POV-Ray : Newsgroups : povray.off-topic : shake reduction Server Time
9 Jun 2026 19:37:37 EDT (-0400)
  shake reduction (Message 23 to 32 of 42)
Subject: Re: shake reduction
Date: 15 May 2008 23:12:58
Message: <482cfbba$1@news.povray.org>
Warp wrote:
> Jim Henderson <nos### [at] nospamcom> wrote:
>>composite the pictures together.
>   Somehow I have never liked that type of post-processing in photography.
> It gives me the feeling that the photo has been faked.
Hmmm, I suppose, but I also thought that the lines of people ready to
muse upon truth and artifice in photography were wide and deep. Analogue
cameras were bad enough, but now that the capture is digital and
probably filtered digitally from the start, at least that is what I
assume my camera's different shooting 'modes' are,...it seems that
'faked' is an increasingly relative term.  I'm surprised there isn't
already a camera that would perform such compositing automatically and
present the result as truth.  And can we really say it isn't?
Date: 15 May 2008 23:35:53
Message: <482d0119$1@news.povray.org>
Sabrina Kilian wrote:
> A quick googling says the A30 doesn't shoot in RAW format. There might
> be a firmware hack somewhere, but it seems this is the main Pentax
> camera, and if none of them have RAW capabilities then it isn't likely
> this one would either.
Yes I discovered that limitation almost immediately, in fact, when I
tried using the camera to document some drawings I'd done.  Once apon a
time I had a pretty good routine and adequate lighting equipment for
documenting my paintings, but now I don't.  Without hot enough lights,
the point and shoot fell well short of adequate for that task, and the
limitations of jpg only worsened the problem.  I *thought* I'd seen that
some other format from jpg was supported when I was shopping the camera,
but I was obviously mistaken.  Well maybe I can find some adequate
lights for cheap.
Date: 16 May 2008 00:12:09
Message: <482d0999$1@news.povray.org>
Personally, I find the lens far more important than anything else. A
JPEG shot thru a 68mm lens is going to look better than a RAW shot thru
a 7mm lens no matter how good the postprocessing, methinks.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 16 May 2008 00:13:47
Message: <482d09fb@news.povray.org>
Considering your eyeball does about 4 layers of preprocessing before the
image even gets to your optic nerve, it's hard to say that anything you
actually photographed could be considered "faked". :-)
An interesting and almost relevant article:
http://www.scientificblogging.com/news_releases/our_visual_system_has_future_seeing_powers_study
Date: 16 May 2008 00:54:40
Message: <482d1390@news.povray.org>
And to think 7mm is a lot compared to most cellphone cameras :D
Date: 16 May 2008 02:05:35
Message: <482d242f@news.povray.org>
  I still consider there to be a difference between, for example, a white
balance filter and, for example, compositing an image from several source
images. There's a drastic difference between those two. The latter has
something the camera didn't "see" (at least not at one single shot), so
it has a sense of "faking" to it.
  A very wide panoramic image which has been composed of several images
taken in quick succession is a rather border case. Personally I consider
it "faked, but it doesn't bother me too much".
Subject: Re: shake reduction -66KB
Date: 16 May 2008 07:45:57
Message: <op.ua8wafq2c3xi7v@news.povray.org>
And lo on Thu, 15 May 2008 20:47:11 +0100, Jim Henderson
<nos### [at] nospamcom> did spake, saying:
>>   photography.
>>   It's a bit like you took an image rendered with povray and then added
>> some lens flare effect with photoshop and then called it a "povray
>> image". Yes, part of the image was made with povray, but part of the
>> effect has been "faked", so it's not a pure povray image. It feels kind
>> of cheating.
> I think it depends on how well the compositing is done - most people
> don't do a good job with it, though, so it tends to look faked.
> But if not a composite, then what would be the way to get rid of the
> bloom in the window without losing the details in the darker parts of the
> image?
You can try and fake it to an extent from the one image. Here I created a
gradient mask centred on the lighter building and then tweaked the
histogram levels to match it in tone to the surroundings while keeping the
struts visible. It was only a quickie about two minutes tops, with more
time and more tweaking it would be possible to do more. Does it look
fake/better/worse?
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Download '0119a.jpg' (66 KB)
Preview of image '0119a.jpg'
Date: 16 May 2008 14:23:33
Message: <482dd125$2@news.povray.org>
>> Analogue cameras were bad enough, but now that the capture is digital
>> and probably filtered digitally from the start, at least that is what I
>   white
> source images. There's a drastic difference between those two. The
> latter has something the camera didn't "see" (at least not at one single
> shot), so it has a sense of "faking" to it.
I tend to agree on the first part. You can white balance, or do a lot of
the other 'processing modes' of the camera in analogue, with the right
lighting and color filters on the lens. The fact that a digital camera
makes it faster and requires a lot less investment to do it, shouldn't
matter that much.
However, a camera does see a composite image, and can create one from a
single shot. You could take film that had a higher contrast range then
the paper you put the pictures on, and selectively expose the print to
bring out the parts that you want. Shooting in RAW format acts a bit more
like film, you can tune the RAW image the same way you would selectively
expose a film negative, to get more contrast or the burn a sky out to
white, even if the actual shot contained a few clouds. In analogue, this
isn't even getting into print manipulation, just changing the time you
allow the print to be exposed to light.
And even old film allows for good post processing, dodge and burn to
composite two images, double exposure of the print media, gradient
filters for both the shoot and the film exposure, using the wrong
chemical in processing . . . there are tons of ways to 'fake' an image
while still using the original film, and if you take out double exposures
of the print and dodge and burn techniques, you can do all of them with
just the camera and chemicals.
Message: <482dd125$3@news.povray.org>
lol, so we're up to a double fake now?
Here I created
> a  gradient mask centred on the lighter building and then tweaked the
> the  struts visible. It was only a quickie about two minutes tops, with
> more  time and more tweaking it would be possible to do more. Does it
> look  fake/better/worse?
That looks noticeably better, at least in terms of diminishingoverall
bloom and getting getter saturation.  More skills for me to learn.
Date: 16 May 2008 15:35:45
Message: <482de211$1@news.povray.org>
On Fri, 16 May 2008 12:45:41 +0100, Phil Cook wrote:
> Does it look
> fake/better/worse?
Well, the part that I'm looking at is the huge white bloom from the main
windows on the street corner.  The problem is that the details are lost
because of the exposure, and that data isn't recoverable from the
original image AFAIK (ie, the CCD just registered white).  The issue is a
faster exposure will make the rest of the image too dark to pick out the
details.
Jim
