POV-Ray : Newsgroups : povray.off-topic : A question about Java generics (not a flame) Server Time
10 Jun 2026 00:20:41 EDT (-0400)
  A question about Java generics (not a flame) (Message 24 to 33 of 63)
Subject: Re: A question about Java generics (not a flame)
Date: 10 May 2008 16:48:45
Message: <op.uayhfiwh7bxctx@e6600.bredbandsbolaget.se>
On Sat, 10 May 2008 22:05:53 +0200, Darren New <dne### [at] sanrrcom> wrote:
> OK. So the linker is doing duplicate-code removal. It also would seem to
> assume that all your object code is compiled with the same template
> source code? Or does it actually look at the object code to make sure
> it's the same?
It must be the same, or the program is ill-formed.
> I.e., if I compile A.cpp that includes T.chh to instantiate
> xyz:vector<long>, and then I edit T.chh and then compile B.cpp that
> instantiates xyz:vector<long> but that now generated different code,
> does the linker carry around both versions of the object code?
If you change T.chh, then A.cpp - and any other source file that includes
T.chh - must be recompiled.
FE
Date: 10 May 2008 17:46:12
Message: <482617a3@news.povray.org>
> >   At least Java generics do not support basic types, so I don't really
> > understand what you are talking about.
> I'm saying you could pre-compile many templates if the templates only
> are capable of doing what generics do.
  I don't see why that would be so.
> >   I suppose that no compiler so far uses this optimization, but I can
> > perfectly imagine it being absolutely possible: When a template class or
> > function is instantiated for a certain type, the compiler could compile
> > it into some type of object file. Next time that template is used with
> > the same type (be it in the same compilation process, by another compilation
> > unit, or in a future one) it can simply use that object file instead of
> > recompiling the template code.
> Yes. Bingo. That's a generic.
  I don't see why. (Or, more precisely, I don't see why this would limit
anything in templates.)
> You can't do that with templates because
> you (a) can't tell if the template will generate the same code with
> different classes/parameters
  I was just saying that the compiler could generate reusable object files
from used types (so that when those types are used again with those templates,
the template code doesn't need to be compiled again). Granted, you still
can't make binary-only distributions of libraries, but at least you cut
down compilation times if the same types are used a lot with a given
template.
> > The mechanism to do this could be similar
> > and related to export templates (or if technical reasons mandate it, it
> > could only work with export templates).
> I don't know what an "export template" is, so you may be right there.
  In C++ an export template is a template mechanism where the implementation
of a template can be located in its own compilation unit (meaning that the
implementation of the template code is in its own .cc file and the template
code gets actually inserted in an object file). In other words, the
implementation of a template function doesn't need to be in the header file
where the template function is declared. This makes header files simpler,
object files smaller and compilation of complicated template code faster.
  What this means in practice is that the linker will re-call the compiler
for any export template which is used in the code in order to get the
actual template instance. OTOH, the template is instantiated only once
instead of being instantiated for every usage.
  While export templates are defined in the C++98 standard, sadly not
many compilers support them yet (gcc fairly recently introduced experimental
support).
> >> In any case, what *I* meant was that you get a new blob of code compiled
> >> every time you instantiate a template. Not for each different type, but
> >> even for the same types in different compilation units. Yes? Or am I
> >> confused about that?
> >   Currently yes, but as I said, it's perfectly conceivable that this
> > could be optimized by compilers.
> Sounds like it would be difficult, given that there's no relationship
> the compiler can rely on between template sources and template object code.
  As I said, the export template mechanism I described above might be
usable for this kind of optimization.
> >   The linker always merges all template instantiations of a given type
> > into one (this is required by the C++ standard, AFAIK). In other words,
> > the final executable will have only one instance of those functions.
> > That's not the problem.
  No. The compiler marks the function type names with the 'inline' tag,
which means that when the linker sees that type name in more than one
object file, it only uses one of them (instead of giving you a linker
error about duplicate function type names).
  In other words, basically, when the compiler name-mangles the function
it just created from the template, it puts a mark in it which tells the
linker "if you see this same function name in another object file, just
use one of them, ignore the rest".
  I assume it would be possible for the functions to actually be different
in content (which might happen if you have broken dependencies), in which
case you get undefined behavior (I suppose in practice the linker will
choose one of the functions, probably the first one it encounters, and
ignores the rest).
  Note that any inline function (if it's not actually inlined by the
compiler) gets the same treatment, not just template functions: Even if
the inline function appears in more than one object file, the linker
will use just one of them and ignore the rest.
  (Export templates are not "inline", but that doesn't matter because
their implementation is in one object file anyways.)
> it's the same?
  I actually don't know. I suppose that a smart linker could actually
double-check that the functions in the different object files actually
are identical and give an error if they aren't. I have never tested
what eg. the gnu linker does. It would sound rather trivial to do.
  The object file created from A.cpp and the one created from B.cpp
both will claim to contain the same function, but their machine code
will be different. As I said, I have never tested if linkers actually
test if they are, in fact, identical.
> Generics in Java aren't even really generics, since they get
> type-erased. But yes, I'm not talking about "generics as implemented in
> Java without actually changing any object code." I'm talking about when
> people speak of generics in a language that actually supports generics,
> like Eiffel or Ada, for example.
  Btw, what is the basic difference between generics (as in Eiffel&co)
and delegation?
  If I'm not completely mistaken, delegation is like having all functions
virtual, but without having to declare them in the base class. In other
words, if you have a reference-to-Base, but that reference is actually
pointing to an object of type Derived, and then you call a function foo()
through that reference, and there is no foo() in Base, but there is one
in Derived, it gets called ok. The delegation system checks at runtime
what is the actual object behind that reference, and if it has a function
called foo(), and calls it if that's so. (If I'm not mistaken, this is
how inheritance works in Objective-C.)
  Delegation sounds like an alternative to templates/generics.
> >   The amount of code "bloat" caused by templates is usually
> I wasn't aware the linker removed duplicate object code. That's the
> bloat I was speaking of.
  It's not so much that the linker "removes" code per se, it's more that
it just uses one instance of a given function and ignores the rest. (Well,
I assume that's how linkers do it in practice.) After all, the linker is
building an executable from a bunch of object files, deciding what to
take from each object file. In the case of inline/template functions it
just takes one duplicate and leaves the rest.
Date: 11 May 2008 13:32:14
Message: <48272d9e$1@news.povray.org>
>> to assume that all your object code is compiled with the same template
>> it's the same?
Um, OK. But that's unenforcable, right?  At least in C++?
> includes T.chh - must be recompiled.
And this is why Java doesn't do templates. You may not have the source
code for A.cpp.
It seems there are two kinds of languages out there: ones where the
program is monolithic and if you don't have all the sources, you can't
really use the object code effectively, and ones that are particularly
designed to avoid the problems that the first group encounter. :-)
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 11 May 2008 14:17:44
Message: <48273848@news.povray.org>
> code for A.cpp.
  You mean that if the public interface of a class T changes, nevertheless
the class A which uses T doesn't need to be recompiled? How does it manage
to do that?
  After all, the T.hh header might just contain the public interface for
the template code. Its implementation may be in its own compilation unit
(if the compiler supports fully the C++ standard).
Date: 11 May 2008 14:20:48
Message: <48273900$1@news.povray.org>
Because if the templates calculate something at compile-time based on a
parameter you pass in (like the number of elements in an array), then
you can't precompile it.
I'm saying that the things templates do that generics don't are the
things that make it difficult to precompile templates.
> template.
Sure. Generics are (usually) restricted in a way that allows you to
distribute the executable (or .o file) without distributing the source
and others can still use it.
Funky. OK.  That's getting closer to being what people generally mean by
"generics". :-)
Put it this way: If you can't compile it and distribute a .o file
*before* you know what type you're instantiating it with, it's probably
not what people mean by the word "generic".
Isn't that duplicate code removal by the linker? Maybe we're in
agreement and I'm just not understanding the subtleties or something. :-)
Yeah. That's the sort of "bondage and discipline" that Ada enforces to
keep that mistake from surfacing. If you compile a generic in Ada, you
can't change the header file and then link against the old .o file.
[snip of lots of explanation]
Thanks for clarifying that for me.
>> it's the same?
It would seem that way, especially if you're generating different code
for every type even if you don't have to. Or you could even have the
linker detect (say) that the code generated for MyTemplate<int*> and
MyTemplate<long*> both come out the same and use the same object code
for both.
> will be different.
Got it. That's what I thought.
> and delegation?
That's essentially right, yes.  Generics and delegation are actually
unrelated, and you probably can't even reasonably have both in the same
language.  Generics are a way of having one function/class/etc work with
variables of multiple types, which implies you have static typing, i.e.,
that your variables have types to start with. Delegation is an
alternative to inheritance, where you "inherit" from object instances
instead of statically from classes. `In other words, instead of having
class A say "I'm just like class B, except for the differences I declare
here," you have *instance* A say "I'm just like *instance* B, except for
what I have dynamically assigned into my object." It's also called
"prototype inheritance" sometimes.  You can do delegation "manually" in
statically-typed languages (or get compiler support for it), and it's
still called "delegation", but it's only "prototype inheritance" if
every object works that way.
It's more an alternative to inheritance. You don't need generics if you
don't have static typing (i.e., if your variables are untyped,
regardless of whether operations on values are type-checked).
Here's my understanding of the terms as they're used in a more general
sense:
Macro - transforms almost arbitrary pieces of text into other pieces of
text at compile time.
Macro[2] - (Lisp sense, Erlang "parse transform" sense) - transforms
arbitrary subtrees of the parse tree into other arbitrary subtrees of
the parse tree. (I.e., if it didn't parse before you applied the macro,
it won't parse after, either. Erlang has both types, fwiw.)
Template - A macro that is restricted to generating a particular node of
a parse tree, given other particular nodes of a parse tree. I.e., a C++
template can only generate functions or classes (IIUC) and can only take
types or integers as parameters. These restrictions let the compiler do
things like duplicate code removal. But it's still essentially a
compile-time source transformation.
Generics - A type of object that is parameterized at compile-time.
Usually only takes types as arguments. Invariably can be (often, must
be) compiled before being instantiated, and can be instantiated with
types created after the generic is compiled.
"is-a" inheritance  - (I don't remember what the people who play with
different inheritance methods call this, beyond "class-based
inheritance".) The usual class/superclass inheritance.
"prototype inheritance" - Object instances inherit from other object
instances. There usually isn't the idea of a "type" as such in the
language, other than as defined by the behavior of different objects.
Naturally, you often have lots of objects delegating to some other
object that has only functions in it, at which point it behaves a lot
like "is-a" inheritance.
"delegation" - Manual or automated support for dispatching unknown
method invocations to another object when the original target object
doesn't define the method.
"aspect-oriented programming" - Took me a while to figure this one out.
It lets you say things like "every method in class B should call "debug"
before it starts and "end_debug" before it exits", and in another place
say "every method of A or subclasses should call "transaction_begin" at
the start and "transaction_end" at the end, and if B is a subclass of A,
then B gets both new behaviors, without having to muck with B or callers
of B. Sort of like how some languages let you use "super" to say "first
do this, then invoke my superclass's behavior for this method, then do
that", only in a more general way. Same sorts of advantages you get with
inheritance/dynamic dispatch not making you put case statements all over.
So, like the same object file showing up in separate libraries in C, it
just links in the first one because it already satisfied the
dependencies. OK. Now that I realize templates really only build code
that you dont *have* to inline, it makes sense. (Contrasted with C-style
macros, which can build expressions that would make no sense on their own.)
It's all coming together... :-)
Date: 11 May 2008 14:35:49
Message: <48273c85$1@news.povray.org>
>> code for A.cpp.
> to do that?
Dynamic loading. :-)
Seriously, tho, I wasn't necessarily talking about the public interface.
I was talking about the implementation of the functions. In Java, the
code for the generic isn't duplicated for different types, and it gets
linked in at runtime. Hence, the whole question of "what if it changes"
doesn't matter - you compile against the types, not against the bodies
of the code. If you change the public interface to the point where the
old code won't work, then when you try to instantiate the generic, it'll
tell you that code couldn't be dynamically loaded. I.e., it falls back
to being a run-time error, just like if you try to load a .so / .dll and
that isn't present on the disk. (Which I guess is in some ways worse
than what you get with C++ and static linking. :-)
The whole "export template" bit I don't understand. I have to believe
that either there are restrictions on what a template can do and still
be able to be an export template, or there are bits in the object file
which are essentially getting recompiled at compile-time.
How does it work if the template class declares in one of the functions
an array of type T (where T is one of the generic parameters), and then
indexes that with []?  If T overrides [], it has to call different
things for each T, and if T doesn't override [], it has to use different
multipliers based on the size of each T object, yes? If you're not doing
that, then you have generics instead of templates, where the same code
is getting used and when you "instantiate" it, it fills in blanks like
"pointer to function that does indexing, size of one element of the
array", etc?
I've even seen purposely-obtuse C++ template stuff that either declares
a type or a function (both with the same name) depending on the size of
the generic type passed in or some such, which would seem to be
something really difficult to put into object code that doesn't have to
get recompiled when you instantiate it.
Date: 11 May 2008 14:55:22
Message: <op.uaz6uksh7bxctx@e6600.bredbandsbolaget.se>
>>> it's the same?
Compilers/linkers are free to enforce it, but I think most implementors
see it as not being worth the effort.
Support for modules (similar to how Java does it) in C++ is planned for
the future. Last I heard it will not be included in the upcoming standard,
but will most likely be in the next Technical Report.
FE
Date: 11 May 2008 15:00:29
Message: <op.uaz6222m7bxctx@e6600.bredbandsbolaget.se>
Read this paper to learn a little about what 'export' means, and why many
consider it to a bad idea:
http://std.dkuug.dk/jtc1/sc22/wg21/docs/papers/2003/n1426.pdf
FE
Date: 11 May 2008 20:18:31
Message: <48278cd7@news.povray.org>
  AFAIK there are no restrictions on what an export template function
can contain.
  The basic implementation of export templates, from the point of view
of the compiler, is that the template *source* code gets written to the
object file (either as raw source code or some kind of pre-parsed code
or whatever; I don't know how eg. gcc does it in practice). When the
linker sees that it needs a specific instance for a certain template
function, it calls the compiler and tells it "I need an instance of
this template function with these types", the compiler compiles the
function for those types, and then the linker uses the generated code.
  As you might imagine this is far from trivial to implement, which is
the reason why so few compilers support this.
  In theory you could distribute template code as "precompiled" object
files, without the original source. However, I assume that with most
implementations of export templates, creating a decompiler for those
object files is probably fairly trivial (because, after all, the object
file has to have the original source code in one form or another inside
it for the whole export template mechanism to be possible).
  Btw, there's an additional advantage in export templates besides the
smaller simpler header files and object files, and it's one which cannot
be used with compilers which do not support export templates and it can
have very practical uses: Export template code can use functions and
types which are local to that compilation unit. This can be used to
increase modularity (by hiding implementation details).
Date: 12 May 2008 12:10:55
Message: <48286c0f$1@news.povray.org>
OK, that would be my second statement, then. The template is actually
getting recompiled down to object code each time you instantiate it,
even if it's an "export" template.
In a language like Ada (which has generics but not templates), you
compile the generic down to object code, and when you instantiate it,
you don't need the source for the implementations. I believe it can work
by basically, at instantiation time, building a descriptor not too
different from a vtable. If the only difference is which overloaded
functions get used, the object code will expect a table of pointers to
be created for it to invoke those functions. If it expects a different
size, then the object code is (possibly) duplicated and the size filled
in (just as you would fix up external references at link time), or the
code is slightly less efficient and takes as one parameter the size it
needs to work with.
In Java, of course, it compiles down to the same code as you would have
without generics, and you compile it once and ship the bytecodes. The
compiler basically just does error checking if the declaration is in
scope and casts the result of operations at runtime if so needed.
