POV-Ray : Newsgroups : povray.off-topic : A question about Java generics (not a flame) Server Time
13 Jun 2026 08:38:29 EDT (-0400)
  A question about Java generics (not a flame) (Message 61 to 63 of 63)
Subject: Re: A question about Java generics (not a flame)
Date: 17 May 2008 05:52:26
Message: <op.ubalpng87bxctx@e6600.bredbandsbolaget.se>
On Sat, 17 May 2008 10:36:31 +0200, Warp <war### [at] tagpovrayorg> wrote:
>   Sorry, I still don't understand this.
>   I tried my foo-bar example making the bar() function a template which
> was
> specialized in one of the compilation units but not the other, and at
> least
> gcc still behave in the same way: When foo() was not inlined, only one
> version of bar() was called: The specialized version was never called.
Your foo-bar example is ill-formed. The compiler can do whatever it wants.
>   From what you have written it sounds like the compiler would have to
> always call the specialized bar() template if it is in the context of
> the foo() instantiation, but at least gcc doesn't behave this way (and,
> frankly, I don't know *how* it could behave that way without seriously
> messing things up).
It is commonly called "two-phase lookup" (though it is not named as such
in the standard) and is explained in section 14.6 [temp.res] of the
standard. Section 14.6.4 [temp.dep.res] deals specifically with dependent
name resolution.
Compiler writers have been rather slow in implementing two-phase lookup
properly, almost as slow as with implementing 'export'.
FE
Date: 17 May 2008 07:41:18
Message: <482ec45e@news.povray.org>
> > was
> > least
  How is it different from your example, which you gave earlier? Also you
had a template function calling another template function, and the latter
being specialized in the context of instantiating the former. That's exactly
what I did.
Date: 17 May 2008 07:56:24
Message: <op.ubarf9o57bxctx@e6600.bredbandsbolaget.se>
>> wants.
> exactly what I did.
The difference is that you are instantiating 'foo<int>' in more than one
place. When you do that, the instantiations must have the same meaning or
the program is ill-formed. In my example 'f<int>' is only instantiated
once. That example was intented only to demonstrate why an exported
template must be recompiled when code that uses it is changed.
FE
