POV-Ray : Newsgroups : povray.off-topic : A question about Java generics (not a flame) Server Time
16 May 2026 16:51:01 EDT (-0400)
  A question about Java generics (not a flame) (Message 1 to 10 of 63)
Subject: A question about Java generics (not a flame)
Date: 9 May 2008 05:34:12
Message: <48241a93@news.povray.org>
Yes, I know it would be better to ask this in a Java forum, but I'm just
too lazy to dig one up (as well as not too eager to show my ignorance in
a random forum ;) ). Given the amount of programmers here, I'm sure at
least someone knows the answer to this.
  In C++, if you have a very complicated template type, such as for example:
std::map<std::string, std::vector<std::vector<std::string> > >
it would be quite laborious to have to write that type every single time
when you need it. The solution to this is to create a type alias:
typedef std::map<std::string, std::vector<std::vector<std::string> > >
    TheMap;
  Now it's much shorter to use that type. For example:
TheMap m;
for(TheMap::iterator iter = m.begin(); iter != m.end(); ++iter)
  Java supports generics, which are instantiated with a syntax very similar
to this. However, Java does not support type aliases.
  Is there a way in Java to shorten those long type names?
Subject: Re: A question about Java generics (not a flame)
Date: 9 May 2008 13:17:40
Message: <48248734@news.povray.org>
Not that I know of. In fact, it's even more annoying in that you have to
type the whole type twice when creating an object.
Map<String, ArrayList<ArrayList<String>>> theMap =
   new HashMap<String, ArrayList<ArrayList<String>>>();
ArrayList<ArrayList<String>> someList = new ArrayList<ArrayList<String>>();
Of course, you could also use interfaces for the type and generic
parameters, only using a real class for the actual object you're creating,
making it a bit shorter:
Map<String, List<List<String>>> theMap =
   new HashMap<String, List<List<String>>>();
List<List<String>> someList = new ArrayList<List<String>>();
//and let's continue the example
List<String> deeperList = new ArrayList<String>();
List<String> otherDeeperList = new ArrayList<String>();
deeperList.add("one");
deeperList.add("two");
otherDeeperList.add("three");
otherDeeperList.add("four");
someList.add(deeperList);
someList.add(otherDeeperList);
theMap.put("foo", someList);
It's interesting to note that in scripting languages, all that could be a
one-liner. In Javascript:
var theMap = {"foo": [["one", "two"], ["three", "four"]]};
And even more interesting to note that C++0x will allow an initializer
syntax almost as short as that :)
Date: 9 May 2008 13:41:09
Message: <48248cb5@news.povray.org>
Nicolas Alvarez <nic### [at] gmailcom> wrote:
> Not that I know of.
  I was thinking if it's not possible even through inheritance.
Something like (iirc Java syntax):
class TheMap extends Map<String, ArrayList<ArrayList<String>>>
  Then just use TheMap? (Of course from a purely OO point of view this
could be seen as a misuse of inheritance, but...)
  I will never understand why they decided to drop 'typedef' when they
designed Java in the first place. It's so handy in C++.
  Yeah, but that's only possible in languages with weak typing (I think
that's the term?) In other words, in languages where you don't have to
specify types explicitly, as they are inferred from the values.
  I also wonder if the new 'auto' feature in C++0x will help alleviating
this nuisance a bit. At least it will allow writing things like:
auto p = std::make_pair(value1, value2);
  You don't have to even care what is the type returned by std::make_pair
or the types of those values, which is cool.
Date: 9 May 2008 13:48:38
Message: <48248e76$1@news.povray.org>
[insert ironic comment here]
>   Java supports generics.
...OK, I just learned something.
Given the statement above, is there any point in my answering this? ;-)
http://blog.orphi.me.uk/
Date: 9 May 2008 13:54:36
Message: <48248fdc@news.povray.org>
Well, in Java everything is a class. So it's not 100% obvious where
you'd *put* a typedef. (I suppose it could be something that's local to
a class or something...)
Two cases here:
- JavaScript is dynamically typed. Types become known only at runtime.
Types are checked only at runtime. Many scripting languages follow this
model. (Smalltalk immediately springs to mind here.)
- Haskell is statically typed, but types are [usually] inferred
automatically. Types are checked at compile-time only. Types are not
known at runtime at all. [With the exception of types belonging to a
class of some kind.]
Obviously nobody cares, but:
   theMap = fromList [("foo", [["one", "two"], ["three", "four"]])]
Date: 9 May 2008 14:29:08
Message: <482497f4@news.povray.org>
  You'd put it in the exact same place as you'd put a class.
Date: 9 May 2008 14:34:49
Message: <48249949@news.povray.org>
  Java generics are a bit ironical because before they existed the
common consensus among Java people was that C++ templates are an
abomination (in the same category as, for example, multiple inheritance,
if not even worse).
  Of course this was before all the generic programming craze, and when
it hit, the Java people had to swallow their pride and introduce some
crippled template mechanism into Java. Naturally since templates were
always considered an abomination they couldn't call them that, so they
tried to save even a bit of their pride by renaming them to "generics".
(I suppose "generics" rides more on the whole "generic programming"
thing.)
  Of course Java generics are a bit crippled because they don't support
basic types (such as int). Thus they solve only part of the problem which
Java had before.
Date: 9 May 2008 14:50:19
Message: <48249ceb$1@news.povray.org>
> if not even worse).
> thing.)
> Java had before.
Well, actually Eiffel calls it generics too. I don't know when Eiffel
was designed, but it's had generics from day 1, and that has always been
its name.
I don't actually know how C++ templates work, but my take on it is this:
- Generics is the ability of a programming language to implement classes
that are parameterised over another class.
- C++ implement this ability using templates.
- Templates can do other things besides implementing generics.
So to say that Java's generics is a crippled copy of C++'s template
mechanism isn't entirely true.
OTOH, I haven't seen Java generics or C++ templates "for real", so maybe
I'm mistaken.
Date: 9 May 2008 15:00:54
Message: <48249f66@news.povray.org>
  I think it suffices to say that with C++ templates you can, for example,
calculate at *compilation time* whether a certain number is prime or not.
  Moreover, you can even do that without using any integer literals or
any basic type, such as 'int'. (Although doing it like that is really
not the most efficient way.)
Date: 9 May 2008 15:15:21
Message: <4824a2c9$1@news.povray.org>
So... it's Turing-complete?
