru a ball,
whatever you call that) and then put it back together again as a perfect
square, with no overlaps and no gaps.
Personally, I can't imagine how that can be possible, but you can
apparently do it with sufficiently many cuts.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 1 Jun 2008 18:57:06
Message: <48432942$1@news.povray.org>
Warp wrote:
>   But their simultaneous location in more than one place can be inferred
> by other side-effects.
Nope. When you actually measure it, it's only going thru one slit.
> For example a single electron can pass through two
> slits at the same time, interfering with itself after doing so.
Not as such. Yes, you get interference patterns. No, as far as I know,
there's no evidence to suggest it goes through both slits. Nobody is
quite sure how it works, but there's no measurement that when you say
"where is the thing" it ever gives you more than one answer.
That's the funky part. It *isn't* intuitive.
Indeed, there are all kinds of experiments (like closing one slit too
close to the photon for it to know that the slit was closed, or
something like that) that indicate that you can't treat the situation
like the photon or electron goes through both slits at once.
Date: 1 Jun 2008 19:00:36
Message: <48432a14$1@news.povray.org>
> own axioms.
Except for two things: all the equations are actually pretty simple,
none of them seem to change.
It's not really the case you can represent *anything* with mathematics.
You cannot represent God (pretty much by definition of God), and you
cannot represent a partially-inconsistent system (one that is
inconsistent sometimes but not other times, or in some places but not
other places). Just as a couple of offhand examples.
Date: 1 Jun 2008 21:01:25
Message: <48434665$1@news.povray.org>
your
> > own axioms.
Simplicity is in the eye of the beholder.
That's because "god(s)" are not anythings. When one shows that
they/he/she/it is, there's no reason why you won't be able to model
they/he/she/it.
Then you incorporate time into your equations/model.
> other places).
Then you incorporate places into your equations/model.
Isotropy/homegeneity of space/time has nothing to do with whether
representation is possible. Since observation can be thought of as a
representation, anything observable automatically has one representation at
least. Whether that model can be simplified, and can have predictive powers
or not is the question, and if it has redundancy, it can. A reality that can
not be expressed with a simplified model, would, in essence, be random in
*all* aspects (again, redundancy leads to prediction). I cannot imagine how
intelligence of any sort can arise in such a reality.
