POV-Ray : Newsgroups : povray.off-topic : Why does this not surprise me? Server Time
9 Jun 2026 09:58:39 EDT (-0400)
  Why does this not surprise me? (Message 11 to 18 of 18)
Subject: Re: Why does this not surprise me?
Date: 14 May 2008 14:48:06
Message: <482b33e6$1@news.povray.org>
Darren New wrote:
> Well, here's a question for you. Other than very generic advice like
> "don't use predictable secrets" and "don't execute code from untrusted
> users" (which really covers a lot more than you may think), what would
> you teach?
How about
   Rule #1: You will NOT "add security later". It doesn't workt that way.
If more people understood that, things would be *so* much better! Too
many people think "security" is just something you can buy in a box and
install as a seperate item. It isn't.
Of similar signifigance,
   Rule #2: People WILL try to circumvent security if it inconviniences
them too much.
After that we get into smaller details, such as
   Rule #3: Any user-supplied data should be thoroughly checked before
use. [For reliability as much as security.]
   Rule #4: Treat network data with suspicion unless you are absolutely
sure where it came from.
and so forth.
http://blog.orphi.me.uk/
Date: 15 May 2008 00:50:52
Message: <482bc12c@news.povray.org>
"scott" <sco### [at] scottcom> wrote in message
news:482aa252$1@news.povray.org...
> > We had one optional (extra credit) section on a network prac that
involved
> > hacking various computers around the university.
> > Questions included getting a login prompt on the admin's server (IP
> > restricted), modifying the Journ dept's website and obtaining a file
from
> > one of the Comp Sci lecturer's PCs
> Most of what we did was totally outside any lectures or classes ;-)
So was ours. This was just the 'official' hacking portion. I did my fair
share of unofficial, as did a lot of others.
The best was when we (admins and comittee for the university computer users
society) caught 3 lusers trying to do an NTNuke on a local ISP's site.
Firstly, the ISP was running some flavour of unix (don't remember which) so
the NTNuke had no effect.
Best was that the lusers didn't wipe their command history file before
logging out.
Date: 15 May 2008 00:57:36
Message: <482bc2c0@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:482a2219$1@news.povray.org...
> What sorts of stuff would you teach?  Basic firewall and
> SQL-injection-prevention stuff? Something more?
In addition to Andrews Rule 1 and 2... (and note that I am not an expert in
security by any means)
The importance of good error checking, handling and reporting. Way too many
hacks are possible because the program does something unexpected in an error
condition (buffer overflow) or reports far too much info to users in the
case of an error.
Password and key management. Possibly covered by your 'don't use predictable
secrets'. Emphasis on how hard this really is to do properly.
Don't trust user input. A subset of your "don't execute code from untrusted
users" This covers SQL injection, XSS, buffer overflows and probably more.
Use the principle of least permissions. The picture editing software does
not need admin rights on the machine. The web app does not need to connect
to the db server as sysadmin.
Defend in depth. Always check multiple times at different levels. Assume
that the level above has been compromised. Similarly, harden the OS you're
running on. A secure app on a vulnerable OS is like a castle on wet sand.
Always work on the assumption that you will be hacked and that the hacker
knows your system. Security through obscurity doesn't work, and hoping you
won't be hacked is a poor defense
It's scary how little some know. I was at a local MS event last year and the
speaker (who is a security guru) was showing off some simple exploits. From
the response of the audience, I would guess a large portion had never seen
buffer overflow working before, and this was a room of several hundred, all
IT people, most professional developers.
Date: 15 May 2008 10:06:07
Message: <482c434f@news.povray.org>
> case of an error.
 I was about to post a similar reply; here's a snippet of it:
Client-side security doesn’t work.
You cannot securely exchange encryption keys without a shared piece of
information.
Malicious code cannot be 100 percent protected against.
Any malicious code can be completely morphed to bypass signature detection.
Firewalls cannot protect you 100 percent from attack.
Any intrusion detection system can be evaded.
Secret cryptographic algorithms are not secure.
If a key isn’t required, you do not have encryption—you have encoding.
Passwords cannot be securely stored on the client unless there is
another password to protect them.
In order for a system to begin to be considered secure, it must undergo
an independent security audit.
Security through obscurity does not work.
John
I will be brief but not nearly so brief as Salvador Dali, who gave the
world's shortest speech. He said, "I will be so brief I am already
finished," then he sat down.
Date: 15 May 2008 12:13:28
Message: <482c6128$1@news.povray.org>
> information.
Isn't think what public key encryption is all about? I mean, this is
basic Diffie Helman.
I think you probably mean something slightly different, which would be
"you can't be sure who you're talking to without a shared piece of
information."
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 15 May 2008 15:01:52
Message: <482c88a0@news.povray.org>
> information.
> detection. Firewalls cannot protect you 100 percent from attack.
Don't modify code you don't understand, particularly if it's
security-related?
http://www.debian.org/security/2008/dsa-1571
http://www.links.org/?p=327
http://www.links.org/?p=328
Date: 16 May 2008 11:14:42
Message: <482da4e2$1@news.povray.org>
Darren New wrote:
>> information.
> information."
Umm, yeah. What I meant was exactly what you said. Thanx for the correction.
John
Date: 16 May 2008 14:36:56
Message: <482dd448$1@news.povray.org>
> security-related?
+847!
