POV-Ray : Newsgroups : povray.off-topic : A small puzzle Server Time
10 Jun 2026 09:54:21 EDT (-0400)
  A small puzzle (Message 121 to 130 of 198)
Subject: Re: A small puzzle
Date: 23 May 2008 18:26:19
Message: <483744B7.8050304@hotmail.com>
Darren New wrote:
> scott wrote:
>> Like what? mm, cm, m and km pretty much cover most things in terms of
>> distance.
> A cm is about right. You need something about a foot, tho. Otherwise you
> get things like "he was 197 cm tall".
Yesss? your point being? FYI I do say that and find 6 feet 2 a
completely ridiculous way of measuring. There is a difference between
convenience and convention, I guess.
> Note that people really rarely use
> "yards" as a measure here. It's feet and miles, unless you're measuring
> something that's particularly sold by the yard, like cloth.
> Kilograms are too heavy and grams are too light.
Indeed and why have a basic unit and define 1000 times that as a standard?
> Liters are too big and
> centiliters are too small. Basically, the factor of 1000 in common units
> is the problem. :-)
>> And having numbers that often go over 100 for everyday temperatures
>> doesn't seem too convenient.
never had that, thank goodness.
> Having numbers that go below zero for everyday temperatures seems less
> convenient.
Also because it feels very different, i.e. cold.
>>> and because 10 isn't really divisible by many numbers.
>> But everyone knows how to divide by 10, which I think is more useful.
> Not if you're constructing something. Then you want to be able to take a
> third of it, for example. Using a duodecimal number system probably
> would have been a better idea.
> And powers of 10 work almost as poorly as powers of 12 for computers. ;-)
>> It also makes physics equations easier, with no ugly scale factors.
> No question it works better in science than everyday life.
Theoretical physics being even better with c=1 and epsilon and mu also.
Date: 23 May 2008 19:08:48
Message: <48374e80@news.povray.org>
  As andrel pointed out, measuring those ranges is less intuitive using
feet and inches because a foot is not a handy multiple of an inch.
  With metric it's at least easy to use either measure with ease: 1.97
meters or 197 centimeters. No crazy factors.
  Colloquially, at least in Finnish, it's usual to say, literally translated,
"meter ninentyseven" (possibly adding "cents" at the end) when eg. talking
about people's height.
> It's feet and miles
  That would be ok if a mile was an easy multiple of a foot.
  Too heavy and light for what? It's very common to buy eg. "400 grams of
meat", etc.
> Liters are too big and centiliters are too small.
  For what? And in cooking a deciliter is a very common measure.
> is the problem. :-)
  There are 10 millimeters in a centimeter, and 100 centimeter in a meter,
and 10 deciliters in a liter. What 1000?
> > temperatures doesn't seem too convenient.
> convenient.
  I think you are artificially stretching here. Negative Celsius
temperatures are an extremely intuitive and easy to understand measurement.
Heck, usually just knowing the sign of the temperature is enough to know
what you should wear (at least in context), even if that's the only thing
you get to know.
Date: 23 May 2008 19:55:49
Message: <48375985$1@news.povray.org>
Actually, it's a *handy* multiple, arguably moreso than decimal. Just
not trivial to translate between because it's not decimal. :-)
True. Of course, everyone using imperial measures already knows how many
inches are in 3, 4, 5, 6, 7, 8 and 9 feet, just like we both know how
many seconds are in an hour without sitting to calculate it out. :-)
I guess if you use abbreviations like this it becomes easier.
>> It's feet and miles
But you almost never mix feet and miles in a description, so the number
of times you convert is small. You're either working in miles (or
fractions thereof, like "go half a mile and turn left"), or in feet
(like "give me seven feet of rope").
(Altho I'm often amused that odometers measure in tenths of a mile,
constructions signs say "Lane closed 1000 feet ahead", and exit signs
say "Exit 23 in 1/2 mile". They really should make up their minds.)
> meat", etc.
I guess if you're used to that, it doesn't seem inconvenient. I'd rather
specify four of something than 400.
Or, to phrase it a different way... You have too many significant
figures there. :-)
But it's four syllables long. :-)
>> is the problem. :-)
Grams to kilograms, for example.
Hey, I'm not saying it's bad. I'm just saying *I* find it inconvenient
most of the time I'm in places that use metric. I'm just trying to
explain stuff that might make someone resist using metric, as someone
raised on imperial measurements who has spent months in countries where
they use metric, is all.
>> convenient.
I was trying to make the point that I think complaining that
temperatures go over 100 is kind of as artificial as complaining that
they go below zero. :-)
> Negative Celsius
I guess it's what you're used to. People used to metric find converting
between units is annoying. People used to imperial measurements find
having insufficient different measures annoying. :-)
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 24 May 2008 01:33:48
Message: <4837a8bc@news.povray.org>
Darren New wrote:
>> distance.
> get things like "he was 197 cm tall". Note that people really rarely use
I think this is an opinion-question, but IMO cm/m is pretty easy and
logical measurement for people. 197cm tells you that he's 3cm shorter
than a normal door, so he won't hit his head.
> Kilograms are too heavy and grams are too light. Liters are too big and
> is the problem. :-)
One packet of sugar weights one kg. One liter of milk weight nearly one
kg. 1-10 kg's are pretty normal weights in everyday life, so how is it
too heavy? It also tells you immediality that a car weights ie. the same
that 1510 packets of sugar (no wonder it needs some energy to get the
darn thing moving).
> convenient.
In below zero (C) temperatures air is dry and most of the normally-wet
places are freaking slippery. Practically I find it very useful
information in everyday life (the most important thing about outside
temparature is that is it + or - in certain times of year).
Well that's true :).
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 24 May 2008 03:40:42
Message: <4837c679@news.povray.org>
  In Finnish it's commonly abbreviated to "desi" in colloquial speech.
> >> is the problem. :-)
  One example. More examples?
  Resistance to change, that's what it is. ;)
Date: 24 May 2008 04:16:42
Message: <4837ceea@news.povray.org>
But as soon as you need to do anything with those numbers (eg adding,
dividing etc) it's much easier to use 197 cm than 6 foot 5 (or whatever).
> convenient.
No, it's obvious that 0 is "freezing", below that is where stuff is frozen
and outside looks white, above that stuff melts.  In normal life "stuff" is
water, so having 0 as the freezing point of water seems to make perfect
sense.
And what if you need more accuracy than 1 inch (which is required in most
household items), do you say 5 foot 10 point 7 or what?  What if you need 5
foot 3 point 85 divided into 2?  Dividing 158.3 cm into 2 is much easier.
Date: 24 May 2008 05:09:04
Message: <4837db2f@news.povray.org>
> household items)
  I have been thinking about that myself. It's not uncommon at all to
measure things in millimeters. A millimeter is a measure which can still
be easily measured with a ruler and it can be very useful in everyday life.
For example if something has to be 7mm apart from something else, you can
easily express and measure that.
  However, what are inches divided into? How would you express 7mm in
inches?
Date: 24 May 2008 09:41:27
Message: <bn6g34pgtd3vcck0dbs9l6smu7eka2fgr5@4ax.com>
On Fri, 23 May 2008 23:45:29 +0200, andrel <a_l### [at] hotmailcom>
wrote:
>We don't have that distinction. That is one of the reasons that I try to
>convince people that the scales they use to measure their weight should
>be called kilometers. Up till now with very minor success.
I'm not surprised using length to measure mass, or am I missing
something?
Regards
Date: 24 May 2008 10:35:23
Message: <483827D7.80904@hotmail.com>
> something?
You might. Probably my mistake, I should also have mentioned that we
almost always abbreviate kilogram to kilo.
Date: 24 May 2008 11:15:43
Message: <97cg34hoa4p7edbei18cijm7gmf22ungej@4ax.com>
On Sat, 24 May 2008 16:36:07 +0200, andrel <a_l### [at] hotmailcom>
As do we in the UK
Regards
